LX Hatch Complete Restoration
484 replies to this topic
#101 _Johnnie27_
_Johnnie27_
Posted 14 July 2020 - 06:20 PM
Hey Jeff,
Can I ask who you got the rear flares from. From your pics they seem to NOT curl up at the rear.
Need to get a set of rears for my project as the ones supplied need massive rework to get them to fit.
Thanks,
 enricks fiberglass in NSW makes very very good stuff (might help)
https://ernicks-fibr...medium=referral
#102 hatchssv8
hatchssv8
  • 358 posts
Posted 15 July 2020 - 12:33 PM
 I am not so sure about that!!
#103 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 15 July 2020 - 04:26 PM
Attached File  DSCN0518.jpg   141.97K   16 downloads
Hi Joe,
I tried to find the receipt for the new rear spoiler I bought but no luck.
I think it may have been Ernicks.
It's already had some work done to it but still needs more.
Regards Mando.
#104 Rockoz
Posted 16 July 2020 - 10:47 AM
Grem Warrinton is supposed to be able to produce very good flares.
His moulds are very low in the generation scheme of things, so have less inherent flaws.
The higher the generation, the greater the flaws, particularly closing up the distance at the bottom of the flares.
They become tighter with each progressive generation.
However.
There have been some problems with Grem regarding the time he takes to make them.
He is suffering from MS, and has good weeks and bad weeks.
He has also had some very dissatisfied Torana customers in particular that he seems to have over reacted to.
But when you get the bits, they are apparently the closest fit.
#105 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 16 July 2020 - 02:29 PM
Hi Rob,
is Grem Warrinton from Ernicks?
Regards Mando.
#106 oh five
oh five
  • 15 posts
Posted 16 July 2020 - 07:38 PM
Hi Rob,
Regards Mando.
No Grem is in QLD I believe, and Ernicks is in Tarren point Sydney and great to deal with. All I can add to this is I purchased a Ernicks kit for my 4 door without the rear spoiler as I used a Rare spares plastic item and the fit from ernicks was absolutely perfect. Pics in a build thread to come soon.
Edited by oh five, 16 July 2020 - 07:39 PM.
#107 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 16 July 2020 - 08:36 PM
I brought the ernicks kit for my LH.
I have fitted the rear flares, Bob tail and the scoop.
Rear flares fit great no issues at all to make em line up.
Bob tail I had an issue with my lock center not lining up with my boot lock, I had to cut out and adjust it to work.
Scoop fit great.
Can't play with rest until cat off rotisserie
Hope that helps
#108 arrimar
arrimar
  • 3,134 posts
Posted 17 July 2020 - 08:03 AM
Hope that helps
I was going to post a pic of a cat on a rottisserie but there's kids and vegans to think of. 😁
#109 CI 0308
CI 0308
  • 737 posts
  • Car:77 LX SS, VX SS
Posted 17 July 2020 - 08:37 AM
You will find Grems front flares close in at the bottom so if you put wide tyres on the front they will hit. Plus I have seen his is very very difficult to deal with.
#110 CI 0308
CI 0308
  • 737 posts
Posted 17 July 2020 - 08:56 AM
The green car are Gem's front flares. See how the bottom of the flare goes in towards the tyre. The originals never did that and will foul a wide wheel. The originals widened out for clearance. I used repliglass fronts although they needed a bit of work. And I run 10s on the front.fd8e0b561d87f61d2edea960d4332451.jpg82578ec6ac07b661cf9fb8e828d91983.jpg764b9cb8b907f2a12b0473c8cc61c5ae.jpg
#111 Berro
Berro
  • 16 posts
  • Name:Jason Berard
  • Car:Torana UC/LX
Posted 17 July 2020 - 03:16 PM
I cut heaps out of mine too. Makes a big difference. Make sure you also remove and weld up the inner lip on the firewall if you want bigger profile rims later.
#112 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 18 August 2020 - 08:52 PM
Attached File  DSCN0534.jpg   101.88K   14 downloads
Attached File  DSCN0538.jpg   162.69K   13 downloads
Attached File  DSCN0539.jpg   103.08K   13 downloads
Attached File  DSCN0542.jpg   100.07K   12 downloads
Attached File  DSCN0545.jpg   109.98K   12 downloads
Attached File  DSCN0541.jpg   133.2K   10 downloads
Attached File  DSCN0532.jpg   124.7K   11 downloads
Attached File  DSCN0531 (2).jpg   118.46K   12 downloads
I went to see the car today.
It's been taken back to metal throughout and primed ready for rust repairs.
You get to see things differently when every scrap of paint has been removed.
They cut the floor on both sides so the chassis rails could be straightened.
Regards Mando.
#113 Hatchback13
Hatchback13
  • 193 posts
Posted 18 August 2020 - 10:19 PM
Hi mando, great looking hatch and build, that’s extensive body work that looks like it’s being done very professionally, may I ask where you are having it done? Also is the bonnet skin being removed or replaced or remade? I have a frame with no skin on, it was a crazy idea 15 years ago to make a perspecs skin! Haha crazy 80’s theme that I remember. Cheers.
#114 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 19 August 2020 - 01:51 PM
Hi Brad,
the guy that's working on the car is about half an hour past Gawler.
The bonnet skin was removed because it looked like there was some rust between the frame and skin.
Everything  looked OK, but luckily he peeled off the skin because there was quite a bit of rust
which he grit blasted and then primed before putting the skin back on.
Regards Mando.
#115 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 19 August 2020 - 02:00 PM
Here are some pictures...
Attached File  IMG_5663.jpg   39.83K   10 downloads
Attached File  IMG_5673.jpg   43.76K   10 downloads
Attached File  IMG_5674.jpg   67.07K   12 downloads
Attached File  IMG_5675.jpg   58.07K   10 downloads
Attached File  IMG_5676.jpg   60.33K   9 downloads
Attached File  IMG_5677.jpg   55.8K   10 downloads
Attached File  IMG_5678.jpg   46.06K   10 downloads
Attached File  IMG_5679.jpg   48.82K   11 downloads
Attached File  IMG_5680.jpg   51.83K   11 downloads
Attached File  IMG_5664.jpg   39.76K   11 downloads
Regards Mando.
#116 Hatchback13
Hatchback13
  • 193 posts
Posted 19 August 2020 - 08:40 PM
Pretty sure I know who you mean, he does great work, if it’s the one.
Great pictures and some great work being done.
Looking forward to watch the progression, cheers
#117 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 09 September 2020 - 05:24 PM
Things have been slow, so I thought I'd post some pictures
of my booster and clutch fluid reservoir I got together this week.
Attached File  IMG_0367.jpg   118.24K   11 downloads
Attached File  IMG_0370.jpg   131.04K   11 downloads
Attached File  IMG_0371.jpg   143.79K   11 downloads
Attached File  IMG_0373.jpg   95.71K   11 downloads
Regards Mando.
#118 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 10 September 2020 - 03:14 PM
I went to the body shop today to see how things are going.
The guy's are making good progress with the prep.
Attached File  DSCN0546.jpg   131.31K   12 downloads
Attached File  DSCN0547.jpg   84.6K   12 downloads
Attached File  DSCN0548.jpg   95.95K   10 downloads
Attached File  DSCN0550.jpg   101.63K   14 downloads
Attached File  DSCN0552.jpg   131.62K   12 downloads
Attached File  DSCN0553.jpg   86.96K   12 downloads
Attached File  DSCN0554.jpg   106.59K   11 downloads
Regards Mando.
#119 arrimar
arrimar
  • 3,134 posts
Posted 10 September 2020 - 04:01 PM
Looking good. Love it all fresh and ready to go.
Remind them about a front bracket for the console.
#120 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 10 September 2020 - 07:00 PM
Nice progress Mando,
Interesting workshop with the Falcon on the book shelf and any idea what is the engine to the left? Is that what a Hemi looks like?
Enjoy, Tom
#121 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 12 September 2020 - 04:01 PM
Time to put the motor together.
Started with a few coats of rocket red.
Attached File  IMG_0375.jpg   157.9K   15 downloads
Attached File  IMG_0377.jpg   162.36K   15 downloads
Attached File  IMG_0379.jpg   186.33K   16 downloads
Attached File  IMG_0374.jpg   158.74K   13 downloads
Regards Mando.
#122 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 12 September 2020 - 04:10 PM
Thanks Arrimar,
I'll have to sort that out at assembly time.
The standard bracket won't work.
The tunnel has had a bulge installed to take the tremec gearbox.
Enjoy, Tom
I'll ask the guy's at the workshop  when I go back in about two weeks Tom.
Regards Mando.
#123 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 12 September 2020 - 07:11 PM
Happy with the painting today.
Gearbox and bell housing look a grey colour but it looks a nice alloy colour in the flesh.
Attached File  IMG_0376.jpg   127.59K   9 downloads
Attached File  20200912_161712.jpg   117.53K   9 downloads
Attached File  20200912_161651.jpg   146.87K   9 downloads
Regards Mando
#124 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
  • Car:LJ 2 door, UC hatch
Posted 12 September 2020 - 07:40 PM
Wow very nice work mate its going to look brand new installed, That gear box looks huge !!!
#125 rexy
  • 3,834 posts
Posted 12 September 2020 - 08:29 PM
Enjoy, Tom
A flathead in front of the stinking clevo?
