* * * * * 4 votes
LX GTR Hatch
turbo awd
817 replies to this topic
#501 _Bomber Watson_
Posted 08 April 2017 - 09:32 PM
Lol, what can you expect, its a video magazine, the writers dont know the first thing about cars.
#502 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 09 April 2017 - 08:01 PM
I had a look at that VL on youtube, it's a fair effort to build it in one year but I would like to know if its been engineered.
#503 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 14 April 2017 - 08:42 PM
Gave the drive shafts a clean up and some paint.
Attached File  IMGP3397_resize.JPG   142.8K   7 downloads
Removed some of the lip on the fire wall and fully seam welded it.
Attached File  IMGP3396_resize.JPG   131.84K   10 downloads
Added some more strengthening to the front suspension towers to make sure the load is transferred back to the rail where the original subframe mounted.
Attached File  IMGP3398_resize.JPG   127.5K   7 downloads
Edited by turbo76lx, 21 October 2017 - 04:15 PM.
#504 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 07 May 2017 - 08:10 PM
Have contacted a few engineers to see if they were interested in taking on the project. I've chosen one, now I have to reassemble the car
so he can see where it's at and where to move forward from here. Hopefully he will look at it in a few weeks.
Attached File  IMGP3419_resize.JPG   142.38K   10 downloads
Attached File  IMGP3426_resize.JPG   140.6K   8 downloads
Attached File  IMGP3434_resize.JPG   144.01K   10 downloads
Edited by turbo76lx, 21 October 2017 - 04:16 PM.
#505 bullitA9X
bullitA9X
  • 4,168 posts
Posted 07 May 2017 - 08:47 PM
Absolutely love your work mate this car is awesome....
#506 gtrboyy
Posted 07 May 2017 - 11:59 PM
Last I heard it's still registered as a commodore whatever that means.
Greenslip check will tell if engineered etc
#507 _imj411_
_imj411_
Posted 08 May 2017 - 01:16 PM
Looks awesome, I would drive it like that. Just put on a helmet to stop the wind, cheers Aaron.
#508 _Romper_
_Romper_
Posted 18 May 2017 - 08:00 PM
did you end up getting a reply from bonneville mate ? who is the new engineer you have in mind ?
#509 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 18 May 2017 - 09:48 PM
After a week Bonneville replied to my email. I'm going to get Peter Turner from Teched Australia to have a look at it on the 29th.
#510 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 29 May 2017 - 06:52 PM
Had the engineer, Peter Turner  http://www.techedaustralia.com.au/ have a look at the project.
He is happy with what has been done, he wants an extra brace between the rear suspension towers and I
have to have retractable seat belts for the outer back seats. The car will have to pass the IM240 emission test
and also have a torsional rigidity test. The plan now is to get the car ready for the torsional test then
start the panel work.
Rear seat belts something like this.
Attached File  IMGP3441_resize.JPG   123.59K   9 downloads
Edited by turbo76lx, 21 October 2017 - 04:18 PM.
#511 Bigfella237
Posted 29 May 2017 - 07:27 PM
I haven't looked at the regs but it's interesting that retractable rear seat belts are required, although I was thinking about doing the same anyway so watching with interest.
Doesn't the inertia reel part have to be designed for a certain range of mounting angle? And did he give you any guidelines as to how the inner quarter would need to be reinforced to an acceptable standard for mounting the reel?
Another question, does Peter have a set of standard Torana or generic minimum results for beaming and torsion tests? I thought the actual car had to be tested prior to any mods to establish a baseline for final testing... a 'so long as it's as good as it was when you started' kinda deal?
I was thinking about making my own test rig but the thought of buying a dozen-odd dial indicators is a little off-puting...
#512 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 29 May 2017 - 08:37 PM
Peter said the seat belts needed to be upgrade because of the power increase. APV-S seat belts make different reals
that work at different angle. http://www.apvsafety...pose-seat-belts
I don't know if he has any torana standards for the torsion test he may just use the 4000Nm per degree for ICV's.
He had no doubts it would pass.
#513 myss427
myss427
  • 1,636 posts
Posted 30 May 2017 - 10:29 AM
Great to see it going forward!
#514 _Bomber Watson_
Posted 30 May 2017 - 06:53 PM
Ditto, awesome news.
#515 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 12 June 2017 - 08:18 PM
Made up some bars to replace the coilovers for the torsion deflection testing. Hopefully will get the test done in a few weeks.
Attached File  IMGP3443_resize.JPG   143.59K   7 downloads
Attached File  IMGP3445_resize.JPG   103.55K   6 downloads
Edited by turbo76lx, 21 October 2017 - 04:19 PM.
#516 Heath
Posted 13 June 2017 - 10:58 PM
If you're replacing the coilovers with those solid struts, I'd at least try and install some bushes up the top for some better compliance. Ride quality might be a bit poor.
Love your work mate!
#517 Bigfella237
Posted 13 June 2017 - 11:30 PM
Hmm... not sure whether that was a serious suggestion or tongue-in-cheek Heath? The solid struts/spring eliminators are only used for the beaming and torsion tests, you need to eliminate any suspension movement (including tyres) so you can accurately measure how far the body flexes under the various loads.
#518 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 14 June 2017 - 06:06 AM
Heath is always serious  :P but it would be fun to see how it handled on a skid pan with these in.
#519 Heath
Posted 14 June 2017 - 11:47 PM
Appreciate the clarification, although it was not necessary.
#520 _LS1 Taxi_
_LS1 Taxi_
Posted 15 June 2017 - 03:34 PM
Glorious fabrication.
#521 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,429 posts
  • Name:facebook dave
Posted 15 June 2017 - 08:46 PM
stunnung work glen
hpoe it all goes to plan from here on
so looking forward to the finnished result
#522 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 25 June 2017 - 08:15 PM
Decided to mount the seat belt reel besides the back seat so they don't stand out as much.
Attached File  IMGP3454_resize.JPG   108.03K   13 downloads
Ground up a piece of flat bar to match the shape of the panel.
Attached File  IMGP3451_resize.JPG   126.21K   11 downloads
Will also weld this comp plate over the outside when the engineer gives me the ok.
Attached File  IMGP3455_resize.JPG   115.68K   13 downloads
Also made up some panels for the back out of some aluminium that i'll cover with some vinyl.
Attached File  IMGP3449_resize.JPG   123.73K   6 downloads
Edited by turbo76lx, 21 October 2017 - 04:21 PM.
#523 RallyRed
Posted 25 June 2017 - 08:28 PM
in the previous 21 pages...I'm sure someone has already  told you that you are a genius....but, .....you are a genius!!  Love your work
#524 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 25 June 2017 - 08:32 PM
No genius here, I just know how to weld and hammer things into place.
#525 SmacT
  • 1,026 posts
Posted 25 June 2017 - 11:18 PM
Yep ^^ genius. :-)
