LX Hatch Complete Restoration
484 replies to this topic
#376 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 22 March 2023 - 10:26 AM
2.5" front to back.
I had to the bulge out the body at the top of the hoop to make it work.
I don't think it would have fitted without that.
You can see some of what was done in the picture.
Regards Mando.
I just ran twin 3 inch pipes in mine over the diff.
Didn't have to touch the floor at all. But I did run it on the outside of the upper arms on an angle back towards the centre of the diff.
I have 20mm between exhaust and floor and close to 3 inches of travel in suspension. I will be making my bump stops so it will never make contact with the exhaust pipes. Just tacked together atm. Just have to run the rest of the rear pipes behind the diff now.
Have a look at my build thread to see more.
#377 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 23 March 2023 - 05:59 PM
Well done,
there's no way I could have done what you have.
Do you have a standard fuel tank ?
Regards Mando.
#378 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 24 March 2023 - 10:44 PM
Well done,
Regards Mando.
Mine has had the ear tubs modified along with the tank to allow for the little 295 30 18 tyres that will be fitted when finished.
So the drop tank has been built to suit the car.i do believe it can be done with a std tank.
Instead of running the pipes over the diff centre run them on the outside of the top arms like I have. Look at my build thread and you will see what I mean.
#379 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 25 March 2023 - 12:36 AM
Shtstr,
how do I get to your build thread.
Regards Mando.
#380 Bigfella237
Posted 25 March 2023 - 12:23 PM
Exhaust work starts here: https://www.gmh-tora...14#entry1094341
#381 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 25 March 2023 - 01:03 PM
Thanks Andrew.
Regards Mando.
#382 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 25 March 2023 - 01:11 PM
Attached File  IMG_1182.jpg   125.88K   6 downloads
Attached File  IMG_1183.jpg   132.07K   6 downloads
Could anyone let me know where these brackets go please.
Thanks in advance.
Regards Mando.
#383 Cook
Cook
  • 1,535 posts
Posted 25 March 2023 - 05:15 PM
Jeff they look like half of the bracket that goes on the back of the rear seat to lock into the bracket mounted on the rear wheel hump. Cheers Ron
Edited by Cook, 25 March 2023 - 05:21 PM.
#384 Heath
Posted 29 March 2023 - 08:38 AM
Spot on. They are the "bump stop" brackets for the rear seat striker.
#385 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 29 March 2023 - 03:52 PM
Thanks guy's,
does anyone know where I can get a 14" steering wheel
that looks the same as a what you would find on a Torana.
Regards Mando.
#386 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 04 April 2023 - 04:16 PM
Hi Guy's,
do all Torana LX models, and in particular hatch's, have to have a centre seat belt.
Regards Mando.
#387 Bigfella237
Posted 04 April 2023 - 04:30 PM
If it says "SEATING CAP 5" on the compliance plate (which it does) then there must be 5 seating positions, all with seat belts.
It is possible to alter the seating capacity with an engineering report, if you're already going down that road for other mods?
#388 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 04 April 2023 - 04:39 PM
Thanks Andrew.
If I was to go down the engineering road, do you think
they would need me to alter the compliance plate from 5 to 4
Regards Mando.
Edited by jeffblanco, 04 April 2023 - 04:45 PM.
#389 warrenm
Posted 05 April 2023 - 06:38 AM
The compliance plate wouldn't be altered, but the engineering paperwork that you have to carry in the vehicle would mention it & any other modifications.
#390 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 05 April 2023 - 07:00 AM
Thanks Warrenm,
that makes sense.
Regards Mando.
#391 Shiney005
Posted 05 April 2023 - 08:29 AM
Thanks guy's,
Regards Mando.
Rare Spares sell a replica I believe. The spokes are thinner than the original ones, but they look very similar.
#392 Cook
Cook
  • 1,535 posts
Posted 05 April 2023 - 09:03 AM
I have a RareSpares one and I'm happy with it, but I'm not trying to achieve originality.
Jeff, out of curiosity, why don't you want to include the fifth seatbelt? Cheers Ron
#393 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 05 April 2023 - 09:30 AM
Hi Laurie,
I'll see what Rare Spares have to offer.
Ron,
I got the car back from the upholster and I can't see the lap seat belt on the back seat.
I'm probably jumping the gun because I need to check with the upholsterer before I do anything.
I'm sure I gave him 5 boxes with all the seat belts but one seams to be missing.
I'm over dealing with tradespeople.
Regards Mando.
#394 Bigfella237
Posted 05 April 2023 - 09:38 AM
Hopefully it's there and he/she just forgot to pull it out when fitting the lower seat swab. You may have to remove the lower half again to look?
If they have lost it and not said anything, go back and tear them a new one!
Either way, I'd say it'd be cheaper (and a LOT easier) just to buy another seat belt rather than getting an engineer's report.
#395 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 05 April 2023 - 10:30 AM
Thanks Andrew,
as usual, I can't argue with your reasoning.
Regards Mando.
#396 Cook
Cook
  • 1,535 posts
Posted 05 April 2023 - 10:51 AM
Agree with Andrew. I had fitted mine before it went to the trimmer and I had to go hunting to find it after I got it back. From memory I bought my steering wheel from Resto Country as it was a bit cheaper but it was a Rares one. Cheers Ron
#397 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 07 April 2023 - 05:08 PM
Nearly done.
Engine bay and under car complete, nothing to do.
All the fluids are in, and the car started first time once the fuel got to the throttle body.
It runs like crap, but should be all good once it gets to the dyno on the April 21.
Regards Mando.
Attached File  IMG_1188.jpg   376.31K   7 downloads
Attached File  IMG_1189.jpg   424.17K   10 downloads
Attached File  IMG_1190.jpg   365.02K   10 downloads
Attached File  IMG_1191.jpg   426.2K   10 downloads
Attached File  IMG_1194.jpg   377.76K   7 downloads
#398 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 07 April 2023 - 05:27 PM
The boot carpet installed by dash original is an absolute disaster.
I've ordered a new one from Winners hoping the next one will fit like a glove, fingers crossed.
Attached File  IMG_1184 (1).jpg   403.23K   7 downloads
I'm really happy with the rest of the interior.
I've just got some small things to finish of like the door cards, centre the steering wheel after the wheel alignment
and adjust the glove box lid.
Attached File  IMG_1196.jpg   382.86K   8 downloads
Attached File  IMG_1186.jpg   326.13K   9 downloads
Attached File  IMG_1185.jpg   310.89K   8 downloads
When I took the car out of the garage for the first time, and turned the wheels onto full lock I heard an almighty crunch
to find out the tyres don't clear the front flares.
I'll have to cut out a wedge and have someone fibreglass them up.
Attached File  IMG_1195.jpg   229.54K   13 downloads
Regards Mando.
#399 Bruiser
Bruiser
  • 881 posts
  • Name:Bruce
Posted 07 April 2023 - 05:44 PM
Nice work mate, she looks schmick as a brand newie
Shame about the flares tho
#400 christolx
christolx
  • 184 posts
  • Name:Chris
  • Car:1976 LX SL Coupe
Posted 07 April 2023 - 08:06 PM
I'm having the same problem with my Flares. had the rears re-shaped, as they pulled in at the bottoms and the fronts...I'm not even sure how I'm going to modify them to fit well.
