The Sally Report
1003 replies to this topic
#251 sibhs
Posted 28 May 2020 - 09:12 PM
Great work Marty-very motivating.  :clap:
Cheers Stuart
Evening All,
The inner rear lower guard is very sad. Thought I'd have a go at making another.
Firstly the circle indents, I was going to make some die's from wood but thought I'd hunt around the shed for an easier option.
I found an Aussie box bearing which was a little too small, then found a land cruiser outer bearing cone which increased the diameter. Now for the female part.
Attached File  IMG_1068 (1).jpeg   195.13K   13 downloads
Grabbed an old fly wheel and turned it over to find a perfect female match, lets give it a go.
Attached File  IMG_1105.jpeg   192.73K   9 downloads
Marked out the centres and placed it all in the press and out comes a pretty good copy.
Attached File  IMG_1107.jpeg   151.68K   7 downloads
Attached File  IMG_1108.jpeg   139.59K   7 downloads
Attached File  IMG_1109.jpeg   149.22K   7 downloads
Attached File  IMG_1111.jpeg   197.03K   7 downloads
Next into the bender and it's starting to take shape.
Attached File  IMG_1112.jpeg   156.75K   11 downloads
Attached File  IMG_1113.jpeg   104.84K   6 downloads
Attached File  IMG_1114.jpeg   187.43K   7 downloads
If this works out I'll look forward to having a crack at the rear inner beaver.
Edited by sibhs, 28 May 2020 - 09:13 PM.
#252 Ice
Posted 28 May 2020 - 09:21 PM
Now i see why you call your self ONLY a Handyman ✌️
#253 rodomo
Posted 28 May 2020 - 09:27 PM
You can do it! :spoton:
Right now I'm feeling your pain with the front lower guard repairs. I've spent 3 nights out there at my pace (beer, smoke do a bit, watch a bit of NCIS, smoke beer) to get the repair piece to line up to the door and sill before I try and attach it to the guard.
Having said that, the Rare's piece is a good start rather than making the whole thing from start.
#254 sibhs
Posted 28 May 2020 - 09:41 PM
Hi Rob, I can't bare to look at the lower guard ATM. I'm hoping I can get a good second hand one.  I think I've screwed the Rares one by folding over the edges and trying to sharpen the swage lines.
#255 claysummers
Posted 28 May 2020 - 09:56 PM
Genius
#256 _LONA-CK_
_LONA-CK_
Posted 29 May 2020 - 08:11 AM
Hi Marty send me your number and I will send you some pics of what I have laying around collecting dust and rust,,, I know I have a really good inner rear beaver here, bottoms of original guards, and a heap of other cuts.
Cheers gong 0478847765
#257 RallyRed
Posted 29 May 2020 - 08:30 AM
Just caught up on this thread...amazing work. Very impressive and you have some serious patience!.
Regarding the shifter overhaul,  did you identify the key bits that take it back to "NOS" slop levels..i.e nice and tight?  Ta
#258 sibhs
Posted 31 May 2020 - 09:26 PM
Genius
It's a fine line between genius and crazy. Not sure what side I'm on?
Cheers gong
I always appreciate your help John and looking forward to receiving the package. Marty
Thanks Col. This shifter seemed very tight and had little to no wear in the usual spots so hoping it'll just work.
Heres a few bits and pieces I've done this week.
Ran a chain through the rails to make sure there's no more crap in there.
Attached File  IMG_1172.jpeg   142.6K   7 downloads
Attached File  IMG_1173.jpeg   104.31K   8 downloads
Then threaded the chain through a scourer for extra cleaning. This didn't end well with the scourer coming off  30 cm in on the first pull. Managed to free it with a flexible grabber and forget trying that again.
Attached File  IMG_1174.jpeg   95.59K   6 downloads
Bought a proper steel hole saw.
Attached File  IMG_1175.jpeg   114.34K   7 downloads
Attached File  IMG_1176.jpeg   114.99K   6 downloads
Finally got the stuck bolts out of the lower wish bone and found the holes have elongated. Two pics are of a good one and bad one. I think I'll get another one rather than trying to fix.
Attached File  IMG_1185.jpeg   151.03K   6 downloads
Attached File  IMG_1186.jpeg   154.58K   8 downloads
Also got the zinced bracket onto my new cable. This was tricky.
Attached File  IMG_1189.jpeg   51.52K   6 downloads
And the bracket onto fuse box. Easy
Attached File  IMG_1190.jpeg   78.3K   7 downloads
Things will slow down because I'm going away for a few weeks.
#259 46Crab
46Crab
  • 16 posts
  • Car:LH Sedan
Posted 31 May 2020 - 10:00 PM
Good job Marty. Your bloody keen and dedicated mate, I reckon that car had more rust than metal in it.
Edited by 46Crab, 31 May 2020 - 10:00 PM.
#260 sibhs
Posted 01 June 2020 - 10:41 AM
Thanks Crab,
It has had a lot of rust but not as bad as some i've seen. I'm on the down hill run and there is now more metal than rust.
#261 sibhs
Posted 01 June 2020 - 09:23 PM
Got a little rust in the rear of wheel guard. Firstly had to clean the guard so I can see what's required.
Attached File  IMG_1195.jpeg   133.8K   14 downloads
Attached File  IMG_1196.jpeg   188.12K   13 downloads
Attached File  IMG_1198.jpeg   248.83K   15 downloads
Attached File  IMG_1199.jpeg   187.51K   11 downloads
Attached File  IMG_1200.jpeg   173.22K   7 downloads
Attached File  IMG_1197.jpeg   153.5K   5 downloads
Some of the bits used to shape the pieces.
Attached File  IMG_1204.jpeg   292.31K   7 downloads
This copper water pipe is proving very handing as a heat sink. I've just flattened the ends.
Attached File  IMG_1205.jpeg   145.93K   7 downloads
Attached File  IMG_1207.jpeg   137.31K   5 downloads
#262 sibhs
Posted 01 June 2020 - 09:38 PM
Bit more rust around the tail light.
Attached File  IMG_1211.jpeg   202.03K   7 downloads
Attached File  IMG_1214.jpeg   204.2K   6 downloads
Attached File  IMG_1215.jpeg   195.93K   8 downloads
Attached File  IMG_1216.jpeg   184.55K   8 downloads
Not sure how you crack the handbrake mount but had to grind out the cracks, jack-up from below and weld.
Attached File  IMG_1217.jpeg   258.54K   7 downloads
Attached File  IMG_1218.jpeg   241.66K   7 downloads
Attached File  IMG_1219.jpeg   200.51K   8 downloads
Attached File  IMG_1220.jpeg   242.45K   7 downloads
Attached File  IMG_1221.jpeg   233.42K   7 downloads
#263 lctriples
lctriples
  • 414 posts
  • Name:paul
Posted 02 June 2020 - 10:25 AM
Popeye may have been previous owner and didn't know his strength when putting handbrake on! Great work as usual marty!
Edited by lctriples, 02 June 2020 - 10:25 AM.
#264 claysummers
Posted 02 June 2020 - 02:23 PM
Too many hand brakeys?
#265 Shiney005
Posted 02 June 2020 - 02:31 PM
No such thing Clay.  :)
#266 sibhs
Posted 03 June 2020 - 09:22 PM
Decided to do some panel beating on the rear guard while the guts of the boot are out. This way I can stick my arm up from below rather than working from above later in the build.
I took a heap of pics, one each time I did a bit and gives you an idea of progress. Very happy how its coming along, this took about two hours.
I used a powder guide coat and there's a picture of the tools used.  It's a shame some butcher used 36 grit on the panel at some stage. That grade of paper should be banned from panel shops.
First couple of pics are just washing it down from the KBS. I worked on the top half of panel first.
Last pic shows it after re-applying KBS.
Attached File  IMG_1224.jpeg   61.79K   12 downloads
Attached File  IMG_1225.jpeg   85.28K   9 downloads
Attached File  IMG_1226.jpeg   59.75K   8 downloads
Attached File  IMG_1227.jpeg   83.28K   8 downloads
Attached File  IMG_1228.jpeg   65.07K   8 downloads
Attached File  IMG_1229.jpeg   65.06K   8 downloads
Attached File  IMG_1230.jpeg   85.38K   8 downloads
Attached File  IMG_1231.jpeg   59.38K   8 downloads
Attached File  IMG_1232.jpeg   62.34K   8 downloads
Attached File  IMG_1233.jpeg   60.65K   6 downloads
Attached File  IMG_1234.jpeg   56.79K   7 downloads
Attached File  IMG_1235.jpeg   57.65K   6 downloads
Attached File  IMG_1236.jpeg   64.31K   6 downloads
Attached File  IMG_1237.jpeg   58.28K   6 downloads
Attached File  IMG_1238.jpeg   52.83K   6 downloads
Attached File  IMG_1239.jpeg   57.52K   6 downloads
Attached File  IMG_1240.jpeg   67.23K   7 downloads
Attached File  IMG_1241.jpeg   60.31K   7 downloads
Attached File  IMG_1242.jpeg   61.5K   7 downloads
Attached File  IMG_1243.jpeg   61.36K   7 downloads
Attached File  IMG_1244.jpeg   59.76K   8 downloads
Attached File  IMG_1245.jpeg   63.5K   7 downloads
Attached File  IMG_1246.jpeg   62.29K   7 downloads
Attached File  IMG_1247.jpeg   58.59K   7 downloads
Attached File  IMG_1248.jpeg   59.31K   6 downloads
Attached File  IMG_1249.jpeg   59.48K   6 downloads
Attached File  IMG_1250.jpeg   58.88K   7 downloads
#267 Potta
Posted 04 June 2020 - 02:15 AM
Love your work as always mate.
#268 sibhs
Posted 19 July 2020 - 10:35 PM
Hi Guys,
Back from holiday in Exmouth and Shark Bay then had a family gathering at my place so I wasn't allowed to make any mess.
Finally back into it but just putting along.
While I couldn't make a mess I did a bit of pottering in the back workshop on some little bits.
Cleaned up the reverse wires.
Attached File  IMG_1828.jpeg   316.69K   8 downloads
Attached File  IMG_1829.jpeg   411.12K   8 downloads
and the rear number plate light.
Attached File  IMG_1824.jpeg   273.96K   7 downloads
Attached File  IMG_1825.jpeg   239.85K   7 downloads
Attached File  IMG_1827.jpeg   371.71K   7 downloads
Cut off the dags from my moulded seat knobs and polished my knob end!!!!
Attached File  IMG_1821.jpeg   168.07K   7 downloads
Attached File  IMG_1823.jpeg   155.98K   7 downloads
#269 sibhs
Posted 19 July 2020 - 10:47 PM
Cleaned and assembled the brake block
Attached File  IMG_1818.jpeg   186.4K   10 downloads
Attached File  IMG_1820.jpeg   192.71K   8 downloads
I noticed that the rear passenger guard needed pushing out on its crease line. It was a hard spot to get into and put any pressure on. I made a gismo that I could wind out and then I slapped the outside panel along the edge to bring it out. It has made it better.
Knife edged a bit of 'T' bar and welded on some threaded rod.
Attached File  IMG_1906.jpeg   68.69K   7 downloads
Attached File  IMG_1907.jpeg   74.78K   7 downloads
Attached File  IMG_1909.jpeg   93.69K   9 downloads
Attached File  IMG_1910.jpeg   55.42K   7 downloads
Before I pushed out the crease I drew the line on the body by using electrical conduit.
Attached File  IMG_1903.jpeg   60.52K   8 downloads
Attached File  IMG_1904.jpeg   46.12K   9 downloads
#270 sibhs
Posted 22 July 2020 - 11:13 PM
I've got myself an engine.
Picked up a 173 with a CD prefix so it won't be out of place in the LC. The engine had been fully reconditioned 4 years ago but never started. They'd spent $5700 on it and it cost me $1500 and a four hour drive to pick it up.
The build receipt didn't explain cam and head chambers or compression so I've dropped it off to my engine builder to pull the sump and head and check it out.
Hopefully most of it's good enough for my needs. I'll supply the correct sump and rocker cover when it's ready. Hopefully in a few weeks I get some news that it's a good block to start with.
Once I stripped the external parts off i gave it a paint strip.
Attached File  IMG_1920.jpeg   106.93K   10 downloads
Attached File  IMG_1930.jpeg   127.29K   8 downloads
First round.
Attached File  IMG_1934.jpeg   110.62K   8 downloads
Second round of sripper.
Attached File  IMG_1937.jpeg   113.9K   9 downloads
Back in the trailer.
Attached File  IMG_1993.jpeg   101.36K   8 downloads
At the engine builders.
Attached File  IMG_1994.jpeg   104.11K   8 downloads
#271 claysummers
Posted 23 July 2020 - 12:11 AM
Sounds like a bloody nice score Marty.
#272 bat 53
bat 53
  • 527 posts
  • Name:albert
  • Car:lc gtr
Posted 23 July 2020 - 10:25 AM
beat me to it
#273 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 23 July 2020 - 08:42 PM
Nice score  :spoton:
Edited by Gatti, 23 July 2020 - 08:42 PM.
#274 sibhs
Posted 29 July 2020 - 10:59 PM
Made up the section that sits at the rear of tyre well.
Again just using a shape I had lying around which was a press plate. Unfortunately I couldn't find a female part so got the router out and cut the shape in a chunk of wood.
Attached File  IMG_1970.jpeg   69.18K   10 downloads
Attached File  IMG_1971.jpeg   70.19K   9 downloads
Attached File  IMG_1972.jpeg   100.03K   9 downloads
Managed to remove most of the creases by squashing them in the press.
Attached File  IMG_1973.jpeg   68.24K   9 downloads
Attached File  IMG_1974.jpeg   77.66K   8 downloads
Attached File  IMG_1977.jpeg   53.48K   8 downloads
Attached File  IMG_1978.jpeg   58.57K   8 downloads
Attached File  IMG_2032.jpeg   78.84K   8 downloads
#275 sibhs
Posted 29 July 2020 - 11:14 PM
I'm enjoying this rear end work. There's plenty of assembling all the parts to trial fit and then making the missing parts. It's all starting to come together.
Big thank-you to a couple of guys on this forum who have willingly donated rust replacement parts. This has helped immensely and keeps the project moving forward.
Welding has been getting so much better with this lower guard looking amazing. You'll notice the heat marks around the welds are kept within 5-10mm by laying down 4 spots then hitting it with compressed air and moving my way along.
Sprayed with Coopers paint stripper this black paint just falls off.
Attached File  IMG_2002.jpeg   86.95K   8 downloads
Attached File  IMG_2013.jpeg   59.96K   9 downloads
Attached File  IMG_2015.jpeg   86.01K   9 downloads
Some of my best welds right here.
Attached File  IMG_2016.jpeg   56.97K   10 downloads
Little bit of braising rod used to fill a gap.
Attached File  IMG_2019.jpeg   64.7K   9 downloads
Attached File  IMG_2020.jpeg   59.65K   9 downloads
Edited by sibhs, 29 July 2020 - 11:15 PM.
