'Purple' build thread
591 replies to this topic
#451 Statler
Posted 02 December 2015 - 08:11 PM
Been having a little win.
After waiting months for the sparky to show up, i was given the name of another one. Gave him a call ...... he quoted ...... & Purple is now wired! :) Thank you ODan Randall. :)
It still hasn't run, but it winds over. Been fixing fuel system leaks. Ended up removing the 'barb > hose' fitting on the fuel rail inlet & having a 'weld on adaptor' fitted. ( I still hate paying ppl for welding ) I have excessive fuel pressure. Seems the -8 hose going to -6 fuel reg fittings isn't a good thing.
I need to change out the fuel regs & fit the Holley one. The factory reg on the fuel rail has to go too. So another 'weld on' fitting needed & some more hose  fittings.
Managed to partially fit most of the interior.
I am happy with the way it is looking. Still not clean.
Finally i can see a little bit of light at the end of the tunnel! :)
#452 N/A-PWR
Posted 02 December 2015 - 08:17 PM
Nice Engine Bay Col,
great news.  :clap:
#453 Ice
Posted 02 December 2015 - 08:49 PM
Here,s a tip for you Col scuff plates go on top of carpet
snigger snigger
#454 Bigfella237
Posted 02 December 2015 - 08:56 PM
This may have been mentioned earlier so I'll apologise in advance for not trawling back through the thread but...
What's with the tags Col, are they the factory tags just painted? They look cool!
#455 _Bomber Watson_
Posted 02 December 2015 - 08:58 PM
Would be easy enough to paint factory ones like that, but there prolly the laser engraved ones he mentioned earlyer.
cheers.
#456 Bigfella237
Posted 02 December 2015 - 09:03 PM
DOH, just went back one page and found that I'd already asked the same question!
~ Engraved ID tags ordered too. (National Engravers)
ALL of the mod plate guys i have spoken with refuse to put the mod plate in the boot. "Oh it has to go as close to the original tags as possible!"
So i am going to put the engraved tags in the engine bay & mount the stock tags in the boot. ~
#457 IMORAL
IMORAL
    Bored
  • 2,569 posts
  • Car:LX SS HATCH - IMORAL
Posted 02 December 2015 - 09:13 PM
Looks shit hot Col
#458 Statler
Posted 02 December 2015 - 09:20 PM
National Engravers. Robert there was very helpful. I sent him pics of our tags. He sent back samples. We done a couple of edits & BAM! :)
#459 Statler
Posted 17 January 2016 - 06:17 PM
No matter where i put that Holley reg it just didn't look good. I know looks over function is stupid, but the 'kit supplied' reg must be ok?
Out with the Holley & back on with the rising rate reg. Hey .... i made a custom 316 bracket for it! lol
Had the d/s fuel rail cut down about 1" & a -8 fitting welded on. Finger tightened the fitting on to it, went to tighten it & it went to butter! Hmmmmm .......
Had to cut the fitting off, reassess the plumbing & weld on another -6 fitting. Put in a 45deg M>F & it all plumbed up nicely.
Checked (again) for leaks, found none so ................
14 years in the build & she finally runs. :)
Still much to do but it is finally a step in the right direction.
Edited by Statler, 17 January 2016 - 06:18 PM.
#460 N/A-PWR
Posted 17 January 2016 - 06:20 PM
Great work Col,
and your Video is superb.   :spoton:  :clap:
#461 IMORAL
IMORAL
    Bored
  • 2,569 posts
Posted 17 January 2016 - 08:05 PM
Whooohoooo!!!
#462 Ice
Posted 17 January 2016 - 08:09 PM
Or there any oil in that engine
Is ^
#463 _Mox_
_Mox_
Posted 18 January 2016 - 07:31 AM
Good stuff Col, a lot of blood, sweat and tears, and its all worth it when you hear the engine fire.
#464 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 18 January 2016 - 09:31 AM
Big thumbs up Col.
Another line to rub off the whiteboard.
#465 Statler
Posted 29 January 2016 - 09:03 PM
10 yrs since the engine has ran Gene. Been wound over by hand every week since,  I primed the oil pump & wound it over on the starter until it finally had oil pressure to the top.  Then cranked the starter until it fired.
Yes it sounds 'dry'. & so it should. 10 years since fire up!
Still sounds better than anything you have posted since you joined the forums. JUst saying!
Need to sort out the fuel pressures still. I think the gauge is fried. It 'hunts' for idle until it is warm. I don't want to wind up the fuel pressure until i know what it is.
#466 Ice
Posted 29 January 2016 - 09:07 PM
Dont start Col
#467 IMORAL
IMORAL
    Bored
  • 2,569 posts
Posted 29 January 2016 - 09:43 PM
Dont start Col
Cant you read? He said it did start you silly sausage
#468 Ice
Posted 29 January 2016 - 09:53 PM
GF
#469 IMORAL
IMORAL
    Bored
  • 2,569 posts
Posted 29 January 2016 - 09:56 PM
Gluten Free?
WTF are you on about? Talk nonsense in the sandy thread and not Cols you goose ;)
#470 Statler
Posted 04 February 2016 - 06:59 PM
Still waiting on the fuel pressure gauge to arrive so i can set the pressure.
Bonnet release cable arrived so i can finish fitting the front panels.
Coming along nicely. :)
Pic of the boot install.
Just need to adjust the clutch & i can drive it out of the shed for a wash.
The only foreign sticker on the car is on the rear screen. Cheers Datto. :)
Edited by Statler, 04 February 2016 - 07:00 PM.
#471 Statler
Posted 12 February 2016 - 07:55 PM
Today it passed the blue plate inspection. :)
Edited by Statler, 12 February 2016 - 07:59 PM.
#472 _Bomber Watson_
Posted 12 February 2016 - 07:57 PM
Win..
#473 N/A-PWR
Posted 12 February 2016 - 08:02 PM
Work of Art Col.  :spoton:
#474 Ice
Posted 12 February 2016 - 08:09 PM
Good stuff Col that deserves a scotch or 7
#475 Statler
Posted 12 February 2016 - 08:25 PM
I like your train of thought Gene. :)
