The Sally Report
1003 replies to this topic
#276 sibhs
Posted 29 July 2020 - 11:29 PM
The inner guard piece I made has finally gone in. Also had to guess the rear section shape which had totally rusted away. I used the piece from the right hand side as a guide. This bit supports the rear beaver shape.
I'm lucky I've got a torana to check things with, I almost forgot to put the drain slots in the bottom.
Attached File  IMG_1986.jpeg   45.33K   11 downloads
Attached File  IMG_1988.jpeg   45.15K   9 downloads
Attached File  IMG_1996.jpeg   80.52K   9 downloads
Attached File  IMG_1997.jpeg   71.75K   9 downloads
Attached File  IMG_1998.jpeg   90.86K   9 downloads
Attached File  IMG_2022.jpeg   66.31K   9 downloads
Attached File  IMG_2024.jpeg   61.83K   9 downloads
Attached File  IMG_2025.jpeg   61.17K   11 downloads
Attached File  IMG_2027.jpeg   49.56K   11 downloads
Attached File  IMG_2029.jpeg   59.61K   10 downloads
Made up the support angle to hold the boot floor up.
Attached File  IMG_2062.jpeg   64.04K   13 downloads
#277 claysummers
Posted 30 July 2020 - 10:59 AM
Nice work Marty. Can see you are enjoying it.
#278 Rockoz
Posted 30 July 2020 - 06:22 PM
Awesome stuff.
Cant wait to get back into fixing my un named project.
Its from the same era.
You guys will hate me when I show how little rust it has even after sitting in a paddock for more than 5 years.
#279 Ice
Posted 30 July 2020 - 07:40 PM
Your getting good at this welding kaper ✌️
#280 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 30 July 2020 - 08:55 PM
Kicking goals Marty
#281 rodomo
Posted 05 August 2020 - 11:19 PM
Getting there...……………….bigger job than I had :huh:
#282 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 06 August 2020 - 07:35 PM
Marty, can i ask how the Rares outer l/H 1/4 panel fitted mate, good or not ? We're chasing 1 of the bolts like in your brake failure switch for an lc, if anyone has 1 for sale. & there was someone who was making & selling the boot light switch bracket, does anyone remember who it was, chasing 1 of those now to. Thanks, car is looking good to Marty. Gary.
#283 sibhs
Posted 06 August 2020 - 10:18 PM
Thanks guys.
Gary if you're talking about the rear lower Rares quarters, I was happy with both sides. I have read of people not being happy. Maybe I missed something.
I had to join them in between the swage lines.
#284 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 06 August 2020 - 10:49 PM
Yep, that's the bits Marty. Gary.
#285 sibhs
Posted 09 August 2020 - 09:57 PM
Decided to drop some parts in molasses. This is definitely easier than sand blasting but this did take three weeks in the bucket.
Put a bit of paint stripper on what paints left on then after its all washed clean the bits were treated with KBS rust blast.
Attached File  IMG_1895.jpeg   84.07K   7 downloads
Attached File  IMG_1897.jpeg   51.34K   6 downloads
Attached File  IMG_2003.jpeg   74.35K   6 downloads
Attached File  IMG_2104.jpeg   134.41K   7 downloads
Attached File  IMG_2110.jpeg   73.11K   6 downloads
#286 sibhs
Posted 09 August 2020 - 10:10 PM
Fixing these lower rear mud guard pieces has proven tricky but they are done and in. This is the passenger side where I used a bit of bitumen coated aluminium to mould into the shape required. Then transfer that to some steel and make up the piece. Had to ad a bit here and there.
Attached File  IMG_2094.jpeg   52.02K   9 downloads
Attached File  IMG_2095.jpeg   73.76K   7 downloads
Attached File  IMG_2096.jpeg   83.67K   8 downloads
Attached File  IMG_2097.jpeg   50.13K   8 downloads
Attached File  IMG_2098.jpeg   57.77K   8 downloads
Attached File  IMG_2099.jpeg   51.66K   8 downloads
Attached File  IMG_2100.jpeg   52.79K   7 downloads
Attached File  IMG_2101.jpeg   56.18K   9 downloads
Attached File  IMG_2107.jpeg   55.35K   8 downloads
Attached File  IMG_2111.jpeg   64.17K   9 downloads
#287 sibhs
Posted 09 August 2020 - 10:16 PM
Drivers side next to spare wheel well.
Attached File  IMG_2112.jpeg   107.86K   8 downloads
Attached File  IMG_2113.jpeg   53.57K   7 downloads
Attached File  IMG_2114.jpeg   53.2K   8 downloads
Attached File  IMG_2115.jpeg   92.39K   8 downloads
Attached File  IMG_2116.jpeg   83.99K   8 downloads
Attached File  IMG_2117.jpeg   85.24K   7 downloads
Attached File  IMG_2118.jpeg   76.92K   7 downloads
Attached File  IMG_2128.jpeg   54.37K   8 downloads
#288 rodomo
Posted 09 August 2020 - 10:42 PM
:spoton:
#289 claysummers
Posted 09 August 2020 - 10:54 PM
Kicking goals Marty
#290 meanmachine72
meanmachine72
  • 2,050 posts
  • Name:Jono
Posted 10 August 2020 - 11:14 AM
https://www.ebay.com...9AAAOSw3SdeHiAy
#291 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 10 August 2020 - 06:53 PM
Thanks Johnno, much appreciated mate.
#292 sibhs
Posted 11 August 2020 - 10:17 PM
The Inner beaver which I was going to try and make is a critical part which helps you line up lots of the rear panels.
Thank-fully John donated one to my build and I'm sure glad he did.
After I had cleaned and prepped it. Then it was screwed together along with all the other parts making adjustments along the way.
It's important to assemble all parts in the correct order so you can rust treat bits the best you can.
When it was all ready I applied KBS two coats and copper coated the edges.
Anyway I hope these photos tell the story.
Attached File  IMG_1810.jpeg   94.71K   11 downloads
Attached File  IMG_1811.jpeg   95.73K   10 downloads
Attached File  IMG_1949.jpeg   57.46K   8 downloads
Attached File  IMG_1950.jpeg   49.75K   8 downloads
Attached File  IMG_1958.jpeg   55.15K   8 downloads
Attached File  IMG_1960.jpeg   57.91K   8 downloads
Attached File  IMG_1978 (1).jpeg   55.49K   8 downloads
Attached File  IMG_2045.jpeg   96.72K   8 downloads
Attached File  IMG_2132.jpeg   67.19K   8 downloads
Attached File  IMG_2133.jpeg   67.71K   8 downloads
Attached File  IMG_2135.jpeg   62.75K   8 downloads
Attached File  IMG_2142.jpeg   52.99K   8 downloads
Attached File  IMG_2143.jpeg   77.53K   9 downloads
#293 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 11 August 2020 - 10:30 PM
That's some nice inner beaver
#294 rodomo
Posted 11 August 2020 - 11:05 PM
Said the Bishop to the barmaid? B)
#295 Rockoz
Posted 12 August 2020 - 03:25 PM
Are you using clecos at all?
I bought a heap of them and they are great for trial fitting things.
Only a 1/8 hole as well.
You may already have used them, if so, my bad memory is my excuse.
#296 sibhs
Posted 15 August 2020 - 08:44 PM
Hi Rob,
I'm not using clecos. Had a look at them on the net and think they have their place in a build and if I was just starting I might of bought some. They would get it the way a bit being so long and they're a two step fit with a hole needed drilling first. Tek screws are one step and less likely to get it the way.
Just finished my longest straight flat weld. Got the rear beaver fitted and very happy with these rear-end Rare Spares rust panels.
Attached File  IMG_1943.jpeg   51.79K   11 downloads
Attached File  IMG_1959.jpeg   59.69K   11 downloads
Setting up to paint strip the beaver.
Attached File  IMG_2105.jpeg   83.66K   10 downloads
The paint just slides off way too easily so KBS the internal bits is a must. Wouldn't trust Rares black etch for long rust resistance.
Attached File  IMG_2106.jpeg   99.22K   9 downloads
Attached File  IMG_2108.jpeg   95.01K   9 downloads
Attached File  IMG_2144.jpeg   78.42K   9 downloads
Attached File  IMG_2146.jpeg   58.13K   11 downloads
Attached File  IMG_2150.jpeg   65.69K   11 downloads
Getting set-up for the big weld.
Attached File  IMG_2152.jpeg   67.42K   9 downloads
Attached File  IMG_2156.jpeg   46.79K   10 downloads
This join deserves a new tip.
Attached File  IMG_2157.jpeg   97.27K   9 downloads
Measured and drilled number plate holes using original as template.
Attached File  IMG_2199.jpeg   58.83K   10 downloads
Part way through grinding, the grind took longer than the weld.
Attached File  IMG_2178.jpeg   64.08K   10 downloads
Attached File  IMG_2208.jpeg   61.8K   10 downloads
Attached File  IMG_2209.jpeg   56.41K   11 downloads
Attached File  IMG_2217.jpeg   49.16K   10 downloads
Attached File  IMG_2160.jpeg   52.57K   9 downloads
Applied KBS down into the beaver to flow into this welded area so hopefully will never rust again
Attached File  IMG_2213.jpeg   66.14K   9 downloads
Once its all Rust Blasted it looks pretty good.
Attached File  IMG_2210.jpeg   82.45K   9 downloads
Ran a one inch bead of weld down at the bottom to imitate an original join
Attached File  IMG_2211.jpeg   54.56K   10 downloads
#297 Shadow17
Shadow17
  • 143 posts
  • Name:James
  • Car:lj
Posted 15 August 2020 - 09:30 PM
Hi Marty, Spot on as usual and great pics of the job gives me the insights over how to proceed with mine that's next after the drivers door.
#298 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 15 August 2020 - 09:52 PM
Hi Rob,
Great work Marty.
Big job. Killing it
#299 RallyRed
Posted 16 August 2020 - 08:25 AM
As usual, great work !!
#300 sibhs
Posted 16 August 2020 - 10:24 AM
Here's the spare wheel well workings. This Rares panel looked very regimented compared to original but only required a few hand formed bends to get it looking good. Plus a bit of hammer work to stretch it to meet the rear quarter.
Attached File  IMG_1951.jpeg   60.5K   9 downloads
Attached File  IMG_1953.jpeg   51.55K   8 downloads
Attached File  IMG_1975.jpeg   47.84K   8 downloads
Attached File  IMG_2037.jpeg   71.49K   8 downloads
Attached File  IMG_2039.jpeg   107.79K   8 downloads
Attached File  IMG_2048.jpeg   51.6K   8 downloads
Attached File  IMG_2049.jpeg   44.19K   8 downloads
Attached File  IMG_2060.jpeg   48.13K   9 downloads
Attached File  IMG_2131.jpeg   44.87K   8 downloads
Attached File  IMG_2201.jpeg   60.76K   8 downloads
Attached File  IMG_2202.jpeg   59.48K   8 downloads
Attached File  IMG_2207.jpeg   63.86K   8 downloads
Attached File  IMG_2212.jpeg   60.39K   8 downloads
Attached File  IMG_2218.jpeg   59.43K   9 downloads
