Potta's LC GTR
699 replies to this topic
#426 Potta
Posted 11 February 2015 - 01:31 AM
This is why I put my bolts in from underneath, that's what the destructions say :-)
Attached File  image.jpg   221.94K   5 downloads
I've got lock nuts on top now and will do the other side the same.
#427 Potta
Posted 13 February 2015 - 12:46 AM
Time to update the list
1. Steering - Rectify pulling on road test
2. Foot Brake - Rectify swerving/pulling from straight ahead position when brakes applied
3. Differential/Final Drive - Clean and Rectify all Oil Leaks - Diff centre removed, cleaned, painted
4. Steering Box/Rack - Rectify all excessive Free play - Removed for reco -  currently at Wilkinson's suspensions.
5. Linkage - Rectify all excessive free play including Tie Rod ends, left side - Removed, rubber was like vegemite,
6. Interior General - Fill or cover speaker holes in parcel shelf
7. Control Arms - Rectify Damaged/bent including Rear trailing arm acquired replacements
8. Control Arms - Rectify excessive movement/worn bushes, including bottom, left lower
9. Seat Belts - Rectify damaged/frayed webbing - Right Front - Picked up ready to be installed
10. Indicator lamps to cancel on left and right turns as steering wheel returns to center position - Purchased cancelling springs
11. Gearbox - Clean and rectify all oil leaks - plug missing in yoke shaft - Plug purchased - Shaft is back together but not in the car till I clean up
12. Indicator lamps to operate correctly including right rear - rectify light dull
13. Plate Lamp to operate correctly
14. Park Brake locking pawl/ratchet to operate correctly
15. Seats - Fit trims, knobs, rotating wheels - drivers side tilt knob cover missing - New knob ordered - Due next week apparently.
16. Centre console to be securely mounted
17. Steering to self centre after turns
18. Rectify steering too heavy
19. Replace Ball Joints
20. Install taller front springs to match rear(Kings 1" lowering springs)
21. Replace rear brake cylinders
22. Paint Diff and Drive Shaft in colours that will clash
23. Replace Brake Disks
Still a lot to do, not sure I'm going to make it, but I'll do my best.
The steering and braking issues should be fixed but I will need to test to confirm.
I've almost finished all the stuff in the front end, then I'll move to the back.
I would love to have it driveable again by Sunday night but we'll see.
#428 N/A-PWR
Posted 13 February 2015 - 10:34 AM
Great Work Craig,
The amount of work you have put into the RWC tasks,
is like rebuilding an LC GTR,
in such a short amount of Time.  :clap:  :spoton:
#429 Potta
Posted 13 February 2015 - 09:28 PM
Great Work Craig,
Cheers Dave, I'm certainly starting to feel it, lots of late nights and not much downtime, but life wasn't meant to be easy.
List is wrong so here is an adjusted one.
7. Control Arms - Rectify Damaged/bent including Rear trailing arm - acquired replacements
15. Seats - Fit trims, knobs, rotating wheels - drivers side tilt knob cover missing - New knob ordered - Ready for pickup tomorrow.
11 out of 23 things to go. Its gonna be tight.
#430 _threeblindmice_
_threeblindmice_
Posted 13 February 2015 - 09:33 PM
Have you checked the steering coupling , the failed mine when it went for rego .
#431 Potta
Posted 13 February 2015 - 09:41 PM
Yeah its nolathane which I don't like but its fairly new.
I will replace it later.
Pretty sure they only check what failed last time anyway.
At least I hope, otherwise he's likely to go to town again.
#432 Ice
Posted 13 February 2015 - 09:56 PM
Is your steering self centering yet Craig
#433 Potta
Posted 13 February 2015 - 10:19 PM
dunno mate, she's still up on stands, had to get a seal for one of my backing plates so can't put the wheels back on yet.
It will be a matter of put it together and hope I think.
It was pretty much self centering before, it was just that it was pulling to the left that made it seem like it wasn't self centering.
I'm really hoping I don't need a new shaft.
#434 _LHSL308_
_LHSL308_
Posted 13 February 2015 - 11:31 PM
Keep it going Craig your doing a great job, getting into the home stretch now and it will be all worth it.
#435 Potta
Posted 14 February 2015 - 12:07 PM
10 to go lol
#436 Potta
Posted 15 February 2015 - 07:52 PM
BOOM!!
Couple of big ones off the list and I've got the Ok to have Thursday and Friday off to finish off and go for rego again.
Starting to feel like I might get there again now.
#437 Potta
Posted 17 February 2015 - 02:07 AM
Pretty much all done now, just a few jobs left to do and hopefully the front end and suspension work I've done will fix the steering.
Jobs left to do;
Refit Wheels
Wheel alignment
Fit new Seatbelt
Fit console securely
Tighten suspension once it is on the ground and settled
Bleed brakes
Under vehicle degrease
Fit drive shaft
Hope for the best
Test  :driving:
#438 _duggan208_
_duggan208_
Posted 17 February 2015 - 10:40 PM
Fingers crossed, might have to say a little prayer mate.
regards
#439 Potta
Posted 18 February 2015 - 01:22 AM
Refit Wheels
Wheel alignment
Fit new Seatbelt
Bleed brakes
Fit drive shaft
Top up Gearbox Fluid
Hope for the best
Lots of fiddling, tightening, adjusting etc etc tonight.
Feels like I got nothing done but put in a solid couple of hours.
A few little fiddly bits that took up a heap of time.
regards
Thanks Jon, I'm happy for anyone to pray to whichever deity they see fit to get me across the line.
I just need a little bit of luck and I'll be right.
Its the console that's going to be a b!tch, I can tell already.
#440 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 18 February 2015 - 10:13 AM
Did you have guages in the console, can't remember.  Would it be easier just to remove it for the check?
Edit, you'd probably need a new shifter boot then I guess which might be just as difficult.
Edited by stevemc32, 18 February 2015 - 10:14 AM.
#441 Shiney005
Posted 18 February 2015 - 02:48 PM
How is it going Craig? You getting there?
#442 Potta
Posted 18 February 2015 - 09:30 PM
Yeah that's why I went for a console in the first place, easiest way to cover up the shifter and handbrake.
I'll make it work
Haven't done any more yet but booked in for a wheel alignment Friday morning and heading out to the shed in a minute.
Not a lot left to do but I'm sure there will be some last minute adjustments and mucking around to get things right.
#443 Potta
Posted 19 February 2015 - 01:53 AM
Refit Wheels
Wheel alignment
Fit new Seatbelt
Bleed brakes
Fit drive shaft
So a few jobs to do tomorrow, then hopefully all good when I test drive.
Wheel alignment and pit inspection booked in for Friday.
#444 Shiney005
Posted 19 February 2015 - 09:03 AM
Good luck with it mate. After the effort you have put in they had better pass it. Lets see lots of pics of it driving around this weekend.
#445 Potta
Posted 19 February 2015 - 05:57 PM
Refit Wheels
Wheel alignment
Fit new Seatbelt
Bleed brakes
Fit drive shaft
Just waiting for my brake pedal pumper to get home and I'll be able to go for a test run
#446 _Bomber Watson_
Posted 19 February 2015 - 06:02 PM
STart gravity bleeding them while you wait :D
#447 Potta
Posted 19 February 2015 - 06:49 PM
Tried doing it myself but couldn't quite reach the spanner with my foot on the brake lol.
#448 _Bomber Watson_
Posted 19 February 2015 - 06:58 PM
I do them myself with no special tools exclusively, as i've managed to teach the dog to neither press the brake pedal or turn the spanner.
Just crack a nipple and wait, give it a pump on the pedal occasionally if you get bored, fluid will come out eventually. Run some clear PVC line from the bleeder, and run it up then down into a bottle. After you have blead them fairly well you will have a solid colom of fluid in the line with no air bubbles, then you can start pumping the pedal a bit. Close the nipple, pump it, open it again, etc, time consuming but works when you have no friends and live alone.
#449 Potta
Posted 20 February 2015 - 01:11 AM
:party:  :D  :D  :spoton:  :rockon:  :rockon:  :burnout:
Pretty happy right now, drives straight, stops straight, is awesome.
List is completed except for wheel alignment which will happen in the morning.
To say I'm stoked and relieved is a massive understatement.
Thanks to everyone who offered support and advice, wish me luck.
#450 _Bomber Watson_
Posted 20 February 2015 - 08:17 AM
Congrats mate.
