Dirtbags dream car rebuild! HK monaro!
416 replies to this topic
#251 _dirtbag_
_dirtbag_
Posted 08 June 2011 - 09:48 PM
Hiya. Yeah I just ran it through the shrinker a bit more to get the curve I needed.
Hey Dirtbag, did you use a shrinker for the quarter panel or just english wheel or both??I would have to do the same with our Pontiac.
I used the panbrake to put the swage through the middle of the panel, then used the english wheel on the top half to get some crown, and the bead roller to put the lower swage in. The rest is just hammer and dolly and lots of yanking on the panel. To get the lower half in the correct curve I just reefed on the lower half of the panel while holding the middle of the panel down on a workbench. This gave me the twist in the panel it needed to sit flat on the car.
I hope that helps.
Oh, the answer is no, I didn't use the shrinker : )
#252 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 08 June 2011 - 10:04 PM
I hope that helps.
You're very talented mate thanks
#253 _dirtbag_
_dirtbag_
Posted 08 June 2011 - 10:18 PM
Talented - no, ugly - yes : )
Well I did a little bit more today.
I fully welded the new wheel well in and then made the lower edges to meet up to it.
Then I had the fun job if wire wheeling the rest of the inner guard so I could etch prime it all before welding the new guard on.
I also prepped the other guard repairs for etch primer, including the underside of the spare wheel well.
Then on with the etch primer.
I can't remember if I put these in earlier or not, but the front end is powder coated now.
Well that's it for now. I've been doing a fair bit of rust repair to a 55 kombi ute but I wont bother doing another VW thread, so there'll be a little while before my next update.
#254 _jabba_
_jabba_
Posted 08 June 2011 - 10:52 PM
Looking good :), should do something with that escort ;).
#255 _dirtbag_
_dirtbag_
Posted 08 June 2011 - 11:42 PM
I planned to build the escort with the big works rally flares and cool paint/roll cage etc just for some cheap thrills, but my brother might be interested in me building it for him instead. Whether he gets it or I build it for myself it will have big flares and big wheels : ) Oh, and stripes.
#256 GML-31
Posted 09 June 2011 - 05:50 AM
nice work Tim
#257 308 Sunbird
308 Sunbird
  • 976 posts
  • Name:Stuart
Posted 09 June 2011 - 10:43 AM
Awesome thread Dirtbag, have been following it from day one. I cant believe the ease in which you make your repairs look factory.The owner
(that is if you give it back) must be rapped in how thorough you are in making these repairs permanent.The only problem I've got now is that
I want a HK-T-G Monaro and I cant afford one! and I blame you for that.Keep up the great work.
Stuart
#258 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 09 June 2011 - 10:54 AM
Looks factory, cant wait till you weld the quarter.
Will you Oxy it or tig or mig??
Edited by Bart, 09 June 2011 - 10:54 AM.
#259 _dirtbag_
_dirtbag_
Posted 09 June 2011 - 06:19 PM
Well even though I've been putting most of my focus on the 55 kombi ute, I couldn't help myself from tacking the new quarter on.
First thing I did was get it into a position I was happy with, then tacked it on in a few places around the panel, making sure it was all sitting flat against the car.
I use a 1mm thick cutting disc to cut the small overlap off as I go around the panel tacking it on. I much prefer to butt weld panels together, rather than overlap them. I don't mind an overlap in floorpans for example, but not in panel like this.
I'm doing lots of little tacks, with the welder turned down pretty low, as I'll do the main welding with the oxy. The mig is really good for getting it into position though.
This just shows how easy it is to line up panels for butt welding when you cut along the edge of the outer piece with a 1mm cutting disc.
I'm really happy with how the new panel shaped up. Even though there are no welds holding the front of the guard in place it's still sitting nicely against the car.
More tacks.
It looks pretty good to me. Better than the old panel anyway.
That's all I did on it today, as the kombi is taking most of my time, but I'm pretty happy with how it's turning out.
#260 GML-31
Posted 09 June 2011 - 06:23 PM
looks great mate
#261 _dirtbag_
_dirtbag_
Posted 09 June 2011 - 06:27 PM
Thanks Kev : )
#262 _Bomber Watson_
Posted 09 June 2011 - 06:33 PM
Yep. I really need to come spend a week or two with you....
Hows next week?? Im on Holidays....
#263 _dirtbag_
_dirtbag_
Posted 09 June 2011 - 06:35 PM
Sure Bomber, I'll find something for you to do : )
#264 _Bomber Watson_
Posted 09 June 2011 - 06:43 PM
Peeee eemmm Sent
#265 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 09 June 2011 - 07:53 PM
Thats a reaaly nice job mate, even when you didnt tack the front as you said it was still in line with the rest of the original panel. Shows you got the shape right.
Oxy will make a nice clean flat weld.
Edited by Bart, 09 June 2011 - 07:54 PM.
#266 _dirtbag_
_dirtbag_
Posted 11 June 2011 - 04:30 PM
Well I did a little bit more fiddling on the monaro today. I used the mig to weld around the tail light, and where the lower part of the wheel arch joins on to the original wheel arch. Excuse the lousy pics lately, my camera died so I only have my phone.
Some more tacks along the underside as well. I still need to trim the lip under there, but at least it's tacked into position now.
Hopefully next week I'll be able to spend some decent time on it and get the welding done. Then I can start on the other side : )
#267 _Viper_
_Viper_
Posted 11 June 2011 - 04:50 PM
Amazing stuff Tim! there is hope yet for all the rusty damaged beasts out there, we will just send them to you.
#268 _cruiza_
_cruiza_
Posted 11 June 2011 - 06:03 PM
Great work Tim, have you ever thought about building a rotisery for doing this sort of thing
#269 _dirtbag_
_dirtbag_
Posted 11 June 2011 - 07:46 PM
Hi cruiza. A rotisserie would be really helpful with jobs like this, but the bonneville is going to be on there for a long time, so wont be able to get another car on it any time soon unfortunately.
If I wasn't such a poor bugger I'd get another one, but the house has wiped me out!!!!
#270 _judgelj_
_judgelj_
Posted 11 June 2011 - 08:13 PM
make one :)
#271 _dirtbag_
_dirtbag_
Posted 11 June 2011 - 08:25 PM
Seen the price of thick wall RHS lately? Plus, who has the time for that??? I'm behind enough as it is!!!! :sad:
#272 _Gunmetal LH_
_Gunmetal LH_
Posted 11 June 2011 - 08:49 PM
That new shed of yours with a strong roof, +2 block&tackles...
#273 _jabba_
_jabba_
Posted 11 June 2011 - 09:13 PM
I built my rotisserie for $140, i just asked the steel place if i could look at there offcuts and i managed to get some dirty thick steel and build one :). Not pretty but it works :).
#274 _judgelj_
_judgelj_
Posted 11 June 2011 - 09:15 PM
price can be done cheap but then again time is the biggest factor
#275 _jabba_
_jabba_
Posted 11 June 2011 - 09:20 PM
Yeah thats fair enough, my time is worth nothing. But doing these cars for a living i guess you cant waste a day building random shit.
