The Sally Report
1003 replies to this topic
#626 snuff1966
snuff1966
  • 194 posts
  • Car:LH G pack
Posted 03 March 2022 - 04:38 PM
This is gunna be good
#627 Rockoz
Posted 04 March 2022 - 10:30 AM
Never boring.
Love seeing the progress and the way you tackle things.
I eagerly await all of your updates.
Maybe my life is boring. LOL.
#628 sibhs
Posted 04 March 2022 - 05:43 PM
This is getting exciting! Very happy with result, looks so deep and glossy.
Base coat down.
Attached File  IMG_7222.jpeg   218.27K   9 downloads
Attached File  IMG_7223.jpeg   205.61K   6 downloads
Clear goes on.
Attached File  IMG_7234.jpeg   122.75K   6 downloads
Attached File  IMG_7239.jpeg   112.55K   6 downloads
Next mission is to get into the plenum chamber. You can only spray so much in here so the bits I can't get to I used a brush. Also was a bit light on in base coat in the bonnet jam near hinge so had to do that again. Really important to check base and clear with a torch to see if you miss any thing.
Attached File  IMG_7242.jpeg   205.55K   7 downloads
Attached File  IMG_7244.jpeg   146.68K   7 downloads
Then I had to see what it looks like with a bit of hardware. Hopefully this part doesn't have to come off again. It's defiantly a dirty purple and probably why not many were sold in this colour. Really needs sunlight to set it off.
Attached File  IMG_7322.jpeg   124.23K   6 downloads
Thanks again for comments and I've also had a member ring me up with some painting tips. I appreciate this because I'm only learning off YouTube vids.  My favourite advice comes from 'Paint Society'
#629 LJ RB30
LJ RB30
  • 1,058 posts
  • Name:Trevor
Posted 04 March 2022 - 07:17 PM
Always good to see colour on the car after all your hard work! :spoton:
#630 Ice
Posted 04 March 2022 - 11:42 PM
Needs more glitter poo  :)
#631 sibhs
Posted 05 March 2022 - 10:06 PM
Time to give the room another clean. This time I cleared out all the unnecessary stuff and set up a paint mixing area. Hosed out the dust and fitted spray booth air filter mesh to all gaps and intake vent. Also used on the extractor fan.
Attached File  IMG_7316.jpeg   177.53K   12 downloads
Attached File  IMG_7324.jpeg   148.45K   16 downloads
Attached File  IMG_7325.jpeg   215.42K   12 downloads
Attached File  IMG_7326.jpeg   158.22K   10 downloads
A bit more rubbing back before the under bonnet and boot are sprayed.
Attached File  IMG_7318.jpeg   183.81K   8 downloads
I've been wanting one of these for years and finally found one in a store. American made and uses toilet roll to clean air. It's probably too late but better late than never. I already have six moisture and air cleaners in the line but these are meant to be good. I've made notes on the wall for reminders on gun set-up etc.Except i'm using 800 before final coat.
Attached File  IMG_7317.jpeg   253.26K   18 downloads
#632 claysummers
Posted 06 March 2022 - 06:28 AM
I read your notes, the last one looks like frOck at end of run 8 )
#633 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 10 March 2022 - 06:42 PM
It's flick, as in if you don't trigger off. It's whatever your own painting style is though.
#634 claysummers
Posted 10 March 2022 - 07:41 PM
Of course
#635 sibhs
Posted 10 March 2022 - 08:56 PM
Correct "Flick".
I made these notes after watching some YouTube vids. I think I need to watch a few more on just metallic painting before I spray the body.
Finally finished off the dash knobs after starting them 2.5 years ago. I purchased some chrome circle stickers and was waiting until I had the clear out. They came out far better than expected.
Attached File  IMG_7412.jpeg   198.41K   9 downloads
Attached File  IMG_7427.jpeg   92.46K   8 downloads
Packed them away safe and sound.
Attached File  IMG_7442.jpeg   161.36K   7 downloads
Also cleared the bell housing after bead blasting.
Attached File  IMG_7424.jpeg   108.57K   7 downloads
#636 jd lj
jd lj
  • 2,124 posts
  • Name:James D
Posted 11 March 2022 - 03:21 AM
The bellhousing will need some rocket red overspray around the front.
Those dash knobs came up very nice.
#637 sibhs
Posted 11 March 2022 - 08:08 AM
Hi James, Yes I was planning that, thanks for reminder. I'll also scuff it first to reduce the gloss.
#638 Rockoz
Posted 11 March 2022 - 12:25 PM
Years ago I got a tip from a painter for doing metallics.
Seemed to work for me.
Put 2 or 3 steel balls in the pot. Glass marbles could work too I guess.
Give the pot a bit of a shake from time to time to get the balls rolling in the paint to keep it mixed up.
#639 sibhs
Posted 11 March 2022 - 12:35 PM
Makes sense, I just try and swirl/shake the pot every so often. Lucky for me this has a very small metallic fleck so hopefully my lack of technique won't be too noticeable.
#640 claysummers
Posted 11 March 2022 - 03:36 PM
Tip from my guru was to do the top coats perpendicular for successive coats. Left to right then up and down. Or more practically perhaps top left to bottom right then top right to bottom left.
#641 sibhs
Posted 15 March 2022 - 08:16 PM
Painted the underside of the bonnet and boot and again looks pretty good. I did get some movement on the bitumen coating on boot lid. This could of had something to do with the wax and grease remover sprayed on it. Thats when I first noticed an issue.
It looks dark and dull in the shade but comes alive in the sun.
Attached File  IMG_7409.jpeg   243.68K   15 downloads
Attached File  IMG_7411.jpeg   219.28K   12 downloads
Attached File  IMG_7416.jpeg   97.36K   10 downloads
Attached File  IMG_7417.jpeg   125.63K   9 downloads
Attached File  IMG_7418.jpeg   116.03K   15 downloads
Noticed the metallic fleck had gathered together, I think this is from applying too much paint too quickly and pooling.
Attached File  IMG_7448.jpeg   215.77K   8 downloads
Looks so much brighter in the sun.
Attached File  IMG_7452.jpeg   404.29K   14 downloads
#642 claysummers
Posted 15 March 2022 - 08:46 PM
You may find a water based wax and grease remover kinder to the bitumen Marty. Doesn't surprise a me that the regular stuff eats in to it.
#643 RIM-010
Posted 18 March 2022 - 09:49 PM
Beautiful work Marty. What is the colour?
#644 sibhs
Posted 18 March 2022 - 10:36 PM
Cheers Tim.  -  Amethyst Metallic
#645 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 18 March 2022 - 10:54 PM
Looking better, it is a great colour, those grass trees are beautiful Marty, I want to give the lawn a cut though.
#646 sibhs
Posted 21 March 2022 - 09:40 PM
When I sprayed the grey undercoat I thought I could just give it a scuff with the grey scourer but because I'm a shit spray painter it needs to be gone over with 800. So wet sand the body again. Some areas I had to go back to 400 and work my way up to 800.
Attached File  IMG_7457.jpeg   150.4K   9 downloads
Attached File  IMG_7461.jpeg   116.8K   8 downloads
Attached File  IMG_7510.jpeg   193.07K   7 downloads
Attached File  IMG_7552.jpeg   111.48K   7 downloads
Attached File  IMG_7553.jpeg   78.54K   11 downloads
Attached File  IMG_7554.jpeg   169.4K   7 downloads
Attached File  IMG_7555.jpeg   132.85K   8 downloads
Attached File  IMG_7563.jpeg   137.56K   8 downloads
#647 S pack
Posted 21 March 2022 - 09:52 PM
Getting there Marty. Won't be long now and it'll be straighter than a politician at a Mardi Gras.
BTW, good to see you got the leckie safety under control. :stirpot:
#648 sibhs
Posted 22 March 2022 - 01:33 PM
Stick to plumbing advice Dave. :spoton:
Took Grumpys advice on tapping the threads before assembly. I'm glad I did because it's a balancing act lining the bonnet screws up and to get a stuck thread would be a shit fight.
Attached File  IMG_7556.jpeg   151.52K   8 downloads
Taped up hinge area to protect while fitting.
Attached File  IMG_7557.jpeg   178.33K   7 downloads
After modifying the bonnet hinges I had them re-zinced, sprayed the springs grey and fitted.
Attached File  IMG_7560.jpeg   176.7K   7 downloads
Attached File  IMG_7561.jpeg   159.78K   7 downloads
Attached File  IMG_7562.jpeg   165.13K   7 downloads
Attached File  IMG_7564.jpeg   148.41K   9 downloads
Attached File  IMG_7490.jpeg   177.19K   8 downloads
Also got a few more bits done, I think there quality is getting better.
Attached File  IMG_7595.jpeg   266.29K   8 downloads
#649 308 Sunbird
308 Sunbird
  • 976 posts
  • Name:Stuart
Posted 22 March 2022 - 05:26 PM
Haha I sprayed my springs on my trolley jack too. Looking great Marty keep up the good work.
#650 jd lj
jd lj
  • 2,124 posts
  • Name:James D
Posted 22 March 2022 - 08:15 PM
I like the trolley jack idea for the bonnet hinge springs. They were a challenge to stretch over my jig when I did mine.
