* * * * * 4 votes
LX GTR Hatch
turbo awd
817 replies to this topic
#526 Ice
Posted 25 June 2017 - 11:27 PM
No genius here, I just know how to weld and hammer things into place.
No thats bloody skill
love this build
#527 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 12 September 2017 - 08:47 PM
Had the beam and torsional test done today. The engineer now needs to graph the results to check if it passed but it looks good.
#528 hanra
Posted 12 September 2017 - 09:02 PM
What exactly is involved with that test?
#529 Bigfella237
Posted 12 September 2017 - 09:32 PM
Interesting, I'm really surprised he tested the bare body shell.
I know all opening panels (if fitted) have to be ajar during testing but I would've thought the front end panels would lend some strength to the front chassis rails, plus an engine and trans should help tie everything together, and even the glass is structural in some cars? Still I suppose if it passes without those fitted then it should only be stronger when they are?
Did you need to make some weight allowance for all the missing stuff? There is roughly 1000kg difference between a shell and a complete car after all!
#530 Bigfella237
Posted 12 September 2017 - 09:50 PM
If you're interested Brad, here's some light reading for ya...
https://infrastructu...1Jan2011_v3.pdf
Pretty much the entire first half of this document (section LT1) covers beaming and torsion testing.
#531 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 12 September 2017 - 10:01 PM
The beam test was all 4 wheels on the stands 6 dial indicators along each side of the car and load 135kg into each
passengers seating position and record the results.
The torsional test, the rear wheels are fixed down, a beam is attached to the front wheels with a pivot point between the
wheels to the ground and weight is applied to the beam to twist the car with 6 dial indicators along each side of the car.
#532 rodomo
Posted 12 September 2017 - 11:30 PM
Did it pass?
#533 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 13 September 2017 - 08:18 AM
Will be a few days until the engineer can graph the results and see if it passed but the results look good.
#534 myss427
myss427
  • 1,636 posts
Posted 13 September 2017 - 09:50 AM
My test was very similar, but I had to have the driveline in? With the car so light would it move much? or does he calibrate that to the movement?
#535 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 27 September 2017 - 07:40 PM
Started fixing the rust in the tail light bucket.
First had to get dogs ok on the tail light bucket from the spare parts car.
Only going to replace the bottom half but had to do a small repair first.
Had to repair some rust in the corner.
Bottom replaced.
#536 bullitA9X
bullitA9X
  • 4,168 posts
Posted 28 September 2017 - 11:06 AM
Nice work as usual mate love this build 😁😁
#537 Peter UC
Peter UC
  • 771 posts
Posted 28 September 2017 - 01:00 PM
Have you got your results yet? I want to know the results.
#538 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 28 September 2017 - 08:43 PM
Yes Pete I got the result today and it is all good.
This is part of the report.
The following details apply to the subject vehicle:
. GVM assessed by calculation to be 1700 kg.
. Front track was 1470 mm.
. Turning moment was 6240 Nm.
. Torsional rigidity was calculated to be 12489 degrees/Nm.
. Beaming deflection with an imposed load was measured to be 0.74 mm.
#539 _Bomber Watson_
Posted 29 September 2017 - 06:29 PM
Should that be 12489 nm/degree?
Im strugglign to get my head around it the other way.
#540 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 29 September 2017 - 07:53 PM
Yes I think that's what it means, I know the weight that was applied worked out to 6240nm which twisted the car only 0.5 deg.
Fixed some more rust fixed under the hatch seal channel and fitted a replacement channel.
Decided to put it back on the rotator to make it easier to start fixing some of the rust and dints in the body.
#541 _LS1 Taxi_
_LS1 Taxi_
Posted 29 September 2017 - 10:31 PM
frOck me.
The underside of that thing is horn.
The shame is that dudes not familiar with Torana’s won’t appreciate what’s been done. It’s so neat they’ll just think
It’s an engine conversion.
A credit to you.
#542 _Bomber Watson_
Posted 29 September 2017 - 10:56 PM
As above.
#543 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 02 October 2017 - 08:42 PM
Mmmmmmm sun roof.
Only kidding just re-doing the sun roof patch, I rushed it the first time and got a little to much distortion.
#544 _Bomber Watson_
Posted 02 October 2017 - 08:59 PM
I would leave it in hahaha.
#545 _LS1 Taxi_
_LS1 Taxi_
Posted 02 October 2017 - 09:26 PM
Holy shit.  I thought I'd clicked on Heaths build thread for a second....lol
I'd leave it in too.
#546 Ice
Posted 02 October 2017 - 09:35 PM
Sunroofs are cool again arnt they
#547 Peter UC
Peter UC
  • 771 posts
Posted 03 October 2017 - 11:46 AM
Results aren't too bad, at 12,489 Nm/degree the stiffness is roughly was cars around the late 90s early 00s were. I'd imagine a standard Torana would be around 6000Nm/degree?
#548 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 03 October 2017 - 05:36 PM
Pete I think a standard torana  is a bit below the 6000 nm/deg.
Here's a link to a few other cars torsional rigidity.
http://beautifullyen...-of-known-specs
http://youwheel.com/...rehensive-list/
#549 _Bomber Watson_
Posted 03 October 2017 - 07:51 PM
Does anyone else find it amusing that a Daewoo Lanos has more Torsional rigidity than a Ferarri 355, three times as much as a BMW Z3 and four times as much as a Lambogini Countach?
#550 Peter UC
Peter UC
  • 771 posts
Posted 04 October 2017 - 11:50 AM
You're probably right hence the question mark. Toranas are pretty good for their age however and I reckon they would be better than an old Ford Maverick at 4400, they were basically an old Ford Mustang structure.
Having said that the Torana sedans would be better than the hatches though
Edited by Peter UC, 04 October 2017 - 11:51 AM.
