Fair enough,i only moved this one .060,but i will move it more and maybe angle mill a bit to get the valve away from the bore in the next rebuild.When you moved it .160 were you able to still us a race series head gasket or do u have to use a copper gasket.i try to keep overbore to a minimum and push the head over.
i moved it over .160".
yes mate getting there hopefully should be a bit quicker too.
202 "stroker" kits- opinions? +knifedged bmotor cranks
#101
_STRAIGHTLINEMICK_
Posted 17 August 2012 - 08:34 PM
#102
_STRAIGHTLINEMICK_
Posted 17 August 2012 - 08:40 PM
Was it the same comp with both heads?. .On yt alloy heads 060 " brings it down to around 47cc.I haven't got any specs from the 2 heads, but I know a 12 port is limited to around 280hp at the flywheel & the 9 port can be 300hp +. The 12 port ran a best of 104mph & the 9 port 105.5 using the same cam.
The alloy Yellaterra wouldn't be too bad a starting point if they made it with a 47cc chamber instead of the large chamber, as Bomber has already pointed out.
#103
Posted 17 August 2012 - 08:42 PM
#104
_STRAIGHTLINEMICK_
Posted 17 August 2012 - 08:49 PM
plenty left mate ,the 70cc and 56cc YT head is the same casting ,you chisel .100" off the 70cc to get 56cc ,a further .060 gets you about 47cc.Just get a syringe off the beach ,fill it with 47cc of cooking oil and squirt it into a 12 port chamber then measure from the deck to the top of the oil to work out how much to take off.Micki didnt think 060" off would take 6 1/2cc out of it??
Suppose it might.
How much deck is left on one of the "high comp" 12 port alloys?
#105
Posted 17 August 2012 - 08:52 PM
_STRAIGHTLINEMICK_
Posted 17 August 2012 - 08:55 PM
forms a what?Cant say i've heard of anyone doing it that way, doesnt the cooking oil form a meniscus which would give a false reading?
Posted 17 August 2012 - 08:59 PM
Mountains of molehills.
Edited by Heath, 17 August 2012 - 09:00 PM.
#108
Posted 17 August 2012 - 09:01 PM
Heath, looking at say water in a glass i would think the meniscus would be more than a couple of thou??
#109
Posted 17 August 2012 - 09:07 PM
And would cooking oil form a concave (like water) or convex (like murcury) shape??
I usually use ATF for ccing.....
#110
_STRAIGHTLINEMICK_
Posted 17 August 2012 - 09:09 PM
Yep it does do that at the edges but you can work it out well enough with a vernier to get the job done.A meniscus is an effect that occurs with liquid because of the surface tension, where at the edges of the fluid where it meets the solid surface (i.e. the walls of the combustion chamber) it actually reaches up the walls a little, theoretically throwing off your measurement. But I don't think it would be too detrimental to your accuracy DJ. Put a straight edge across the chamber and reach down into the middle with a measuring device. Close enough
Good enough for the bush I reckon.
#111
_STRAIGHTLINEMICK_
Posted 17 August 2012 - 09:15 PM
fair enough, but in the end after machining,if you fill the chamber with a perspex plate on top you will get the correct cc.And to add to that, i was under the impression that a meniscus was actually a concave or convex shape over the entire surface of the liquid, not just the edges, although the edges are more prominent generally.
#112
Posted 17 August 2012 - 09:20 PM
Good idea to get a rough guide though, never thought of that myself.
_STRAIGHTLINEMICK_
Posted 17 August 2012 - 09:22 PM
it can only be a few thou out mateCorrect, after machining and finding out its wrong lol.
Posted 17 August 2012 - 09:26 PM
My ccing gear is "within a cc" anyway
#115
_STRAIGHTLINEMICK_
Posted 17 August 2012 - 09:42 PM
All good,Hey Bomber ,have you heard of a cylinder head porter in Mackay named Steve Gay,he's old school aparently good with holdensSactly, like i sasid good idea for a guide.
#116
Posted 17 August 2012 - 09:43 PM
the alloy 12 port i had the chambers welded in had roughly .060 -.80 of the deck ( dont know the real reading as it had been effed with before i got it).
machine shop checked the thickness of the deck and said its already too thin and not to shave again, chamber came out at 47 cc after welding and porting.
i thought this was the reason they stopped selling the original closed chamber alloy YT's, because the squish pad was caving in.
even if you do get the compression up, they have no squish area.
#117
Posted 17 August 2012 - 09:49 PM
Mick, negative, might look him up though.
_STRAIGHTLINEMICK_
Posted 17 August 2012 - 09:54 PM
People have said they made small chamber version but i have never seen one,have you actually seen one.I did hear they had some chambers collapse on the earlier batch.they seem to have fixed it up with the last batch.Yep would be better with a good squish area.Do you know what the intake flow was on your head?still using race series gasket.
#119
Posted 17 August 2012 - 09:55 PM
#120
_STRAIGHTLINEMICK_
Posted 17 August 2012 - 09:58 PM
Are you using that head now?same as.
#121
Posted 17 August 2012 - 10:00 PM
was around 135cfm at 10 inch's IIRC, 340hp worth of air.
This head is on the Grumpy Humpy FX, photo in the fastest holden 6 thread.
Edited by greens nice, 17 August 2012 - 10:01 PM.
#122
_STRAIGHTLINEMICK_
Posted 17 August 2012 - 10:03 PM
thats good inake flow ,did you do anything radical to get itno i havent seen one with my own eye's, i have a yt book here with a part number for them though, they were called the "road racer" version, or something like that.
#123
Posted 17 August 2012 - 10:08 PM
nothing radical, just heavily ported.
#124
_STRAIGHTLINEMICK_
Posted 17 August 2012 - 10:14 PM
Thats a cool looking FX, Wow that must be an old YT catalogue mine only has the large chamber version.no i havent seen one with my own eye's, i have a yt book here with a part number for them though, they were called the "road racer" version, or something like that.
#125
_STRAIGHTLINEMICK_
Posted 17 August 2012 - 10:17 PM
That intake flow would help me ,Did you widen the port much?nothing radical, just heavily ported.
