The Sally Report
1003 replies to this topic
#576 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 844 posts
  • Name:JASO
Posted 05 October 2021 - 12:49 PM
Thanks Marty, as above. :)
#577 sibhs
Posted 09 October 2021 - 11:19 PM
Painted the internal side of doors red oxide.
Fitted the rubbers to boot and doors then bolted them on the body.
Boot took a fair bit of time adjusting and trialing spacers etc. The bonnet was a PITA and I was just about to rip the Rare Spares hinges out when I worked out how the get the back of bonnet down.
Attached File  IMG_6119.jpeg   171.23K   12 downloads
Attached File  IMG_6120.jpeg   105.64K   9 downloads
Attached File  IMG_6153.jpeg   212.78K   11 downloads
I found the rares instructions useless.
Attached File  IMG_6158.jpeg   154.9K   10 downloads
Made sure I fitted the window stops before doing the bodywork. Helps support the panel while blocking back.
Attached File  IMG_6159.jpeg   95.67K   11 downloads
Attached File  IMG_6160.jpeg   97.81K   9 downloads
Checking the doors are flat with body.
Attached File  IMG_6161.jpeg   77.27K   9 downloads
Getting into the boot adjusting.
Attached File  IMG_6162.jpeg   85.1K   9 downloads
Attached File  IMG_6163.jpeg   145.29K   9 downloads
Attached File  IMG_6165.jpeg   169K   11 downloads
Took about two hours of going around in circles to get bonnet flat and gapped.
Attached File  IMG_6167.jpeg   107.09K   13 downloads
Attached File  IMG_6171.jpeg   60.3K   11 downloads
Attached File  IMG_6172.jpeg   176.06K   10 downloads
Door gaps all good. Until Sally walked in and started picking little bits that wern't to her satisfaction.
Attached File  IMG_6169.jpeg   96.87K   13 downloads
Attached File  IMG_6170.jpeg   76.95K   11 downloads
And finally all panels on and gapped.
Attached File  IMG_6173.jpeg   152.45K   14 downloads
#578 purrlx
purrlx
  • 1,332 posts
  • Name:Danny
  • Car:LX hatch
Posted 10 October 2021 - 06:18 AM
awesome work, can you get the rubbers off without damaging them for paint
#579 sibhs
Posted 10 October 2021 - 09:30 AM
Hi Danny, I hope so! I only clicked them in one notch so should be able to use long nose pliers to assist.
#580 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 10 October 2021 - 12:07 PM
Top work Marty.
How hard are the bonnets to line up hey.
One of my hinges was a little loose so I put it in a press and it seems to work better but I am contemplating buying the resto country remakes as it needs an extra push once it closes to get the bonnet completely flat.
So bloody fiddly.
I see you using builders packers aswell great stuff
#581 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 844 posts
  • Name:JASO
Posted 10 October 2021 - 02:19 PM
Very nice partnership Marty :)
(Quoting) - "Door gaps all good. Until Sally walked in and started picking little bits that wern't to her satisfaction."
Thats Quality Assurance/Control :)
#582 lctriples
lctriples
  • 414 posts
  • Name:paul
Posted 11 October 2021 - 06:06 AM
Hey marty, any tips or tricks you can pass on with rares hinges, as i cant get mine to fit properly either, great work on ther build mate! Paul
#583 sibhs
Posted 13 October 2021 - 10:07 PM
Hi Paul,
Rares hinges are made from a thicker metal therefore causing a few challenges.
I made two modifications, grinding back the back edge where it touches the drip tray (make it half thickness) and slotting the rear hole to allow more downward movement. I also had to remove washer from rear bolt to get maximum movement.
Best to fit hinge and take note of where it touches the drip tray.
#584 lctriples
lctriples
  • 414 posts
  • Name:paul
Posted 14 October 2021 - 10:59 AM
Thanks Marty, appreciate that, will try what you said and see how it goes, paul
#585 jd lj
jd lj
  • 2,124 posts
  • Name:James D
Posted 26 October 2021 - 07:00 PM
Hey Marty,
Did you do any reconditioning to the heater box fan motor other than cleaning it and rezincing it?
The same with the wiper motors, is there any reconditioning of these motors that can be done to make them run like new with a bit more speed?
#586 sibhs
Posted 13 February 2022 - 08:47 PM
Hey Marty,
Hi James, Haven't been on for a while, Just cleaned the internals, greased bushs on ends and sprayed cover silver. Didn't re-zinc due to magnets attached to cover.
Full body rub down, mask-up and hi-fil again.
Attached File  IMG_6309.jpeg   146.17K   9 downloads
Attached File  IMG_6368.jpeg   139.09K   9 downloads
Attached File  IMG_6378.jpeg   153.48K   8 downloads
Attached File  IMG_6398.jpeg   109.98K   8 downloads
Attached File  IMG_6405.jpeg   146.35K   9 downloads
Attached File  IMG_6406.jpeg   168.19K   8 downloads
Attached File  IMG_6431.jpeg   138.24K   7 downloads
Attached File  IMG_6432.jpeg   96.34K   7 downloads
Attached File  IMG_6433.jpeg   184.7K   8 downloads
#587 RallyRed
Posted 13 February 2022 - 09:10 PM
Incedible work , in the garage🙂
#588 claysummers
Posted 13 February 2022 - 09:15 PM
I love that guide chalk
#589 sibhs
Posted 14 February 2022 - 03:15 PM
Once the top half is rubbed back another piece of guide tape is applied and the lower half sanded.
Attached File  IMG_6434.jpeg   81.55K   8 downloads
Attached File  IMG_6435.jpeg   139.04K   8 downloads
Attached File  IMG_6436.jpeg   125.71K   8 downloads
Attached File  IMG_6438.jpeg   117.64K   8 downloads
Attached File  IMG_6439.jpeg   103.57K   9 downloads
High points hit with the speed file.
Attached File  IMG_6440.jpeg   78.42K   8 downloads
Attached File  IMG_6441.jpeg   158.52K   8 downloads
Attached File  IMG_6442.jpeg   111.08K   10 downloads
#590 sibhs
Posted 15 February 2022 - 07:09 PM
Another round of high fill then a final test fit of bits with a few adjustments made.
Attached File  IMG_6489.jpeg   145.36K   9 downloads
Attached File  IMG_6490.jpeg   154.82K   9 downloads
Attached File  IMG_6497.jpeg   75.68K   8 downloads
Attached File  IMG_6498.jpeg   159.83K   8 downloads
Attached File  IMG_6500.jpeg   151.97K   7 downloads
Attached File  IMG_6502.jpeg   107.73K   7 downloads
#591 jd lj
jd lj
  • 2,124 posts
  • Name:James D
Posted 15 February 2022 - 07:29 PM
It's looking good Marty, well done.
#592 sibhs
Posted 15 February 2022 - 07:43 PM
Thanks James.
I had a set back on the troublesome rear quarter.
While checking the lines I could see it wasn't quit right so put a bit more bog on. Then i realised the bog was getting over 2mm thick and I needed another 2mm there so I decided to grind it off and pull the guard more. You can thank Heath for making me do this, after I read he pulled his engine out and rebuilt it after noticing something minor.
Attached File  IMG_6503.jpeg   119.51K   10 downloads
Attached File  IMG_6504.jpeg   157.76K   8 downloads
Attached File  IMG_6505.jpeg   97.39K   7 downloads
Attached File  IMG_6506.jpeg   108.72K   7 downloads
Attached File  IMG_6508.jpeg   112.74K   7 downloads
Attached File  IMG_6529.jpeg   53.52K   8 downloads
Attached File  IMG_6530.jpeg   109.23K   7 downloads
Attached File  IMG_6531.jpeg   107.42K   8 downloads
Attached File  IMG_6532.jpeg   92.56K   8 downloads
Attached File  IMG_6534.jpeg   105.47K   10 downloads
Attached File  IMG_6536.jpeg   99.08K   7 downloads
#593 Ice
Posted 15 February 2022 - 07:57 PM
2 mm you bloody perfectionist
This will be straight as an arrow this body
#594 Shiney005
Posted 16 February 2022 - 08:54 AM
What are you looking at when you have the pvc pipe down the side? Just hollow sections under it?
#595 sibhs
Posted 16 February 2022 - 02:16 PM
Hi Laurie, the pvc is used to get the line curve correct, I couldn't see the error at this stage. Not until I blocked it back and did some checks against the other side I noticed the problem. It was a case of almost there then having to take a few steps back.
#596 sibhs
Posted 16 February 2022 - 05:52 PM
Sanded and primed and I think it's pretty close now.
Attached File  IMG_6677.jpeg   103.14K   7 downloads
Sally set me up a little spot to watch Bathurst so I wouldn't get too much dust every where.
Attached File  IMG_6680.jpeg   141.26K   8 downloads
Decided to get some foam panels to insulate the garage door. Faces west and gets super hot in the arvo. Seems to make a big difference.
Attached File  IMG_6693.jpeg   116.93K   7 downloads
Attached File  IMG_6700.jpeg   152.56K   9 downloads
#597 sibhs
Posted 17 February 2022 - 06:46 PM
Hi Gene, I hope it is, but it's easy to miss something working in garage conditions.
I've been slowly progressing on the fuel tank. It's been something that when I have some bog left over or primer it gets a bit of work done to it.
Sprayed it with silver and clear and apart from the runs it came out sooo smooth. Hoping I can get this sort of finish on the car too.
Attached File  IMG_6730.jpeg   149.68K   8 downloads
Attached File  IMG_6731.jpeg   121.36K   8 downloads
Attached File  IMG_6767.jpeg   80.06K   8 downloads
Attached File  IMG_6809.jpeg   155.31K   8 downloads
Attached File  IMG_6812.jpeg   94.07K   8 downloads
Attached File  IMG_7173.jpeg   117.2K   8 downloads
Attached File  IMG_7174.jpeg   112.48K   8 downloads
Attached File  IMG_7175.jpeg   122.82K   8 downloads
Attached File  IMG_7176.jpeg   62.06K   8 downloads
Attached File  IMG_7178.jpeg   83.91K   9 downloads
I'll see if I can sand these out and polish it up otherwise I'll give it another go.
Attached File  IMG_7183.jpeg   107.02K   9 downloads
While the silver was in the gun I sprayed the mirror stem.
Attached File  IMG_7179.jpeg   59.78K   8 downloads
#598 claysummers
Posted 17 February 2022 - 07:39 PM
Hi Marty,
Bodywork coming along nicely. I don’t mind it once I get in to a rhythm.
Your tank looks a similar finish to what I did in my FB ute. I didn’t bother with boxing it. It’s only an FB after all. I found a urethane silver to go straight over Epotec that doesn’t need clear coat like most metallics do. First go I got a lot of runs but went to a 1.4 touch up gun that worked a lot better. The single application urethane had a great finish and saved me a lot of effort. I ended up doing a lot of little detail pieces with it.
#599 jd lj
jd lj
  • 2,124 posts
  • Name:James D
Posted 18 February 2022 - 04:03 AM
If you're painting the mirror stem did you do the sunvisor mounts too?
#600 sibhs
Posted 18 February 2022 - 08:17 AM
Hi Marty,
Hi Clay, I was using a 1.4 but on my big gun. I've got a touch-up gun but that only has a .6 tip. Clearing does take more work but I look at this as practice sessions for the big dance.
Hi James, I did think of that. I painted a few sets 7 years ago for the LJ so they're already on the visors and packed away ready for install.
