Please let me know.
Posted 05 May 2007 - 04:13 PM
Posted 05 May 2007 - 08:57 PM
Posted 08 May 2007 - 11:33 AM
Posted 08 May 2007 - 11:53 AM
Posted 08 May 2007 - 12:59 PM
Posted 08 May 2007 - 08:12 PM
Posted 08 May 2007 - 08:17 PM
Put a thermostate in it.Im havin a few heating probs on the 173 (not overheating but running to cold)
Posted 08 May 2007 - 08:32 PM
Posted 08 May 2007 - 09:23 PM
74deg means it opens earlier, making the problem worse. go up in numbers to heat it up more i.e. 90deg etc.It has a 74 degree thermostate in it and still doesn't heat up properly
Posted 09 May 2007 - 12:28 AM
What other hoses? Do you have hoses going to the manifold?while I was checking the hoses for leaks I noticed the hoses going to the heater box were not even warm but all the other hoses were quite hot as was the top of the radiator, but the bottom of the radiator was cold as was the hose from the bottom radiator to the waterpump.
Posted 09 May 2007 - 01:02 AM
Posted 09 May 2007 - 01:25 AM
just put a higher numeric thermostate in it, high 80's or low 90's deg.yeah all hoses are connected right, 1 thing I forgot to mention it does have a large 6 blade flex fan on it, if I replace it with a stanard 4 blade fan do you think this would help ?
Posted 09 May 2007 - 05:36 PM
Posted 19 May 2007 - 03:03 PM
Posted 21 May 2007 - 04:14 PM
Posted 22 May 2007 - 12:20 PM
Posted 26 May 2007 - 12:35 AM
Posted 26 May 2007 - 08:46 AM
Posted 27 May 2007 - 01:12 AM
Those were the good old day's, learn't heaps doing those sorts of things.Ahhhh.......
Those were the days, o/hauling water pumps and reaming king pin bushes.
They don't know what they're missing. Or do they?
Posted 27 May 2007 - 07:22 AM
in the past when a heater core has failed,but the heater has needed to appear connected, i have put a section of broom stick into the heater pipe.while I was checking the hoses for leaks I noticed the hoses going to the heater box were not even warm but all the other hoses were quite hot as was the top of the radiator,
so before I go pulling things apart does anyone have any other ideas?
Posted 03 November 2007 - 10:43 PM
Can I use number 1 in a VK motor....Hi Guys.
There are actually 4 different water pumps for the Holden 6.
1. EH to HK (small hub & short shaft) this has the common industry part no. of W587
2. HT to HZ/VB & LC to UC Without viscous fan clutch (large hub & short shaft) part no. W726
3. HJ to HZ/VB & LC to UC With viscous fan clutch (large hub & long shaft) part no. W814
4. WB/VC to VK Large housing & bearing (commonly called the 'Jumbo' pump) part no. W815
Edited by blown308, 03 November 2007 - 10:45 PM.
Posted 04 November 2007 - 05:59 AM
Posted 04 November 2007 - 08:05 AM
Posted 16 November 2009 - 05:44 PM
Posted 19 November 2009 - 02:52 PM
To gain more space you don't necessarily need the very early pump. The HT to HQ one will do the job. The only difference between the two is the pulley bolt pattern, they have the same (short) offset.Anyone know now were to buy cast impeller pumps now? im after the early eh, hd, hr pump, i am changing over from the commodore type to get room for a supercharger belt, my old pump with a cast impellor has been on the motor with water for about 12 months and done about 5000 ks but the pulley is in the way.
0 members, 3 guests, 0 anonymous users
