Plastic plugs for nose-cone badge
112 replies to this topic
#101 hanra
Posted 25 August 2020 - 02:31 PM
3D print would be the easiest option these days. Just need to scan an original.
#102 dattoman
Posted 25 August 2020 - 07:53 PM
Put me down for a set
#103 Shiney005
Posted 26 August 2020 - 09:20 AM
If you advertised those things you would sell a hundred sets in the first day.
From the 3D printed products I have seen, they always seem quite hard and brittle. The plastic has to be melted and then set again after all. I doubt that it could produce the plugs malleable enough to hold the pins.
#104 Balfizar
Balfizar
  • 499 posts
  • Name:Chris
Posted 19 December 2020 - 02:46 PM
What is the part number of this plug?  Is it uniquely Australian or a global GM part.  GM does not re-invent the wheel for a common application.  I have sources "GM" parts from USA, Brazil, Russia, Germany and the UK because they were Global, common, multiple use parts.
#105 hanra
Posted 19 December 2020 - 09:08 PM
SP2419
#106 Balfizar
Balfizar
  • 499 posts
  • Name:Chris
Posted 20 December 2020 - 11:20 AM
SP2419
SP - means standard Product,  that's a hint.
#107 hanra
Posted 20 December 2020 - 12:13 PM
I thought it was Standard Parts?
#108 Balfizar
Balfizar
  • 499 posts
  • Name:Chris
Posted 20 December 2020 - 01:18 PM
correction, Yes Standard Parts
Edited by Balfizar, 20 December 2020 - 01:23 PM.
#109 hanra
Posted 20 December 2020 - 02:20 PM
Can you see 2419 in there?
#110 Balfizar
Balfizar
  • 499 posts
  • Name:Chris
Posted 20 December 2020 - 03:40 PM
Unfortunately no,  This catalogue is an 1987 Olds, Buick,Pontiac,Chev and Cadillac.  So if it was not on one of these 2419 won't be in there.
i will check my obsolete parts catalogue to see if it had an "new" equivalent part number.
Edited by Balfizar, 20 December 2020 - 03:42 PM.
#111 hanra
Posted 19 November 2023 - 07:48 AM
5 years on. How did this turn out?
8 years on. How did this turn out?
This is the sample we have for development, we do not have any other update at this stage as to time etc. I should have further information within the next month on this project.
#112 Ando
Ando
  • 527 posts
Posted 19 November 2023 - 10:09 AM
I bought these 'push on badge retainer / sockets' on Ebay from bnsautosupplies. The small sockets are for 4mm hole & 2.2mm pins. I reckon they'll work.
Attached File  s-l1600 (1).jpg   390.07K   3 downloads
#113 Shiney005
Posted 19 November 2023 - 05:42 PM
Good stuff, and just in time for mine too.
