LX Hatch Complete Restoration
484 replies to this topic
#326 Heath
Posted 15 September 2022 - 03:25 PM
I have a decent original Twist-and-Pull handle here that I'm happy to sell, if you need it.
#327 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 15 September 2022 - 03:35 PM
Thanks Heath,
I think I'll wait until it turns up.
I know I put it somewhere.
Thanks for the offer.
Regards Mando.
#328 AbsynthHatch
AbsynthHatch
  • 765 posts
  • Name:Mark
Posted 18 September 2022 - 08:05 AM
Mick from Torana Restoration Parts may know the answer to this question.
#329 Cook
Cook
  • 1,535 posts
Posted 18 September 2022 - 10:29 AM
Hi Mick. Now that I think about it I'm sure I got mine from Mick not Resto. Cheers R
#330 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 01 October 2022 - 09:49 PM
Hi Guy's,
could anyone let me know how many bows are there for the roof lining please.
One of the bows I have is about half the thickness of the other bows I have.
Would this be one of the bows or just a piece of wire.
Regards Mando.
#331 Cook
Cook
  • 1,535 posts
Posted 02 October 2022 - 08:33 AM
Hi Jeff. I only had 2 rods and some wire in mine but I also had a sunroof. Check the holes in the inner side to see where they can be located. That should give you clue. I'm not sure but I think the "wire" runs along the very back and fits under the two tabs. Cheers Ron
#332 Bigfella237
Posted 02 October 2022 - 10:56 AM
According to the cattledog there are 4 "Wires", the first & third (counting from the front) are identical, and both the second & forth are unique...
Unfortunately I can't tell you any more as it's been decades since I've physically looked at the wrong side a Torana headlining but I'm sure somebody here will know which are which.
Edited by Bigfella237, 02 October 2022 - 11:00 AM.
#333 claysummers
Posted 02 October 2022 - 11:34 AM
I’m guessing it will be one that is supported by tabs on the body. Usually where there is a support brace for the roof panel and to mount interior light, and/ or at the hatch opening. Not talk8ng about hatches specifically, of which I have no clue, but old cars in general from experience.
#334 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 02 October 2022 - 02:12 PM
Thanks everyone, I never thought to look at the body for tabs.
Regards Mando.
#335 Heath
Posted 02 October 2022 - 04:18 PM
You should have three rods, two match and one odd one (the different length one on a hatch is not common with a sedan headliner).
The rods reach between the holes in the cant rails.
Then there are spots where the roof support/s have the row of sharp little triangles punched out, this is where the thinner wire goes.
#336 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 02 October 2022 - 08:07 PM
Thanks Heath,
I hope the guy doing the interior can do something with the thin wire.
It actually looks like junk.
Regards Mando.
#337 Heath
Posted 03 October 2022 - 09:00 AM
Just replace it with some fat stainless wire if you want something that is less shitty looking.
#338 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 03 October 2022 - 01:08 PM
Thanks Heath,
Iv'e found a place in country SA that makes new ones from sainless steel.
I know is a rip off but I can't help myself.
Regards Mando.
#339 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 06 October 2022 - 08:25 PM
What a mess !
Attached File  IMG_1064.jpg   393.32K   13 downloads
Attached File  IMG_1065.jpg   518.36K   12 downloads
Attached File  IMG_1066.jpg   331.6K   13 downloads
Attached File  IMG_1068.jpg   326.43K   15 downloads
Attached File  IMG_1069.jpg   357.53K   20 downloads
Regards Mando.
#340 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 04 January 2023 - 05:52 PM
Greetings Gentleman,
can anyone let me know if the instrument fascia [the one with the cigarette lighter] can be installed before
the hard vinyl / plastic piece that runs along the top of the dash then runs down on both sides next to the side vents.
Regards Mando.
#341 Statler
Posted 04 January 2023 - 05:56 PM
Yes
#342 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 05 January 2023 - 04:48 PM
Thanks Col.
Regards Mando.
#343 Heath
Posted 10 January 2023 - 12:14 PM
The thing on the top (that runs down the sides) is called the "crash pad" and I prefer to take it off before playing with the rest of the dash fascia.
#344 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 10 January 2023 - 05:33 PM
Attached File  IMG_1138 (1).jpg   340.01K   8 downloadsThanks Heath,
turns out the instrument panel wouldn't fit between the
lower panel and the crash pad so I had to remove it first.
Regards Mando.
#345 hanra
Posted 11 January 2023 - 12:17 PM
Is that a repro fascia? A friend of mine had the same problem.
#346 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 11 January 2023 - 05:05 PM
Hi Brad,
the slide control panel and the ashtray fascia are from Rare Spares,
the rest have been reconditioned by dash original.
They also reconditioned the lower dash panel and the dash pad.
They did an amazing job, the only thing left to be done is the centre console.
Regards Mando.
#347 Cook
Cook
  • 1,535 posts
Posted 12 January 2023 - 07:33 AM
Hi Jeff. Looking good. I have just fitted mine up and realised that there are two rubber bumpers either side for the glovebox and one goes in from the back. I found with the right hand side one (looking at it) that I couldn't fit it with the gauge cluster fascia in place. Cheers Ron
#348 hanra
Posted 12 January 2023 - 08:22 AM
Yeah the cluster section was a repro that a friend had and it wouldnt fit between the top and bottom of the dash panel.
#349 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 12 January 2023 - 06:36 PM
Thanks Cook,
I was going have a look at the glove box this weekend.
Sounds like the rubber bumpers are going to be one problem but the bigger problem for me,
is I have to cut down the bottom of the card box that sides into the glove box
to accommodate the top of the air conditioner, the ducts that run to the vents and wiring looms.
A question I hope someone might be able to answer is...
I have green tinge glass all around but I still need to buy the front glass.
I can get a front screen that is clear OR I can get a screen with a green tinge,
but it has sun visor band across the top in the glass.
I'm looking to make my car look look as close to a A9X.
Any thoughts
Regards Mando.
#350 Shiney005
Posted 15 January 2023 - 10:54 AM
This is the "new" A9X. (Which I believe is in the eastern states now)  It looks clear to me, and no sun strip either.
Attached File  IMG_0610 - Copy small smaller.jpg   181.6K   9 downloads
Edited by Shiney005, 15 January 2023 - 10:55 AM.
