LhMusL new torry
#76
Posted 09 May 2009 - 05:52 PM
#77
_Lamo_
Posted 09 May 2009 - 05:56 PM
#78
_Squarepants_
Posted 09 May 2009 - 06:08 PM
The white sun visor defiately need a white roof to match, otherwise paint it red. Venitians are awesome!
I really like what you're doing with this car, I hope you can fix it and continue with what you were planning.
You've inspired me for my next project (whatever that may be...)
Nice work dude!!!
#79
Posted 09 May 2009 - 07:36 PM
Cheers Squarepants, yeah will get it painted oneday! and a white roof is on the cards
Hey Pete i guess a more important issue with the tank is if it is a 4 or 3 access hole tank? Because i wantto run 2 true lines and i believe on the 4 hole tanks you just added a combination/Dueo (T peice) on the "Relief Valve" hole (so it acted as a relief valve and a second line), so you could have twin true lines????
But on the new tanks they only have 3 holes and run one of themwith a T peice std????????
So i hope one of these A86 or A90 have the 4 hole setup, coz i don't want to run no fuel gauge to have the 2 line setup!!!!
Its all a bit confusing coz i was reading that one 5/16 or 8mm line is ok but its the 3mm oriface in the lock offs thats the restriction to flow above 220rwkw. So would the ideal be a 4 hole tank with 1.Fill 2.gauge 3.relief valve/2nd outlet line 4.Primary outlet, with the out lets each going to there own lock off(heard you can get larger 4mm ones?? (VH 30's?? increase flow by36%)??? Or was it 2 lock off's per out let!!
Been reading all this on Vl Turbo sites where they are going for 400rwkw+ etc. with GRA setup's.....
Edited by LhMusL, 09 May 2009 - 07:38 PM.
#80
Posted 10 May 2009 - 04:34 PM
Also we fit the twin service valves in by putting the AFL (automatic fill limiter) in where the pressure relief valve (PRV) is located, ie. a screw in fit, then we can fit another service valve where the AFL was located. The reason for the small holes in the service valve is to ensure that the solenoid can open the plunger against the pressure of the tank.
Hope that answers a few of your questions
Ollie I stand corrected that is definatly a A90.
Edited by Peter UC, 10 May 2009 - 04:35 PM.
#81
Posted 11 May 2009 - 08:31 AM
So are you going the TechnoCarb setup? Gary (Guns N Roses) is running this on his Torry, he bought the whole set-up from a gas place in Warragul? or some place up that way.. Then he just fitted it himself! Man they look horn though!
Thats kinda good news about not needing the VIV thing! You can just go nuts and get the car fixed!
Let me know if you need a hand with stuff, probably cant help for a few weeks though, until i get the stuff i want to do done on the house.
#82
Posted 11 May 2009 - 04:59 PM
So i guess the main question is gonna be how long would it take to get a special order A90(4 flange) with twin line setup and doulbe layer filters???
#83
_@milco@_
Posted 11 May 2009 - 05:43 PM
hey can you find out the name of the place he got the techno carb from? i am very interested in doing this to me lx
#84
Posted 11 May 2009 - 06:48 PM
#85
Posted 12 May 2009 - 04:06 PM
#86
Posted 12 May 2009 - 04:36 PM
PM me you details if you like
#87
_torana_umunga74_
Posted 12 May 2009 - 05:13 PM
#88
Posted 13 May 2009 - 12:57 PM
#89
Posted 13 May 2009 - 01:13 PM
#90
Posted 13 May 2009 - 06:24 PM
#91
_ultrabluea9x_
Posted 08 June 2009 - 05:31 PM
#92
Posted 15 June 2009 - 03:01 PM
#93
Posted 15 June 2009 - 06:41 PM
But now the problem is she isn't firing!!!!!!!!!! Grrrrrrr
Spark- check
Fuel - Pooling in base of redline single plane manifold, same outcome with different carbs. Would love a torque power but not sure if the manifold is the problem.
Cam timing is next to be checked.........
All my lovely cam lube is being wiped off from to much cranking, might need to take off manifold and re-lube. (need more lube to much cranking lol)
#94
Posted 16 June 2009 - 05:12 PM
So hopefully it will come out when we drop the sump or is in the timing cover etc. as would prefer not to pull engine out to get sump off to find the little bugger.
Prob shouldn't run the engine with that bit floating around hey???
At least we know what the problem was!!!!!!
#95
Posted 16 June 2009 - 10:47 PM
#96
Posted 17 June 2009 - 04:49 PM
It was the cam shaft dowel pin that broke, is there any reason why this would have happened?????
Didn't come out when the oil was dropped and its not in the timing cover, getting a fibre optic scope thingy to hopfully locate it with, so we don't have to pull the engine....
#97
Posted 17 June 2009 - 06:39 PM
#98
Posted 19 June 2009 - 11:28 AM
#99
Posted 19 June 2009 - 11:34 AM
#100
Posted 20 June 2009 - 10:55 AM
Just got a msg from UltraBlueA9x (Glen)
Ol Vacum cleaner over the dip stick tube got the sucker out!!!!!!!! Some luck at last hey Matty
Might be drivable this weekend
