The Marty Report
LJ GTR Build
1095 replies to this topic
#126 _Quagmire_
Posted 29 June 2013 - 08:38 PM
breaking bad is addictive lol :P
#127 Ice
Posted 29 June 2013 - 10:03 PM
Keep plugging away at it marty looks like this car will be a1 when finished looking forward to the end product
gene.
#128 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,429 posts
  • Name:facebook dave
Posted 30 June 2013 - 09:24 AM
yep!
heard that second hand RV's with allterrain tyres
and long range fuel tanks are fetching a premium price
here in w.a
great show that!
#129 Potta
Posted 30 June 2013 - 05:30 PM
Yeah I think it is American Restoration Gong, its on 7 Mate now too on Monday Nights.
The name of the shop is Ricks Restorations.
Restores some awesome old stuff including motorbikes, coke machines, old railway machinery and pretty much whatever people bring in.
They quite often use walnuts for stuff like solid rubber tyres to take the top layer off if they can't get replacements, and soft metals and plastics.
#130 sibhs
Posted 02 July 2013 - 10:43 PM
Finally finishing off some work I started months ago. My mission has been the driver sill which has had heeeaps of work in getting it right.  I don't now how everyone else gets this right unless you have a NOS or expensive sill replacement panel.
Mines a standard locally made unit which needed splitting and spreading, 5mm strip welding to lower edge and the front end cowl made and fitted.  Very happy with the result, I would say close to perfect.
Attached File  IMG_2822.jpg   44.04K   33 downloads
Attached File  IMG_2825.jpg   65.21K   29 downloads
Attached File  IMG_3012.jpg   46.17K   29 downloads
Needed a bit of persuation to get the sill straight, got a bit of a bend in it when I welded a 5mm strip on the bottom to match original.  Once fitted it was all hit with the three step KBS system then a bit of primer.
Attached File  IMG_3114.jpg   41.9K   30 downloads
Attached File  IMG_3115.jpg   49.36K   30 downloads
Attached File  IMG_3141.jpg   40.28K   30 downloads
This shows a standard sill and mine with the 5mm strip.
Attached File  IMG_3107.jpg   57.47K   30 downloads
Had this section above the hinge mount which looked dodgy from where the guard was replaced, I ground back some welds, knocked the metal closer and welded a 5mm strip across the top to match original. Would look better with a bit of primer.
Attached File  IMG_3083.jpg   54.62K   31 downloads
Attached File  IMG_3130_2.jpg   57.27K   33 downloads
Cut out some bits from the window. Struggled with how to cut the short side so just used a small drill, cold chisel and file. Worked out ok.
Attached File  IMG_3134.jpg   55.85K   33 downloads
Attached File  IMG_3135.jpg   49.08K   32 downloads
Attached File  IMG_3136.jpg   51.6K   33 downloads
I must admit, i have used a patch repair.........I just couldn't bare to cut out the dash to gain access to the area of the plynum chamber. So I ground the metal around the hole, welded the patch then the KBS system. Later I will apply sealant around edges from inside the chamber.
Attached File  IMG_3123.jpg   66.25K   37 downloads
Attached File  IMG_3124.jpg   53.5K   32 downloads
Attached File  IMG_3125.jpg   57.9K   33 downloads
Ground back the welds on the shock mount.
Attached File  IMG_3109.jpg   35.89K   33 downloads
Got another wiper motor and used the electrical connector and cog from it.
Attached File  IMG_3098_2.jpg   53.82K   33 downloads
Attached File  IMG_3101_2.jpg   49.24K   32 downloads
Attached File  IMG_3105_2.jpg   48.72K   33 downloads
#131 N/A-PWR
Posted 03 July 2013 - 02:22 AM
Cool work Marty,
You must think, not another rust hole, after fixing the last one. Dave I
#132 sibhs
Posted 03 July 2013 - 08:57 AM
Hi Dave, yeah, just found a few more holes under the dash and into the chamber. These I can cut and fit new metal. Seems like a never ending task especially since I consider this to be a good clean shell. I've just used my first bottle of gas and 5kg wire. I'll do a gas swap today. Cheers, Marty
Edited by sibhs, 03 July 2013 - 08:58 AM.
#133 Potta
Posted 03 July 2013 - 09:17 AM
At least you're getting plenty of practice for the next one  :spoton:
#134 sibhs
Posted 05 July 2013 - 08:58 PM
Got some of the sh!t jobs done this week thanks to my recovery time off work.
First up is the rear drip rail, had a few suspicious lumps under it so cut it out to find rust in both layers.  Cleaned it up and gave it the rustblast treatment then started putting the layers back.  Used the original drip rail and welded a new strip to it. Ran a crease down the middle to look original.
Attached File  IMG_2929.jpg   40.54K   34 downloads
Attached File  IMG_3161.jpg   49.57K   35 downloads
Attached File  IMG_3162.jpg   42.75K   36 downloads
Attached File  IMG_3168.jpg   72.07K   35 downloads
Attached File  IMG_3176.jpg   39.85K   35 downloads
Started the last sill, split it down the guts to get the taper and then welded a 5mm strip to the bottom.  This strip welding alway causes a bend in the sill so to fix this I cut a slit in the lower vertical and she springs back into shape.
Attached File  IMG_3154.jpg   52.55K   39 downloads
Attached File  IMG_3155.jpg   59.6K   36 downloads
Attached File  IMG_3179.jpg   52.83K   36 downloads
Attached File  IMG_3177.jpg   61.04K   38 downloads
Attached File  IMG_3180.jpg   58.14K   35 downloads
Attached File  IMG_3184.jpg   51.18K   36 downloads
I came up with the idea to use an old sump to make the cowl end, so-far it's looking good and has been easier than making from scratch. Stay tuned to see how it finally looks.
Attached File  IMG_3173.jpg   71.8K   38 downloads
Attached File  IMG_3191.jpg   45.27K   38 downloads
I've had this rust area in the boot/wheel arch which I was struggling to cut some metal to fit the space..  Another brain wave, using builders damp course (bitumised aluminium) I cut a piece and moulded it to the shape required for a template.  Then back to the sump and using the template I find the best curved area for the job. Cut it out and massage it into shape, problem solved.
Attached File  IMG_3188.jpg   47.14K   35 downloads
Attached File  IMG_3189.jpg   51.71K   34 downloads
Attached File  IMG_3190.jpg   69.42K   33 downloads
Again stay tuned for the outcome.
#135 sibhs
Posted 14 July 2013 - 09:44 PM
Progress has slowed since I've been back at work but most importantly we still have progress.
Repaired the rear boot catch support by fitting new metal to tank support then bending up a piece for the upright. It's cool what bits you can make with a hammer, vice and a few scrap bits of metal bar for bending over.
Attached File  IMG_3205_2.jpg   48.66K   37 downloads
Attached File  IMG_3210.jpg   49.56K   39 downloads
Got stuck into the rust around the rear window which was just a series of holes in three areas.
Attached File  IMG_3207.jpg   52.7K   32 downloads
Test fitted the rear seal to check fit.
Attached File  IMG_3225_2.jpg   52.28K   32 downloads
That little repair to the wheel arch using a piece of sump came out great.
Attached File  IMG_3215.jpg   40.14K   31 downloads
Welded the spare wheel fitting back using previous photo's for a guide.
Attached File  IMG_3218.jpg   57.94K   32 downloads
Put the passenger door back on to check the sill and lower fender alignment.
Attached File  IMG_3220.jpg   44.41K   31 downloads
Seam sealer added to inside the guard.
Attached File  IMG_3223.jpg   41.69K   30 downloads
This is my chassis repair section with the crush tube I added to it.
Attached File  IMG_3228.jpg   66.24K   30 downloads
L/H front fender repair section I made.
Attached File  IMG_3229.jpg   57.04K   29 downloads
Next update we'll have some flutes in.  The body is almost rust free with just a few sections to weld in, then the doors need work.
#136 N/A-PWR
Posted 14 July 2013 - 09:49 PM
Great Metal Work Marty,
Rust Free sounds good. Dave I
#137 Potta
Posted 14 July 2013 - 11:11 PM
Looks like you're learning a few tricks along the way Marty.
Great to see you still getting stuff done.
#138 ribz0
ribz0
  • 512 posts
  • Name:Eric
Posted 15 July 2013 - 02:26 AM
Hey Marty.... WOW!!! you are getting into it mate!!! and doing a great job!!
Keep the pics and updates coming mate... Id love to catch up and have a good look!!
#139 sibhs
Posted 15 July 2013 - 07:37 PM
Hi Eric,
Yeah PM me and we can organise something.
For a bit of a laugh you can watch me fit my first flutes.  I can now see how people get them in the wrong way, easily happen.
Very happy with the result, this took about two hours.
#140 lxsstorana
lxsstorana
  • 2,499 posts
  • Car:SS Hatchback
Posted 15 July 2013 - 08:34 PM
Nice metal work Marty. :spoton:
Also watched the video and gotta say you move quick.
#141 sibhs
Posted 25 July 2013 - 10:13 PM
Thank's Mick, thats one frame taken every 10seconds. I'm not really fast. :-)
Evening all,  for those that didn't view the vid, heres some pics of the flutes and lower guard fitting.
Firstly I positioned the splash guard, this helped get the lower fender on the right angle and position.
Attached File  IMG_3231.jpg   46.38K   38 downloads
Then it's a slow process of tack welding it all together.
Attached File  IMG_3233.jpg   45.41K   38 downloads
Attached File  IMG_3234.jpg   39.92K   36 downloads
Attached File  IMG_3235.jpg   41.27K   32 downloads
Attached File  IMG_3237.jpg   40.68K   34 downloads
Attached File  IMG_3260.jpg   39.56K   31 downloads
Fitting this chassis repair has proved challenging, getting the hole in the correct place is the hard part. I tried using a steel rod through the holes but they don't all line up, it's too hard to explain in writing but I think i've sussed it out and have tacked it in place and will next test fit the K-Frame.
Attached File  IMG_3242.jpg   56.4K   36 downloads
Attached File  IMG_3264.jpg   47.12K   34 downloads
My sump end worked but was a lot of work and not as good as the other side.
Attached File  IMG_3259.jpg   59.64K   34 downloads
Edited by sibhs, 25 July 2013 - 10:19 PM.
#142 sibhs
Posted 04 August 2013 - 10:50 PM
Time to find out what's going on with these seats. Stripped them down to reveal LJ seats with a welded headrest. Once the head rest is cut off I'll need some springs added, sand blasting, painting then off to the trimmers. Attached File  ImageUploadedByTapatalk1375620121.466479.jpg   77K   35 downloadsAttached File  ImageUploadedByTapatalk1375620152.516622.jpg   80.05K   31 downloads
The runners are removed and cleaned, checked in position. One is missing a piece of the foot which I'm making a bit for. Attached File  ImageUploadedByTapatalk1375620288.666690.jpg   90.46K   32 downloadsAttached File  ImageUploadedByTapatalk1375620314.399686.jpg   75.56K   34 downloads
Test fitted the kFrame before welding chassis repair. Fitted well. Attached File  ImageUploadedByTapatalk1375620346.666278.jpg   83.23K   37 downloads
Got some goodies for painting.
Attached File  ImageUploadedByTapatalk1375620432.016917.jpg   98.28K   35 downloads
Cut out the sections for Stonetray and test fitted.
Attached File  ImageUploadedByTapatalk1375620534.066141.jpg   95.64K   34 downloads
Edited by sibhs, 04 August 2013 - 10:53 PM.
#143 sibhs
Posted 11 August 2013 - 10:58 PM
Welded the repair to seat runner. Attached File  ImageUploadedByTapatalk1376225407.717064.jpg   89.15K   33 downloadsAttached File  ImageUploadedByTapatalk1376225502.034150.jpg   88.66K   36 downloadslast of the flutes is in so that's almost all the hard stuff done. Attached File  ImageUploadedByTapatalk1376225647.199710.jpg   81.09K   37 downloadsChassisrepair finished. Attached File  ImageUploadedByTapatalk1376225697.799992.jpg   75.5K   36 downloadsUsing some dampcoarse I folded up a template to make the chassis supports. Once these are made there not much before it gets some paint. Marty
#144 N/A-PWR
Posted 13 August 2013 - 12:05 PM
G'Day Marty,
Again you have shown how commitment can produce instant results ( Marty's Robot Works Video ),
also you keep a very clean Workshop as this sort of Work produces a lot of Carbon and can get out of control hey.
The LJ headrest was dodgy looking as in an Accident those two vertical rods could snap off and spear your neck, ouch.
Good thing you got rid of them. Regards Dave I
#145 Ice
Posted 13 August 2013 - 11:41 PM
I reckon you got a bit of priming and shit loads of sanding ahead of you before you even think about paint ha ha ha ha ha true
keep up the good work marty im very impressed with your skills
think i just found my new panel beater
#146 sibhs
Posted 13 August 2013 - 11:54 PM
Hi Gene, yeah, when I say paint I mean etch, when I get close to final coat I'll say COLOUR. Marty.
#147 Ice
Posted 14 August 2013 - 12:05 AM
Ok cant wait to see colour i bet
#148 Potta
Posted 14 August 2013 - 01:00 AM
This thing is flying along Marty, you should be proud of what you've achieved so far.
Can't wait to go crusin together.
#149 sibhs
Posted 14 August 2013 - 09:26 AM
Gene, ill be very happy just to see etch. Hi Craig, thanks. Cruising is still a dream away but hoping things speed up once I start the paint prep. Must be painted before April. Where's your GTR at? You need a thread with updates. Marty
Edited by sibhs, 14 August 2013 - 09:27 AM.
#150 Potta
Posted 14 August 2013 - 10:06 AM
Haha, when there are updates I'll put them up  :blush:
A few factors are contributing to it not getting sorted as quickly as I'd like, but it is really only a good days work away from being ready for rego.
My main problem is a seat dilemma, but I'll work it out.
