Challenger Wheels 15x10 - anyone seen them
150 replies to this topic
#51 _LXChev366_
_LXChev366_
Posted 01 July 2007 - 05:46 PM
OK, just found this thread...
I run 15x8 all round, the photo of my car makes the rears look bigger?
The front and rear has Ford Stud pattern.
BUT, i have a special length 9 inch diff fitted so that the wheels and tyres fill the guards. They (very minor) scrape in a couple of spots. I use Yoko 225/60/15 AO32R Tyres
The fronts just touch the upper wheel tub next to the inner guard and lightly on the outer guard. The rear part of each front wheel tub needed hitting back ie about where front mudflaps would normally be fitted, as they would have rubbed on full lock. I run Wilwood 4 spot Front calipers.
The rears lightly touch the outer wheel arches.
The wheels (Qty 8) were bought from Mullins Wheels Cheviot Rd Salisbury SA back in 1996 for $1528. The wheels are 18mm neg offset. part no. 152-580N18-54C. The guy I bought the car from gave me all the tech sheets about the car, which helps in times like this.
Edited by LXChev366, 01 July 2007 - 05:49 PM.
#52 RIM-010
Posted 01 July 2007 - 05:50 PM
^^ Buger off Rim!
If you're referring to me, this is the first post I've made in this thread...
#53 _rorym_
Posted 01 July 2007 - 06:17 PM
Just trickin RIm!...I think someone has got their spacings wrong..mine fit fine!.
#54 RIM-010
Posted 01 July 2007 - 07:02 PM
:blink:
So, you were referring to me, even though I've had no input into this thread?
Edited by RIM-010, 01 July 2007 - 07:12 PM.
#55 _rorym_
Posted 01 July 2007 - 07:05 PM
:huh:
#56 dattoman
Posted 01 July 2007 - 10:48 PM
I didn't know there was an offset choice
Wilwoods fit under his 14's
But not the 15x8 Challengers
Will investigate further
#57 A9X
Posted 01 July 2007 - 11:08 PM
Get onto it big guy.
It might help our own problems.
Welby
#58 dattoman
Posted 01 July 2007 - 11:10 PM
You might go to Challengers ?
Maybe we should try his wheels on your front end
#59 _LXChev366_
_LXChev366_
Posted 01 July 2007 - 11:52 PM
I've got wilwood 4 spots with 309.6mm rotors under my 15x8 wheels whats the problem?
I have been using them for nearly 2 years, photo of my car is on page 2 I thinkof this thread.
#60 dattoman
Posted 02 July 2007 - 12:48 AM
The problem might be wheel offset
Your brakes are obviously very different to the 276mm HQ discs with Wilwood calipers that Alex has and Rory will be using
Got pics of them ?
#61 _rorym_
Posted 02 July 2007 - 07:48 AM
Seems weird to me they would clear 14 x 8 Hotwires and not 15 x 8 Challngers?..
#62 _LXChev366_
_LXChev366_
Posted 02 July 2007 - 10:40 AM
When I get a chance I will snap a pic 4U. I do have custom Wilwood Rotors on a Alloy Hat. The wheel offset I have is neg 18mm, In one of my previous posts I give the part no's of my wheels.
#63 dattoman
Posted 02 July 2007 - 04:17 PM
Maybe the larger rotor moves the caliper up enough to clear the centre hub of the wheel
#64 _rorym_
Posted 02 July 2007 - 04:30 PM
I dont have hub clearence issues on my HQ centres...what u on about whiteman?
#65 dattoman
Posted 02 July 2007 - 05:59 PM
Have you fitted 15x8 challangers to your car Rory ?
#66 _rorym_
Posted 02 July 2007 - 09:35 PM
Not yet but being in the game for a few years noticed the inside formation of most rims have pretty much the same clearences so unless the Challenger has a HUGE inward lip/indentation on the mould...which I would find pretty weird..... I cannot understand why it would be a problem.
Edited by rorym, 02 July 2007 - 09:35 PM.
#67 _LXChev366_
_LXChev366_
Posted 02 July 2007 - 10:18 PM
Ok took some pics... didnt realise how dirty everything looks when you take a photo :<_<: It used to look pretty about 2 years ago :rolleyes:
Other pics here....
http://s18.photobuck...C...v Race Car/
Edited by LXChev366, 02 July 2007 - 10:22 PM.
#68 _rorym_
Posted 02 July 2007 - 10:21 PM
Datto, you have a problem..there is no clearence problems there at all..you need to look at Alexs thing post haste. And they are the old HUGE Wilwoods..mine are the newer small ones.
Edited by rorym, 02 July 2007 - 10:23 PM.
#69 _LXChev366_
_LXChev366_
Posted 02 July 2007 - 10:35 PM
and here is the wheel flipped over... 15 x8 with 225/60/15 yoko AO32R Tyres.
#70 dattoman
Posted 03 July 2007 - 12:13 AM
On the back of wheel shot.... does that big flat looking area taper off or is it a flat flange the same from the hub area out ?
How far out from the bolt up face of the disc does your caliper stick out if at all ?
#71 _LXChev366_
_LXChev366_
Posted 03 July 2007 - 07:10 AM
It tapers off at the start of the unpainted flat flange, the 25mm ring you can see tapers towards the outer part of the rim the same as the 5 spokes. In the lower part of the photo it looks flat but the upper part looks all tapered.
The caliper is slightly less than the BUF. The little plug under the centre W in "WilWood" is about flush with the BUF. So no the caliper does not stick out.
#72 _rorym_
Posted 03 July 2007 - 08:10 AM
The BUF side on shot shows the caliper is a fair distance back in for clearence .
#73 dattoman
Posted 03 July 2007 - 09:40 PM
Welbys poke out past the BUF by nearly 15mm
Haven't seen alex's yet
I think his are the same old style Superlites
#74 _BCR42Y_
_BCR42Y_
Posted 03 July 2007 - 11:13 PM
If I supply some photo's, can a photoshop guru photoshop these wheels onto my car so that I can get an idea of how it may look.
#75 _rorym_
Posted 19 July 2007 - 07:20 PM
Hmmm...Might have to measure mine..
