202 "stroker" kits- opinions? +knifedged bmotor cranks
163 replies to this topic
#76 orangeLJ
Posted 16 August 2012 - 10:36 AM
G'day mate, Which rods and pistons do you have there,if you are unsure which way to go with the crank see if you can drive a car with a full weight crank,then drive one with a lightened crank,there is a difference. Or if you are near sydney i can take you for a drive,if you send down a crank we can knifedge it for you or grind it ready to use,mick
Custom JE forgies from the states (to suit our combo) H beams are custom again, but they are essentially a Honda H beam with a few differences.
Wish I could stretch to a JZED heads, but looking to spend some $$ on injection instead of running the 48mm dellortos. Just need to find someone that does a decent manifold (with good injector placement) and doesnt want to charge the world. I dont much like the idea of running weber manifold with aftermarket injection slapped on, kind of defeats the purpose (to me anyway)
Pics of your crank would be EXCELLENT Warren! and very much appreciated.
#77 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 16 August 2012 - 06:19 PM
A couple of months back at a private day. There is a low 13 in the car but can't be bothered chasing it :)
I am glad that you are on the forum as your experience is valuable and it's good to see someone still focussed on selling Red motor performance parts.
Haven't seen you at Repco North Parra for a while. Are you still there?
Thanks Craig , Not working at Repco anymore,There was a shitfight and i didnt need those muppets i, so i left and found a better job. I'm still enjoying doing the holden six stuff though.
#78 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 16 August 2012 - 06:32 PM
There HD8 carbs Mick, the HS8 has a hose from the bottom of the bowl to the carb, yours have the bowl fixed to the carb. I'm not using the 12 port head in this car now, it's in the UC 4 door with EFI on it at the moment,I've got a 9 port in it now.
The left is the HS8, the right is HD8.
Yep HD8 my type error, what performance differences did you find between red and blue heads.Do you know what the blue head flowed ? We seem to have found a limit with intake flow with 12 port heads.
#79 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 16 August 2012 - 06:41 PM
.120" is pretty damn thin in my eye's, is your block grout filled?
#80 _Bomber Watson_
Posted 16 August 2012 - 07:15 PM
How much have you got out of a 12 port Mick?
#81 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 16 August 2012 - 08:21 PM
It sounds thin but its ok in a n/a engine ,I definatley know of speedway engines with 3.720"bores and heard about others with 3.740".No mate my block is not grout filled..I've only ever seen bore problems on hp blocks bored .125" and that was from water jacket corrosion.I suppose the real reason for the bigger bore is to help unshroud the valves(also move the head across).Been toying with the idea of offset boring but havnt been game to do it. Hows the EH goin Kevin?
#82 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 16 August 2012 - 08:27 PM
about 300 airflow hp @.500", what are the figures from yours?
#83 _Bomber Watson_
Posted 16 August 2012 - 08:30 PM
Dont have one yet.
So your getting about 200cfm @ 28??
Nice, i'll add you to the list.
#84 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 16 August 2012 - 08:35 PM
Dont have one yet.
I will have to look up the actual figures.The 300 was a couple of years ago on a customers alloy head.The head on my fj was done over 5 years ago and flowed about 270hp
#85 _Bomber Watson_
Posted 16 August 2012 - 08:46 PM
Ah, thats about the usual 180cfm. Seems most head places can get that out of a cast 12 port.
No point sending 3-4 heads to NSW when theres a couple of local shops who have gotten the same results.
Edited by Bomber Watson, 16 August 2012 - 08:47 PM.
#86 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 16 August 2012 - 09:18 PM
Thats fine,i would get an alloy version if its available and within your budget, they only weigh about 13-14kg complete.
#87 _Bomber Watson_
Posted 16 August 2012 - 09:24 PM
Yeah, was thinking about buying a YT alloy,.
Problem is i have heard a few issues with chamber size being to big and apparenntlyl there a bit difficult to get the size down, they require welding apparently if you want any kind of compression.
#88 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 16 August 2012 - 10:28 PM
i try to keep overbore to a minimum and push the head over.
i moved it over .160".
yes mate getting there hopefully should be a bit quicker too.
#89 warrenm
Posted 17 August 2012 - 08:05 AM
I haven't got any specs from the 2 heads, but I know a 12 port is limited to around 280hp at the flywheel & the 9 port can be 300hp +. The 12 port ran a best of 104mph & the 9 port 105.5 using the same cam.
The alloy Yellaterra wouldn't be too bad a starting point if they made it with a 47cc chamber instead of the large chamber, as Bomber has already pointed out.
Edited by warrenm, 17 August 2012 - 08:05 AM.
#90 wot179
Posted 17 August 2012 - 08:22 AM
Tell me more about pushing the head across.
Do you offset drill the headbolt holes then press in sleeves?
#91 orangeLJ
Posted 17 August 2012 - 08:56 AM
would flycut, lump style pistons help with the compression issues in the 12 port (thinking out lound here?)
would obviously make it an inteferene engine, but could be worth the gains (lots of $$ on custom pistons though really)
Has anyone ever tried angle milling/angle decking a Holden six head ?
#92 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 17 August 2012 - 11:07 AM
i like this thread!
has anyone had any success with sleeving bores?
#93 Heath
Posted 17 August 2012 - 11:12 AM
Yeah I know a guy who has done moving the heads across and angle decking, both with reportedly positive results.
You only move it over a mm or two, I think you just slot the headbolt holes a little, no sleeves required and the bosses in the head are still okay, The locating device is just the dowels which you have to change - you just offset drill those in a larger size (on either or both the head and block) and use larger spigots/dowels.
Edited by Heath, 17 August 2012 - 11:13 AM.
#94 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 17 August 2012 - 06:40 PM
sure do.
re the lumpy's sure you could but you would be making the piston alot heavier. which is the last thing we want to do with a holden 6.
i could have moved it another 50" before i run into problem's. but the water jackets get awfully close to the flame ring.
i just set it up in a mill and elongated the holes, you have to cut into the tappet cover area a little bit so that the head stud washer's will seat.
fingers crossed it hasnt weakened the deck at all.
no need for sleeve's, there is no water to hit for a long way yet but you have to sort out some way of clamping the bolts in the intake port's.
you can no longer use a short allen headed bolt and the yella terra style post's wont cut it.
i think it was a well worth it effort, i struggle to get .550" lift with 1.7 inlet valves but now i can drop a 1.75 inlet down so far that you can see the collet groove poking in the port hehe.
if a little is good, more is better.
Edited by greens nice, 17 August 2012 - 06:41 PM.
#95 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 17 August 2012 - 06:58 PM
i just meant sleeve's as another way of strengthening the block?
#96 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 17 August 2012 - 07:06 PM
i was replying to wot, but no ive never tried it.
and heath i just made up some .160" offset dowels out of alluminium in the lathe.
Edited by greens nice, 17 August 2012 - 07:08 PM.
#97 wot179
Posted 17 August 2012 - 07:17 PM
So how did you go about clamping in the intake ports?
Mine are hogged right out,no posts.
#98 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 17 August 2012 - 08:00 PM
havent done it yet but i reckon contouring the top and bottom of the tube to suit the port shape and having it tap in from the manifold side might do the job.
#99 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 17 August 2012 - 08:18 PM
If you use flatops and 0 deck and .060" off head then comps of 11 to 1 easy
#100 _Bomber Watson_
Posted 17 August 2012 - 08:24 PM
i didnt think 060" off would take 6 1/2cc out of it??
Suppose it might.
How much deck is left on one of the "high comp" 12 port alloys?
