The Marty Report
LJ GTR Build
1095 replies to this topic
#76 warrenm
Posted 29 March 2013 - 05:42 AM
Thanks for that, much appreciated. :spoton:
#77 _Linesy_
_Linesy_
Posted 29 March 2013 - 06:45 AM
Top Job your doing there. Well done mate!
#78 sibhs
Posted 29 March 2013 - 09:56 PM
Thanks Linesy, that's more motivation to keep going...
Been sourcing more parts, finally got a major part. The boot floor.
Took a couple of hours of careful extraction but more than happy.
Attached File  IMG_2544.jpg   52.84K   29 downloads
Also got the RH rear chassis, mine had been butchered and was missing the rear muffler hanger bracket.Attached File  IMG_2595.jpg   33.43K   28 downloads
Cut the rust out of the boot catch brace
Attached File  IMG_2597.jpg   63.29K   32 downloads
Made a section to reinforce the new chassis.
Attached File  IMG_2598.jpg   45.02K   31 downloads
Below is the bits and some rust repair starts
Attached File  IMG_2619.jpg   52.32K   30 downloads
Attached File  IMG_2625.jpg   63.93K   30 downloads
Attached File  IMG_2631.jpg   72.31K   29 downloads
Started cleaning up the ID tags and was pissed off to find the Body ID Tag was off a 4 door.  When I bought the car the tags weren't a big concern being an "S" I noted that all rivets hadn't been removed but couldn't make out the numbers due to dirt. I did note the car had been in a bingle and another half inner and full outer LH guard had been fitted. Once I stripped the paint I found the true extend of damage, the whole corner had been changed with staggered weld joins in the nose cone, beaver etc. No damage to chassis but I gather the original tag could of been damaged or just a lazy panel beater.
I'm not going to drive/show my car with a 4 door tag on it and don't like the idea of no tag, this may only lead people to believe I have a genuine GTR with the tags in the safe.
So if anyone has a 2 door S tag from late 72 early 73 Adelaide I would like to chat.  Obviously I'm not trying to pass the car off as something it isn't. Infact it's the complete opposite.
#79 rodomo
Posted 29 March 2013 - 10:09 PM
I've said it before, and I'll say it again.
THAT'S HOW REPAIRS WERE DONE BACK IN THE DAY!
Nothing illegal about it back then.
#80 _Agent 34_
Posted 30 March 2013 - 07:04 AM
Marty,
keep hammering away man.
#81 71xu1
71xu1
    Dave
  • 1,278 posts
  • Car:LC GTR XU1
Posted 30 March 2013 - 06:18 PM
Hi Marty not that it matters too much but do away with the sleeve you have made for the chassis more trouble than its worth. It will only act as a rust trap if you need to line the rails up use it for that with vice grips then remove.
Cheers Dave
#82 sibhs
Posted 10 April 2013 - 10:42 PM
Cheers Dave
Thanks Dave, I took your advice and very happy with the chassis rails now. See below
This is the new rail cleaned up, against the old,
Attached File  IMG_2666.jpg   68.73K   35 downloads
Filled the old holes from where the tow bar bolted through. Used a brass heatsink (thick piece of flat bras, copper,ali) to block the holes, then welded away, worked a treat.
Attached File  IMG_2667.jpg   53.14K   33 downloads
Attached File  IMG_2668.jpg   58.02K   33 downloads
Attached File  IMG_2670.jpg   53.88K   33 downloads
The left hand rail had about 5mm trimmed of the lip for the drop tank. That had to be fixed, so I cut the spare one of my original rail and welded it into place. I found the best way was to line up and tac weld holding by a gloved hand a bit at a time and adjusting the new piece as I go. Just couldn't use clamps or pliers, very happy with result.
Once the RH rail and the LH were ready I Rust Blasted (KBS product) the insides then painted on the KBS gloss black. Very satisfied with the result.
Attached File  IMG_2694.jpg   58.81K   35 downloads
Attached File  IMG_2695.jpg   53.59K   31 downloads
Attached File  IMG_2707.jpg   57.8K   32 downloads
While at my Dads I come across some old printing brass letters, ideal for heat-sinks.
Attached File  IMG_2652.jpg   44.81K   29 downloads
Picked up Bertha on Monday, took about 2 hours for me to get it off the trailer and into position. Would of been easier if I hadn't lent my engine lifter to a mate. You can see the difference between the old and new in size.
Tested Bertha on the sandblaster and even with 447 litres of free air, it's only just enough.
Attached File  IMG_2686.jpg   63.89K   29 downloads
Attached File  IMG_2687.jpg   55.73K   31 downloads
Attached File  IMG_2688.jpg   58.61K   32 downloads
Attached File  IMG_2689.jpg   43.45K   30 downloads
Attached File  IMG_2690.jpg   63.4K   28 downloads
Measured and drilled the extra holes required for the brake booster.
Attached File  IMG_2662.jpg   56.07K   31 downloads
Attached File  IMG_2665.jpg   60.43K   28 downloads
Cut the hole for the 4 speed.
Attached File  IMG_2615.jpg   42.31K   32 downloads
#83 N/A-PWR
Posted 11 April 2013 - 01:41 AM
Great Job you are doing Marty. Dave I
p.s. all your tricks work like a treat
#84 _woosha_
_woosha_
Posted 11 April 2013 - 07:51 AM
Nice work marty fairly hooking into her mate. Howz the welding going must be getting better with all the work you been doing?
Cheers woosha
#85 sibhs
Posted 11 April 2013 - 09:37 AM
Thanks Dave, most tricks picked up from you guys, some I make up myself.
Cheers woosha
Hi Woosha,
I'm glad I started learning on the boot and rear repairs, definitely getting better and feeling confident about fitting the flutes.  Next will be the boot floor which will be interesting, I've got a bit of warpage from all the repairs to the floor but should be able to sort it.
#86 Potta
Posted 11 April 2013 - 09:54 AM
Hi Woosha,
BFH should sort that out Marty  :spoton:
#87 sibhs
Posted 22 April 2013 - 10:05 PM
Didn't need the BFH thanks Potta, I had a buckle which I cut a slit in and welded, all good.
Here are the picks of the boot floor being welded in, lined up really well and tacked it all the way around.
Attached File  IMG_2727.jpg   56.68K   30 downloads
Attached File  IMG_2728.jpg   58.58K   28 downloads
Attached File  IMG_2729.jpg   63.84K   29 downloads
Test fitted the tank and all the screw holes line up and it sits nice and flat.
Attached File  IMG_2730.jpg   55.27K   29 downloads
Bashed up Salmon
Attached File  IMG_2732.jpg   96.22K   28 downloads
Once the bumper support brackets were fitted I could put the car back on the rotisserie and finish off the welding from below.  Plan is to use the heatsink and slowly fill the join a bit-at-a-time.
After welding over the KBS and it spitting and carrying on I think I'll do my welding the old school way with clean metal then protect after welding with primers and fish oil.
Attached File  IMG_2740.jpg   37.32K   29 downloads
Attached File  IMG_2741.jpg   37.38K   27 downloads
Attached File  IMG_2742.jpg   63.38K   27 downloads
Attached File  IMG_2743.jpg   44.2K   28 downloads
Prepped and painted the brake calipers then chucked them in the oven at 90º for one hour to cure the heat proof paint.
Re-fitted rubber seals and wrapped them up for storage.
Attached File  IMG_2733.jpg   59.84K   27 downloads
Attached File  IMG_2737.jpg   36.03K   27 downloads
Attached File  IMG_2744.jpg   44.44K   25 downloads
Attached File  IMG_2748.jpg   38.46K   27 downloads
Cleaned up the K Frame by degreasing and then high pressure cleaner, next it will need sand blasting, weld splatter ground off and re-drilling the holes lower.
Attached File  IMG_2745.jpg   75.59K   29 downloads
Sand blasted and rust blasted the suspension bits, testing out results with the KBS to get an acceptable finish.
Attached File  IMG_2746.jpg   63.8K   27 downloads
Attached File  IMG_2752.jpg   36.73K   28 downloads
Hubs sandblasted, rustblasted and awaiting paint.
Attached File  IMG_2749.jpg   45.97K   27 downloads
Attached File  IMG_2751.jpg   36.93K   26 downloads
#88 _LONA-CK_
_LONA-CK_
Posted 23 April 2013 - 07:45 AM
great work marty
cheers gong
#89 N/A-PWR
Posted 23 April 2013 - 03:30 PM
Hi Marty,
There is great satisfaction in painting all the suspension parts individually, great time spent. Dave I
#90 sibhs
Posted 23 April 2013 - 11:02 PM
Thanks Gong and Dave, good to get the encouragement and know my thread gets read.
It's really satisfying doing this resto (so far) and I'm glad I didn't end up buying a restored car.
#91 Potta
Posted 23 April 2013 - 11:22 PM
Good stuff Marty, I see a few familiar looking pieces in that lot, I'm glad they're getting put to good use.
#92 Heath
Posted 24 April 2013 - 07:45 AM
Great work! Enjoying this.
#93 _Agent 34_
Posted 25 April 2013 - 06:04 PM
go Marty go !
smashing it.
#94 _Liam_
_Liam_
Posted 25 April 2013 - 06:24 PM
Love this whole thread mate, it's awesome.
#95 sibhs
Posted 04 May 2013 - 10:19 PM
Well I'd heard about the amazing Molassis so I thought it was worth a try.
Unbelievable......... if you haven't tried this stuff, do yourself a favour and give it a go. I had good results after 10 days and awesome rust removal after 2-3 weeks. Check out some results below.
Attached File  IMG_2725.jpg   65.86K   29 downloads
Attached File  IMG_2835.jpg   52.47K   28 downloads
Attached File  IMG_2783.jpg   69.75K   27 downloads
Attached File  IMG_2842.jpg   46.91K   28 downloads
More work on the boot floor, I had a wideish gap to fill at the rear of the tank lip so I made up a brass heatsink to the shape. This however failed to work and the brass actually welded to the steel.  I then used a piece of copper water pipe with more success. The brass worked fine when used flat but on it's side was RS.
Attached File  IMG_2764.jpg   55.44K   25 downloads
Attached File  IMG_2763.jpg   41.84K   24 downloads
Attached File  IMG_2765.jpg   47.92K   27 downloads
Attached File  IMG_2766.jpg   92.4K   25 downloads
Painted a few more brake parts and cured them in the oven, assembled the hubs to rotors and packed 'em away.
Attached File  IMG_2785.jpg   58.27K   25 downloads
Attached File  IMG_2786.jpg   59.37K   27 downloads
Attached File  IMG_2796.jpg   51.87K   26 downloads
Rear bumper brackets were rusted so they had a dip in molassis then a clear coat.
Attached File  IMG_2788.jpg   52.94K   27 downloads
Fixed up the adjusting nut on the rat trap by welding and turning on lathe.
Attached File  IMG_2814.jpg   45.79K   27 downloads
Attached File  IMG_2815.jpg   35.74K   26 downloads
Attached File  IMG_2817.jpg   40.32K   26 downloads
Attached File  IMG_2831.jpg   42.57K   24 downloads
Noticed a bit of a lump on the shockie mount so cut this away to reveal the damage, I'll treat this and make up a new section and weld in.
Attached File  IMG_2826.jpg   61K   25 downloads
Attached File  IMG_2829.jpg   49.81K   24 downloads
#96 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 04 May 2013 - 10:49 PM
your doing a top job Marty, keep it coming!
#97 sibhs
Posted 04 May 2013 - 10:50 PM
I bought a sill panel and have had to make a few adjustments. The one that I haven't read about here is the varying width of the outside flat edge. It starts at 20mm near the front of the door and widens to 24mm at the rear.  To get this to work I cut down the length of this edge and puled it out 4mm and welded it back up. My first attempt started pulling the gap in so I had to cut my tacks and use spacers to hold the distance.
Attached File  IMG_2822.jpg   44.04K   28 downloads
Attached File  IMG_2820.jpg   52.94K   26 downloads
Attached File  IMG_2821.jpg   37.68K   25 downloads
Attached File  IMG_2824.jpg   60.34K   27 downloads
Attached File  IMG_2825.jpg   65.21K   26 downloads
Cut out the passenger floorpan and positioned the new one.
Attached File  IMG_2847.jpg   54.99K   29 downloads
Attached File  IMG_2849.jpg   56.04K   29 downloads
Assembled the pedal box, modified clutch pedal and fitted new rubbers to 2K satin painted metal.
Attached File  IMG_2853.jpg   44.37K   28 downloads
My champ of a son bought a grill emblem for me so I fitted that to the chrome. Looks sweet.
Attached File  IMG_2838.jpg   54.77K   29 downloads
Can someone tell me what this is for. I bought the firewall grommet kit and there are two of these in it.
Attached File  IMG_2837.jpg   43.44K   30 downloads
Got some epotec for priming the bare panels, I've been putting this off and just rustblasting bare metal but that only lasts about 6 weeks before the rust returns. Cost me $100 for this, thanks to Greg, great value if it's as good as they say.
Attached File  IMG_2843.jpg   57.62K   31 downloads
Having a go at making this bit for the rattrap using a high tensile bolt and turning it to size, really botching it up at the moment and need to get another cutter for the lathe. I'll get there.
Attached File  IMG_2841.jpg   56.03K   28 downloads
Attached File  IMG_2845.jpg   49.83K   27 downloads
Thanks for the support guys and Potta there's quite a few parts from your old girl going on here including, boot floor, front brakes, booster, steering column, tunnel skin,etc etc.
#98 sibhs
Posted 05 May 2013 - 11:11 AM
For those that haven't seen my Glory Box thread, here's a picture of my inspiration.
Attached File  S Final.jpg   53.1K   28 downloads
This is where the colour and year choice are coming from. Owned this car for ten years in the 80's and 90's and had plenty of good memories from it.
#99 N/A-PWR
Posted 05 May 2013 - 12:54 PM
Hi Marty,
Can see you have wasted no time putting your goodies to work, had a look around for your grommet query and it seems from this link (  http://www.gmh-toran...attach_id=29729  ) there are 2 of them in the kit (must be a spare). Dave I
http://www.gmh-toran...e-2#entry747275
p.s. Great Idea in recreating your Original Car
Edited by TORYPOWER, 05 May 2013 - 12:59 PM.
#100 sibhs
Posted 05 May 2013 - 01:37 PM
Hi Dave, theres no mention of these grommets in that thread. There about 15mm long, they look familiar but just can't think where they go?
Attached File  IMG_2837.jpg   43.44K   32 downloads
