LX Hatch Complete Restoration
484 replies to this topic
#51 Heath
Posted 14 June 2019 - 01:50 PM
I'm not sure if this answers your question, but the first thing I did was buy the rims 10x17's and 8x17's and asked for as much dish as possible to look like the hot-wires you would see back in the day without going crazy.
Then I sat them under the car where I thought they should sit, and measured from rim to rim.
Rodtech in Adelaide did the rest with the diff.
Just FYI (and it wasn't my question in the first place) but wheels like that are generally just done in one casting per 'size'. The offset range is just a case of machining different amounts of meat off the hub mating face (normally you'd have about an inch range of offset to choose from) so the dish is not affected at all.
I would IMAGINE that any 17x10" Repro Hotwire from that company has exactly the same amount of dish. And consequently your reply doesn't really answer his question, haha.
Edited by Heath, 14 June 2019 - 01:50 PM.
#52 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 14 June 2019 - 03:43 PM
I understand what your'e saying about the wheels, so I can say without any doubt I have no idea what the track of the diff is.
I gave a measurement to Rodtech and he built the 9" to that.
Your'e right, the question still hasn't been answered.
Regards Mando.
#53 _LS2 Hatch_
_LS2 Hatch_
Posted 15 June 2019 - 02:30 PM
Great build. Coming along nicely. Will be some fun once complete.
I doubt you will need the clutch hole and bolt if your going hydraulic clutch. Your hole will be elsewhere.
I like your aircon set up. I may need to look into that a bit further. I want to put AC in mine too.
Keep up the good work.
#54 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 15 June 2019 - 05:08 PM
Thanks Grant,
Iv'e bought a hydrolic clutch kit from Mal Wood.
If the clutch cable isn't going to exit where the clutch hole and bolt is on the firewall where would it end up?
The car is finally striped and ready to get dipped on Monday.
Iv'e marked up every hole, dent and bracket that needs to be filled or repaired.
I hope I don't get to many surprises once the paint and bog are removed.
Attached File  DSCN0425.jpg   167.82K   22 downloads
Attached File  DSCN0431.jpg   175.75K   28 downloads
Attached File  DSCN0432.jpg   176.74K   19 downloads
Attached File  DSCN0439.jpg   195.19K   19 downloads
Attached File  DSCN0428.jpg   155.42K   21 downloads
Attached File  DSCN0427.jpg   172.86K   20 downloads
Regards Mando.
#55 Bigfella237
Posted 16 June 2019 - 12:50 AM
Hmm, if the shell is getting dipped, won't you lose all your marks in the process?
The Mal Wood hydraulic clutch master cylinders are totally under the dash aren't they? All you need to pass through the firewall is a feed hose from the reservoir in to the master cylinder, and a pressure hose back out to the slave cylinder.
#56 _LS2 Hatch_
_LS2 Hatch_
Posted 16 June 2019 - 09:07 AM
Yep, I’m with you Bigfella. Depending on where he puts the reservoir the original hole can go. I passed mine through under the booster so it’s not visible. As for the pressure line, I ran that internal under dash then drilled a hole in the tunnel to bring out where I wanted it. Was then covered with carpet so not seen.
Can I suggest you use the remote bleeder from Malwood too. Helps for a lot less mess when bleeding the clutch
#57 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 16 June 2019 - 02:04 PM
Iv'e taken photos of the markings on the shell so the guy's at the painter's shop can see what needs to be done.
Hope it works out because I won't get a second chance.
I'll give Mal Wood a call tomorrow and ask about the remote bleeder.
Where is the pressure line connected to?
Regards Mando.
#58 _LS2 Hatch_
_LS2 Hatch_
Posted 16 June 2019 - 05:06 PM
The slave cylinder.
In a nutshell it’s the reservoir to the pedal/master then from there to the slave cylinder/throw out bearing.
Given these are flexible rubber or braided lines, you can choose your own route and exit point through the firewall or tunnel.
Hope that helps or makes sense.
#59 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 16 June 2019 - 05:16 PM
Yep, bleeder extension's remote bleeders ect, are way easier. & the likes of dash 3 braided hose, I've got complete dash 3 in my cluby, & the clutch is way nicer to use, you can half clutch it, all the time. Makes a massive difference from a rubber hose. Gary.
#60 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 16 June 2019 - 06:46 PM
Thanks guy's, I know what your'e talking about now.
Regards Mando.
#61 Holdenbn74
Holdenbn74
  • 152 posts
  • Name:Brendan Nichol
  • Car:LH
Posted 07 July 2019 - 09:25 AM
Love ya work! Great to see these being reborn with such care 👌
#62 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 08 July 2019 - 02:18 PM
Attached File  DSCN0451.jpg   130.54K   28 downloads
Attached File  DSCN0452.jpg   150.57K   24 downloads
Attached File  DSCN0453.jpg   256.96K   21 downloads
Attached File  DSCN0455.jpg   278.33K   20 downloads
I went to see the car today.
Very happy with the body, the guy's at Minus Paint have done a fantastic job.
Regards Mando.
#63 purrlx
purrlx
  • 1,332 posts
  • Name:Danny
  • Car:LX hatch
Posted 09 July 2019 - 07:27 AM
Looks like a great rust free shell.
#64 Heath
Posted 10 July 2019 - 12:15 PM
That is so cool to look at.
I'm never going to strip another car body by hand like I've done my hatch. That was the shittest idea hahaha.
#65 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 11 July 2019 - 02:25 PM
I took some more pictures of the shell today.
Attached File  DSCN0462 (1).jpg   124.49K   19 downloads
Attached File  DSCN0456.jpg   245.47K   20 downloads
Attached File  DSCN0457.jpg   283.99K   19 downloads
Attached File  DSCN0458.jpg   275.3K   19 downloads
Attached File  DSCN0459.jpg   209.86K   18 downloads
Attached File  DSCN0460.jpg   240.6K   16 downloads
Attached File  DSCN0461.jpg   232.79K   19 downloads
Attached File  DSCN0463.jpg   293.58K   17 downloads
Regards Mando.
#66 Bigfella237
Posted 11 July 2019 - 08:31 PM
Now you're just showing off!
That is a thing of beauty! Don't you wish you could just clear over that and keep it as is?
#67 Joe
Joe
  • 31 posts
  • Name:Joe
  • Car:LX Torana
Posted 04 August 2019 - 08:46 PM
Hi Jeff,
That's a good build. How much does the airfilter protrude to the bonnet. And what setup/harness are you using to run the E.F.I. If you don't mind asking. Thanks .
Fernando
#68 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 05 August 2019 - 07:34 PM
I think the air cleaner sticks past the bonnet about 25mm from memory but I can't be completely certain.
I only had it set up for a few day's and that was a while ago.
My tuner want's me to use Holley EFI ECU harness kit for LS2 / LS3 / LS7 510-550-603.
Regards Mando.
#69 Joe
Joe
  • 31 posts
  • Name:Joe
  • Car:LX Torana
Posted 08 August 2019 - 06:24 PM
Thanks Mando :D
Regards Mando.
#70 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 27 October 2019 - 03:29 PM
Hi Guy's,
I thought I would post a few pictures of the hatch I just bought from Perth.
It arrived last week so here we go again.
I have a lot of parts for sale so if anyone needs anything give me a call
0407 80 70 60 NO TEXT.
Regards Mando.
Attached File  DSCN0474.jpg   181.44K   17 downloads
Attached File  DSCN0475.jpg   167.36K   20 downloads
Attached File  DSCN0476.jpg   192.04K   18 downloads
Attached File  DSCN0477.jpg   186.96K   18 downloads
Attached File  DSCN0478.jpg   136.58K   16 downloads
Attached File  DSCN0479.jpg   137.22K   17 downloads
#71 Statler
Posted 30 October 2019 - 02:27 PM
Following
#72 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 01 February 2020 - 06:17 PM
Attached File  DSCN0487.jpg   129.01K   22 downloads
Attached File  DSCN0490.jpg   141.41K   18 downloads
Attached File  DSCN0491.jpg   139.45K   18 downloads
Attached File  DSCN0492.jpg   127.93K   14 downloads
Attached File  DSCN0493.jpg   121.01K   15 downloads
Attached File  DSCN0494.jpg   139.76K   14 downloads
Hi Guy's,
the new car is well on the way and hope to start stripping everything in the next two or three weeks.
No need to install the 9" so I've saved some time.
Have to made all the brake lines in the engine bay again.
The old car had the engine bay smoothed over so the old lines won't go.
I had all the air con lines done in aluminium tube but I'll have to scrap some of those and go flexible.
Regards Mando.
#73 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 01 February 2020 - 06:25 PM
Attached File  DSCN0502.jpg   150.53K   12 downloads
Attached File  IMG_0125.jpg   162.14K   12 downloads
Attached File  IMG_0126.jpg   188.04K   12 downloads
Attached File  IMG_0127.jpg   151.67K   12 downloads
#74 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 02 February 2020 - 09:47 AM
Nice work Mando, glad you got back on the horse so quick
Happy building
Cheers, Tom
#75 Cook
Cook
  • 1,535 posts
Posted 02 February 2020 - 10:10 AM
+1.  Really happy for you to be getting stuck into it.  I'm sure it will turn out a treat.  Cheers Ron
