Dirtbags dream car rebuild! HK monaro!
#176
_DomDom_
Posted 11 May 2011 - 07:24 PM
Dom
#177
_shadowmaster_
Posted 11 May 2011 - 07:26 PM
#178
_DomDom_
Dom
Edited by DomDom, 11 May 2011 - 07:29 PM.
#179
Posted 11 May 2011 - 07:49 PM
Edited by GML-31, 11 May 2011 - 07:51 PM.
#180
_dirtbag_
Posted 11 May 2011 - 08:10 PM
Well done Tim... Did you make the half lower quarter as well as the top piece or just the top ? if you made the bottom as well then thats a hell of an accomplishment.
I was planning on doing that, but was put onto rare spares who supplied all the new outer rust repairs I needed. Yay rare spares : )
Having said that, the lower piece wouldn't have been too hard to make, but replacement panels are cheaper and easier hehehe.
Edited by dirtbag, 11 May 2011 - 08:12 PM.
#181
Posted 11 May 2011 - 08:48 PM
Good on you! It's easier to "tweek" a Rare's bit than to try and fab one.............even though you've got the gear.Yay rare spares : )
#182
_dirtbag_
Posted 11 May 2011 - 09:26 PM
#183
Posted 12 May 2011 - 11:56 AM
#184
_dirtbag_
Posted 12 May 2011 - 06:14 PM
#185
_red roar_
Posted 12 May 2011 - 08:05 PM
A retarded magician : )
I wish i was just as retarded......
Hey D/Bag, have you got any more pics of the green hatch, from one of your other threads, i looked but couldnt find it. From memory you said it was your mate's car? ( i need to drool some more)
#186
_dirtbag_
Posted 12 May 2011 - 08:32 PM
Here's some of the pics from my brothers hatch build thread.
Enjoy : )
#187
Posted 12 May 2011 - 08:42 PM
#188
_red roar_
Posted 12 May 2011 - 09:34 PM
i knew it was in that thread "somewhere", i just havnt got the three days it takes to get through it. lol
That's got a chev ?
#189
_dirtbag_
Posted 13 May 2011 - 12:13 AM
Just needs chrome bumpers and door handles : )
#190
_SnotGobbler_
Posted 15 May 2011 - 10:33 AM
i have a ques... you cover the bare metal with rust convertor. what do you do after that to remove the rust convertor?
at a guess you sand it off back to bare metal, then if surface rust still present, repeat process with rust convertor until all gone?
sanding with a block by hand or the grinder and with what grit approx? then cover with primer?
thanks heaps.. need to know for and idea of what to do when i get around to my torana doors
#191
_dirtbag_
Posted 15 May 2011 - 02:38 PM
I hope that helps.
Oh, in regards to there still being rust on the metal like this car had, I sand the bad bits with 36 grit discs on a grinder and reapply the rust converter.
#192
_dirtbag_
Posted 15 May 2011 - 02:41 PM
#193
_DomDom_
Posted 15 May 2011 - 07:39 PM
Sorry Dom I didn't answer your question. I'll probably end up fabricating a piece to replace the really pitted part over the wheel arch. I"ll have a bash at it first, but it looks like it might be easier to replace it.
Thanks Tim.
It looks very compounded, curves and flats, how does one make a panel like that. Better give us lots of pictures. ;-)
Dom
#194
_dirtbag_
Posted 17 May 2011 - 07:17 PM
I stuck some wax paper over the panel so I could draw on the outline to get a rough template for tracing onto steel.
I don't have the skills of Tom Peach to make an entire quarter from scratch, so will be leaving the bits that are still in good nick in place, such as the tail light surround.
With the paper cut to shape I taped it onto some 1.2mm zinc and traced it out.
This next shot shows some thick black texta lines through the middle of the panel. One is for where the crease is that runs down the side of the guard, the other is for the lower crease/step.
The reason for the texta lines is I used a pounce wheel to perforate the paper, so when I coloured over it the texta goes through the holes and marks the steel.
Once I cut the piece out, I stuck the template on the other side of the panel so I could mark the slight swage line that I need to fold. I have to fold it from the back side, that's why I'm having to do this.
Then I put the fold in. Now it looks like this. Note I haven't trimmed the bottom of the new piece yet. I'll do that when I'm happy with how the rest of it fits.
I then started running it through the english wheel. I started with a fairly flat bottom wheel as I don't want to put too much crown into the panel.
I also started hammering out the flare. It needs to come out further, as it's holding the panel away from the car at the moment, but I'd rather not go far enough with it than too far. It's easier to keep going than it is to undo.
Well that's all I got done to this one today, but it's a start.
Edited by dirtbag, 17 May 2011 - 07:19 PM.
#195
Posted 17 May 2011 - 07:28 PM
#196
#197
_dirtbag_
Posted 17 May 2011 - 07:32 PM
Awesome work dirtbag, you could make a monaro panel by panel.
hehehe. It's the only way I'll ever afford one, that's for sure : (
#198
Posted 17 May 2011 - 07:36 PM
I am frOckin impressed,DB.
Add me to the list and the rest of the forum members.
Great work!
#199
Posted 17 May 2011 - 07:40 PM
anyone good at fibreglassing?
i can see a big $$$ spinner in that
#200
Posted 17 May 2011 - 08:49 PM
