The Sally Report
1003 replies to this topic
#601 Ice
Posted 18 February 2022 - 08:22 AM
Nup strip that tank back to bare metal  thats just not up to Marty standards  :)
#602 I'm a Red Motor fiend
  • 774 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 18 February 2022 - 12:31 PM
I wouldnt shoot clear through a 1.4, max 1.3
#603 sibhs
Posted 18 February 2022 - 09:44 PM
Hi Adam, yes I heard 1.3mm was recommended but just thought is it worth buying a new gun for .1  ????
Thanks for input.
#604 sibhs
Posted 18 February 2022 - 09:47 PM
Standards are slipping. This is only Sallys car.
#605 jpxu1
jpxu1
  • 573 posts
Posted 18 February 2022 - 11:37 PM
Jesus, and I thought the Russians were pushing boundaries  :stirpot:
#606 I'm a Red Motor fiend
  • 774 posts
  • Name:Adam
Posted 19 February 2022 - 05:51 AM
What sort of gun do you have Marty?
You may be able to buy a new nozzle, needle and air cap.
#607 sibhs
Posted 19 February 2022 - 01:50 PM
Star 4000 something.  I first bought this gun with 1.8 expecting to buy a 1.4 later as suggested by paint shop. When the time came to buy the 1.4 the paint shop couldnt supply or was more expensive than a new gun. I bought another Star with a 1.4 and never shop at that store again!
Don't tell Sally please. :-)
#608 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 19 February 2022 - 04:21 PM
Try backing the fluid off half a turn & bump up the pressure a little, you're probably just getting a double up on the curved edges which is easy to do. If you don't get it fully sorted by that, pick up your spray speed a smidge. But try the others first. Technically the bottom of the tank gets some black anyway.
That's meant for Marty, but on this topic.
#609 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 19 February 2022 - 08:15 PM
Awesome work Marty!
I've been away for a while so I got to binge the whole build to date and it's just as impressive as the last one.  Solid effort!
#610 sibhs
Posted 20 February 2022 - 09:47 PM
Thanks Gary, I think this could be the way to go. Question- Isn't the tank silver underneath??
Another coat of primer. I also fitted the trim rivets.
Again set the side line this time using fine line tape.
Rubbed back a few more panels
Attached File  IMG_6811.jpeg   57.17K   8 downloads
Attached File  IMG_6814.jpeg   66.74K   9 downloads
Attached File  IMG_6815.jpeg   64.9K   9 downloads
Attached File  IMG_6820.jpeg   70.07K   9 downloads
Attached File  IMG_6824.jpeg   131.45K   8 downloads
Attached File  IMG_6825.jpeg   92.45K   8 downloads
Here's the final undercoat using a dark grey to enhance the final colour Amythist.
Attached File  IMG_6827.jpeg   171.98K   11 downloads
Attached File  IMG_6828.jpeg   100.93K   8 downloads
Attached File  IMG_6829.jpeg   94.19K   10 downloads
Attached File  IMG_6830.jpeg   50.64K   8 downloads
Attached File  IMG_6831.jpeg   71.4K   8 downloads
Attached File  IMG_6832.jpeg   67.67K   8 downloads
#611 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 20 February 2022 - 10:07 PM
I will text you tomorrow during the day Marty, Gary.
#612 sibhs
Posted 22 February 2022 - 09:57 PM
Finally the guard is looking good.
Attached File  IMG_6859.jpeg   129.56K   11 downloads
Attached File  IMG_6862.jpeg   139.7K   11 downloads
Had another set-back. Read somewhere that the passenger door mirrors are un-usable in the position I positioned it. Decided to delete the LH mirror so welded up the holes and patched it up.
Attached File  IMG_6897.jpeg   57.63K   11 downloads
Attached File  IMG_6901.jpeg   46.05K   7 downloads
Used mastic to seal the door stopping mechanism and get it ready for paint.
Attached File  IMG_6902.jpeg   107.23K   8 downloads
More of the final undercoat applied.
Attached File  IMG_6914.jpeg   89.81K   6 downloads
Attached File  IMG_7018.jpeg   144.31K   6 downloads
Attached File  IMG_7023.jpeg   122.67K   6 downloads
Attached File  IMG_7027.jpeg   85.23K   7 downloads
Attached File  IMG_7029.jpeg   98.67K   6 downloads
Attached File  IMG_7037.jpeg   92.85K   6 downloads
#613 LJ RB30
LJ RB30
  • 1,058 posts
  • Name:Trevor
Posted 22 February 2022 - 11:10 PM
Bloody awesome mate!
#614 sibhs
Posted 23 February 2022 - 06:59 PM
Time to prep the car for final touch-ups of black underneath where I got overspray on and the engine bay. I'm going to drop the car down lower for final paint so this is my last chance to spray under here.
Attached File  IMG_7116.jpeg   115.99K   8 downloads
Attached File  IMG_7117.jpeg   131.07K   7 downloads
Attached File  IMG_7131.jpeg   175.73K   7 downloads
Attached File  IMG_7139.jpeg   184.39K   7 downloads
Attached File  IMG_7141.jpeg   162.02K   7 downloads
Attached File  IMG_7144.jpeg   154.12K   7 downloads
Attached File  IMG_7146.jpeg   172.66K   7 downloads
While the black is out I'll get some progress on these bits.
Attached File  IMG_7150.jpeg   165.02K   7 downloads
Also painted the bottom of sills because I remember I missed some bits on the LJ due to it being hard to work upside down.
Attached File  IMG_7151.jpeg   70.5K   8 downloads
Attached File  IMG_7153.jpeg   117.31K   7 downloads
Attached File  IMG_7159.jpeg   175.53K   6 downloads
Attached File  IMG_7165.jpeg   186.01K   9 downloads
Attached File  IMG_7172.jpeg   166.1K   6 downloads
#615 sibhs
Posted 23 February 2022 - 07:03 PM
Thanks Trev
#616 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 23 February 2022 - 07:32 PM
I wish I could do half the work you can do.
Amazing, well done.
Regards Mando.
#617 sibhs
Posted 27 February 2022 - 09:28 PM
Time to lower the car. Borrowed another set of stands and the mission was how to get it down to the shorter legs. Used my hydraulic trolley and all went well.
Attached File  IMG_7185.jpeg   197.09K   9 downloads
Attached File  IMG_7186.jpeg   156.13K   9 downloads
Attached File  IMG_7187.jpeg   180.94K   9 downloads
Attached File  IMG_7188.jpeg   160K   9 downloads
Attached File  IMG_7189.jpeg   181.41K   8 downloads
Attached File  IMG_7190.jpeg   154.85K   8 downloads
Attached File  IMG_7191.jpeg   162.48K   8 downloads
Attached File  IMG_7192.jpeg   201.53K   9 downloads
Attached File  IMG_7193.jpeg   186.32K   9 downloads
Attached File  IMG_7194.jpeg   160.68K   9 downloads
#618 Ice
Posted 27 February 2022 - 11:00 PM
Unorthodox but effective
love you’re style  Marty    :spoton:
#619 kudu
kudu
  • 1,492 posts
  • Car:LH SL/R 5000
Posted 28 February 2022 - 02:49 AM
I love it!!!
#620 Heath
Posted 28 February 2022 - 08:04 AM
You're a magician mate. Just fantastic work.
I was kind of enjoying the wild 80's rake on the shell dollies, though? lol
#621 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 28 February 2022 - 03:54 PM
Nice work.
I bet that's a good feeling to have it down and the bottom complete.
#622 bat 53
bat 53
  • 527 posts
  • Name:albert
  • Car:lc gtr
Posted 01 March 2022 - 10:17 AM
great job Marty
hope mines at the same stage ( promised for easter ) :clappin:
#623 sibhs
Posted 03 March 2022 - 01:18 PM
Thanks for the replies guys. Is always good to hear from people who are actually looking at this thread. Definitely a long slog on the sanding and re-sanding etc which can become boring for viewers. Hopefully that's about to change as we get read for colour.
Wash down and clean up of room and car.
Attached File  IMG_7200.jpeg   177.21K   10 downloads
Masking out for the jams.
Attached File  IMG_7211.jpeg   150.21K   8 downloads
Attached File  IMG_7214.jpeg   167.62K   8 downloads
Attached File  IMG_7216.jpeg   177.76K   8 downloads
Attached File  IMG_7217.jpeg   172.65K   8 downloads
Stay tuned to see what this looks like.
Attached File  IMG_7221.jpeg   91.67K   7 downloads
#624 Ice
Posted 03 March 2022 - 03:02 PM
Purple Rain
#625 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 03 March 2022 - 03:14 PM
Love that colour.
Regards Mando.
