The Marty Report
LJ GTR Build
1095 replies to this topic
#101 N/A-PWR
Posted 05 May 2013 - 01:41 PM
This download shows 2 of them:- http://www.gmh-toran...attach_id=29729
and the reason for the Post Link was that is where the Download Link was attached sorry
Edited by TORYPOWER, 05 May 2013 - 01:52 PM.
#102 71xu1
71xu1
    Dave
  • 1,278 posts
  • Car:LC GTR XU1
Posted 05 May 2013 - 05:41 PM
Rubber grommets are for attaching the number plate light bracket to bumper bar.
#103 N/A-PWR
Posted 05 May 2013 - 06:28 PM
Excellent Dave,
Here is the Rare Spares List # and Link:-
http://www.rarespare...product=2817531
#104 sibhs
Posted 05 May 2013 - 11:08 PM
Thanks Daves,
I knew I'd seen them somewhere but when they came in a firewall kit, it threw me.
#105 sibhs
Posted 15 May 2013 - 11:10 PM
This week saw the floor pan fitted, all butt welded and ground to give the factory look when finished.
Attached File  IMG_2897.jpg   55.64K   39 downloads
Attached File  IMG_2898.jpg   54.01K   46 downloads
I had this area where it didn't quite fit so I cut a slit, bent into position and welded.
Attached File  IMG_2863.jpg   27.23K   40 downloads
Attached File  IMG_2864.jpg   45.37K   40 downloads
Not much change from a distance but slowly things are happening.
Attached File  IMG_2852.jpg   53.27K   40 downloads
Painted a few bits on the week-end, all primed and 2K satin black, pretty happy with finish.
Attached File  IMG_2872.jpg   49.63K   40 downloads
Attached File  IMG_2874.jpg   71.87K   40 downloads
Attached File  IMG_2880.jpg   44.65K   41 downloads
Sorting out the bits for zincing, some will be gold and most silver.  I'm using these photos to help me work out what they're for when I get them back in a box all mixed up.
Attached File  IMG_2879.jpg   70.37K   45 downloads
Attached File  IMG_2891.jpg   61.86K   45 downloads
Anyone know where I can get this profile rubber, I've tried Clark Rubber so far with no luck. Goes inside the front guards near the headlights.
Attached File  IMG_2894.jpg   42.77K   42 downloads
Attached File  IMG_2896.jpg   38.9K   40 downloads
Pulled the wiper motor apart and found the gear to be cracking and a copper tab Broken off, I've started another thread on hopefully getting this sorted.
Attached File  IMG_2882.jpg   53.09K   40 downloads
Attached File  IMG_2884.jpg   64.68K   42 downloads
#106 lc2dr
lc2dr
  • 320 posts
  • Name:Jeff
  • Car:LC 2dr
Posted 24 May 2013 - 09:11 PM
Hey Marty,
I just read through this from start to finish and I must say I'm impressed - awesome work! :clap:    I'll be watching this with interest.
As you said, you get more confident as you go along and skills develop - keep it up.
Jeff
#107 sibhs
Posted 24 May 2013 - 10:32 PM
Thanks Jeff, great to have you onboard.  Yes, confidence is high and looking forward to the challenges ahead.
Sent some parts off for zincing and got them back this morning.  This lot cost $50 and took 3 days, much cheaper than chroming so I'm getting all the bits & bobs done, just putting together the next batch at the moment.
That bonnet clasp thingy was quite rusty so I chucked it in molassis for a week and it came up a treat, the rust pitting still shows but thats hidden under the nose cone. If rust is in a visible area I would sand it smooth before plating if you want a top looking job.
Before
Attached File  IMG_2922.jpg   63.22K   46 downloads
Attached File  IMG_2923.jpg   47.54K   41 downloads
They have been plated the same colours they were on this car, presuming they are original, some gold and the rest silver.
After
Attached File  IMG_2936.jpg   46.34K   36 downloads
Attached File  IMG_2937.jpg   58.09K   38 downloads
Attached File  IMG_2938.jpg   59.98K   39 downloads
Spun the car and did some more paint removal on the passenger rear, this side had few small bog repairs that i'd like to dolly out later.
Attached File  IMG_2933.jpg   42.14K   40 downloads
Now the weather is cooling, the surface rust has appeared so I'm on a mission to get the etch on in the next few weeks. Concentrating on sandblasting all the edges of panels, engine bay and even the underneath, once sandblasted it gets rustblasted then on a warm afternoon I'll epotec it.
Attached File  IMG_2918_2.jpg   40K   42 downloads
Attached File  IMG_2919.jpg   41.74K   40 downloads
Attached File  IMG_2932.jpg   45.5K   41 downloads
#108 N/A-PWR
Posted 24 May 2013 - 10:41 PM
Excellent maneuver Marty,
Silver and Gold is the Treat. Dave I
#109 _LONA-CK_
_LONA-CK_
Posted 25 May 2013 - 05:39 AM
looks great marty and you bits come up really good to, just some advice when sending off your bits to zinc coatters  make a list of what you are given them and then make sure thay do a check off  because there will come a time when they will loose the most importen things
cheers gong
#110 _Agent 34_
Posted 25 May 2013 - 06:23 AM
As John said with the zinc parts, man it's hard to keep track of bits once they are back as well.
lay out and take photo with masking tape and write on the masking tape what they are for then you have a record that you can read out of the bag.
last tip for cleaning bolts and things prior to zinc
have two containers 1) marine clean that's the ppc stuff 2) some form of good quality rust converter ( bunnings has a really good brand ) in 1 ltr clear bottles.
wire brush stuff first , then move the bolts and nuts and screw into the marine clean for a day wash and then rinse and then into the rust converter for 4 -5 hours and then rinse.
when you get then zinc and if they use a tumbler they will come up a really well.
sometime at the platers they cannot be arsed to clean them that well.
keep going bro
1 more mill
#111 Potta
Posted 27 May 2013 - 10:31 PM
Loving your work Marty, looking great so far.
Your attention to detail is what is going to make this car a standout.
#112 _fullnoise_
_fullnoise_
Posted 28 May 2013 - 08:52 AM
Nice work Marty!! did you get this LJ from shaun ?
#113 sibhs
Posted 28 May 2013 - 10:01 AM
Hi Taps,
just looked through my receipts and, yeah! the guys name was Shaun.
What can you tell me?
#114 _fullnoise_
_fullnoise_
Posted 28 May 2013 - 12:35 PM
Yeah i was going to buy it but i got a sand man insted but his nana bought it from new and she used to take us to school in it.then she gave it to shaun and he also bought our mates xu1 thats was wrighten off for parts and shaun put some of the stuff on there but nerver finished it good to see the old girl getting a rebuild good work mate keep it up cheers taps
#115 sibhs
Posted 31 May 2013 - 10:35 PM
That's what Shaun said when I bought it, was good to get the XU-1 parts with it. Sandman sounds like a great alternative to the Torana.
I've been really happy with the condition of this car, has had front guard repair but looks like a good job.
Thanks to Dave, Gong, Potta, Taps and Grant for the encouragement.
Feel like I was locked away for 3 days blasting the car, what a mess and glad it's over.
Attached File  IMG_2970.jpg   31.12K   40 downloads
Attached File  IMG_2983.jpg   56.15K   39 downloads
Attached File  IMG_2985.jpg   30.81K   37 downloads
Got the car outside for the first time in 5 months, this was so I could dust it down and clean the room.
Attached File  IMG_2988.jpg   64.81K   36 downloads
Attached File  IMG_2990.jpg   45.06K   36 downloads
Attached File  IMG_2994.jpg   40.99K   36 downloads
Attached File  IMG_2998.jpg   58.44K   41 downloads
#116 N/A-PWR
Posted 31 May 2013 - 10:46 PM
TORANA FACTORY
#117 sibhs
Posted 24 June 2013 - 11:03 AM
Attached File  ImageUploadedByTapatalk1372035530.436967.jpg   62.27K   36 downloads<br />Quich update. Been on holiday in Bali. <br />Prepping the tunnel for the skin. Attached File  ImageUploadedByTapatalk1372035610.519715.jpg   82.6K   36 downloads<br />Trek screwed in place. Attached File  ImageUploadedByTapatalk1372035638.770079.jpg   85.97K   37 downloads<br />Then welded. Attached File  ImageUploadedByTapatalk1372035665.952866.jpg   77.81K   37 downloadsAttached File  ImageUploadedByTapatalk1372035681.769954.jpg   63.94K   39 downloads<br />Writing this while laying in hospital waiting for operation on hernia. Just had the shave (favorite bit). Hope to chat after. <br />Marty
#118 kiwi-lilj
kiwi-lilj
  • 1,430 posts
  • Name:Blair
  • Car:LIL J
Posted 24 June 2013 - 05:55 PM
Best part of the shave is that it makes it look an inch longer.
Get well soon mate.
#119 Potta
Posted 28 June 2013 - 12:25 AM
Hope you're feeling better Marty.
#120 sibhs
Posted 28 June 2013 - 10:20 PM
Well, my 'last post' which thankfully isn't, was written about an hour before going under the knife to fix a hernia. I had visions of not waking up and leaving you guys with-out an update.
So progress has been slow after a holiday in Bali, then the op, and then getting addicted to 'Breaking Bad' a tv series that I have watched 4 series in a week, not good for the Torana resto.
While in Bali I saw this HQ, gave the guy the thumbs-up as I took some pics.
Attached File  IMG_5451.jpg   92.04K   39 downloads
Thanks to Blair and Potta for their thoughts, You're right Blair, an inch longer.
Here's a tip for those who didn't know - I've used walnut shell in my sand blaster to clean-up all my aluminium, plastic and electrical conectors. It will remove dirt, paint but is gentle on the metals and plastic.
Attached File  IMG_3080.jpg   23.69K   37 downloads
Attached File  IMG_3081.jpg   23.48K   37 downloads
After giving the shell a full 'RustBlast' I decided to KBS the floor pan and then used 'Fusion' to leave the surface ready for the Red oxide primer.
Attached File  IMG_3020.jpg   21.9K   38 downloads
Attached File  IMG_3024.jpg   14.17K   37 downloads
Cleaned up the rocker cover, ready for dent removal and priming.
Attached File  IMG_3034.jpg   21.74K   35 downloads
Made up the section for the shock tower and welded into position.
Attached File  IMG_3036.jpg   18.8K   35 downloads
Attached File  IMG_3038.jpg   16.96K   32 downloads
Attached File  IMG_3090.jpg   15.58K   33 downloads
I'm welding up the aerial hole, notice the other aerial hole that was welded up by someone, could of drilled in the wrong spot and had to fix-up. Forgot pic of mine welded, but it looks better than the other one.
Attached File  IMG_3059.jpg   17.61K   34 downloads
Attached File  IMG_3060.jpg   11.25K   33 downloads
This panel had taken a hit near the headlight and was pulled out and bogged by previous repairer. I was going to cut a new section in but have been advised it would be better to repair this. So I used bolts through the holes, put a washer and nut at the back then my puller to get the dent out to closer fit. I did heat the metal first to make this easier. Then I welded up the holes using this piece of copper pipe, flattend then I could poke it in behind and use as a heat sink. Tested the fit to the headlight bezel, much better and only needs a skim of bog were'as before there was about 5mm.
Attached File  IMG_3064.jpg   16.8K   28 downloads
Attached File  IMG_3063.jpg   17.31K   28 downloads
Attached File  IMG_3065.jpg   19.45K   28 downloads
Attached File  IMG_3067.jpg   18.43K   29 downloads
Attached File  IMG_3066.jpg   21.71K   26 downloads
One of the bonnet mounting points had both ends cut off (not sure why).  I made up some new ends and fitted them.
Attached File  IMG_3084.jpg   18.42K   28 downloads
Attached File  IMG_3086.jpg   19.78K   28 downloads
Attached File  IMG_3087.jpg   19.44K   30 downloads
That's all for now but should make some serious progress next week with me taking time off work to recover from the op.
Edited by sibhs, 28 June 2013 - 10:23 PM.
#121 N/A-PWR
Posted 28 June 2013 - 10:34 PM
Welcome back Marty,
Another great set of hard work. Dave I
#122 Potta
Posted 28 June 2013 - 11:56 PM
Did you get the walnut idea off of Ricks Restorations Marty?
I love that show.
Anyway, good to see you back, I was getting worried.
#123 _LONA-CK_
_LONA-CK_
Posted 29 June 2013 - 07:46 AM
your doing good work there marty,,and im glad your out of hospital, i myself hate going to sleep in there, as so many time i have had love ones not come back.
take care and rest up
cheers gong
#124 sibhs
Posted 29 June 2013 - 04:08 PM
I love that show.
When I bought my blaster from Radum I spoke about blasting the plastic grill and discussed what medium to use.  Never heard of Ricks Resto's?
All I know is when I tried garnett on my lower dash (aluminium) I could see it wearing the metal away so quickly stopped that. When I put the walnut in it took the easily removed paints off but not much more. Cleans up tarnished ali and great for switches and bakerlite with metal contacts. Obviously I presume the switches will still work. :-) Not sure how soda or glass bead would go on plastics etc?
Thanks Gong, I've done enough resting, nows the time to get stuck into finishing some of these rust repairs. Wow...don't like the sounds of not waking up after the op, but I spose it does happen.
I decided to leave the shell Bare metal until the weather warms and I have an Air dryer for the compressor.  So I'll continue with the welding then give the whole car a Rust Blast then Etch prime.
Edited by sibhs, 29 June 2013 - 04:09 PM.
#125 _LONA-CK_
_LONA-CK_
Posted 29 June 2013 - 07:40 PM
thats the best way finish all welding then re sandblast
i think old mate is talking about americain restoration on pay tv
cheers gong
