The Sally Report
1003 replies to this topic
#651 sibhs
Posted 22 March 2022 - 09:04 PM
After rubbing back with 800 the panels get a bit of shine on them. I then noticed a couple of dips in the top guard so had to spray more hi-fill and sand again. Also started masking for final paint.
Attached File  IMG_7587.jpeg   146.6K   11 downloads
Attached File  IMG_7588.jpeg   138.76K   11 downloads
Attached File  IMG_7589.jpeg   129.4K   11 downloads
Attached File  IMG_7590.jpeg   144.2K   8 downloads
#652 purrlx
purrlx
  • 1,332 posts
  • Name:Danny
  • Car:LX hatch
Posted 23 March 2022 - 06:49 AM
Getting close now, must be a good feeling
#653 LJ RB30
LJ RB30
  • 1,058 posts
  • Name:Trevor
Posted 23 March 2022 - 07:30 PM
Getting excited now  :D
Excellent job mate! :spoton:
#654 rodomo
Posted 23 March 2022 - 09:11 PM
Your masking looks like something off a geometry exam.....................mine looks like shit
#655 sibhs
Posted 23 March 2022 - 11:33 PM
My favourite comment this year, Thanks Rob!
Time to clean out the room again getting rid of any unnecessary stuff and washing down the floor.
Attached File  IMG_7599.jpeg   171.48K   9 downloads
Started working out how i'm going to reach the roof centre.
Attached File  IMG_7600.jpeg   196.11K   6 downloads
This was too risky and I'll use the wood on crates instead.
Attached File  IMG_7601.jpeg   170.85K   6 downloads
Trying the soft edge foam masking to protect the jambs.
Attached File  IMG_7603.jpeg   168.23K   5 downloads
This front gap was a bitch to mask out, could not find any advice on google. Managed to get some foam tape in there eventually.
Attached File  IMG_7604.jpeg   62.84K   6 downloads
Boot done and a couple of interesting angles while laying under the car.
Attached File  IMG_7606.jpeg   184.82K   7 downloads
Attached File  IMG_7608.jpeg   95.52K   7 downloads
Attached File  IMG_7612.jpeg   154.73K   7 downloads
The view from my security camera. Would like to live stream the spraying to all who are interested but that's too hard.
Attached File  IMG_7611.jpeg   130.14K   6 downloads
The final masking applied.
Attached File  IMG_7615.jpeg   144.5K   5 downloads
Attached File  IMG_7616.jpeg   150.41K   5 downloads
Attached File  IMG_7618.jpeg   142.12K   7 downloads
New plastic sheeting fitted to garage door.
Attached File  IMG_7622.jpeg   148.5K   5 downloads
Now waiting on the perfect day. I need the temperature at 25 degrees, humidity under 50% and the wind not blowing from the west so my shity neighbour doesn't get wind of it.
#656 71xu1
71xu1
    Dave
  • 1,278 posts
  • Car:LC GTR XU1
Posted 24 March 2022 - 12:41 AM
Hi Marty, check your TDS for the primer you have used, not all are the same, but you may need to rescuff the primer if left for more than 6 to 7 hrs as the primer closes up/heals itself and potentially you could end up with poor bonding of the base coat.
#657 sibhs
Posted 24 March 2022 - 09:49 AM
Never new that! Thanks Dave.
That would be annoying!
#658 gtr_161
gtr_161
  • 110 posts
  • Car:LC
Posted 26 March 2022 - 11:42 AM
Amazing work as usual mate, I cant wait to see this one completed!
Cheers!
#659 sibhs
Posted 26 March 2022 - 06:19 PM
The big day has arrived.
The safer option for reaching the roof.
Attached File  IMG_7623.jpeg   162.78K   5 downloads
Plenty of wipes and cleaning down for the third time.
Attached File  IMG_7634.jpeg   101.72K   5 downloads
All gaps sealed or filter material jammed in.
Attached File  IMG_7635.jpeg   155.52K   6 downloads
Plan of attack is start furtherest from the ventilation fan which means I start at the front of car. I numbered the sections I'm going to paint in order working over the bonnet down a side then over the roof before spraying rear quarters and boot. Also marked with tape on the floor the sections so I remember where to start and finish.
Attached File  IMG_7637.jpeg   144.39K   5 downloads
Attached File  IMG_7638.jpeg   129.06K   5 downloads
Attached File  IMG_7639.jpeg   139.8K   5 downloads
Attached File  IMG_7640.jpeg   118.05K   8 downloads
Attached File  IMG_7641.jpeg   127.1K   7 downloads
Ventilation tube pointed into wheel barrow with second round of filter mesh.
Attached File  IMG_7642.jpeg   427.53K   8 downloads
Taped up my baggy suit and here we go, wish me luck.
Attached File  IMG_7675.jpg   184.96K   10 downloads
#660 S pack
Posted 26 March 2022 - 06:46 PM
Hey Marty, by the time you read this you may have finished applying the paint.
I would start with the roof and front and rear windscreen openings, then the bonnet & nose cone, then work down one side of the car, across the boot and rear panel than back up the other side to the tip of the front guard.
#661 Ice
Posted 26 March 2022 - 08:10 PM
Good tips Dave
But I don’t think it’s Marty’s first Rodeo
#662 sibhs
Posted 27 March 2022 - 06:18 PM
Not sure whether to cry or laugh.
Certainly had some dramas with my first one being "I'm not a painter". I sprayed the base coat too heavy on the first coat and got some runs. I was about to give up this 2K dream when I realised I could rub it back in 30 mins and try again. So the couple of runs were wet sanded, dried and sprayed over. Then 2 full coats of base at a much lighter coverage. I turned the lights out and carefully inspected the base with a bright LED torch. All looked good.
Now the scary part of using a clear I'd never used before with a different mixing ratio of 3:1. My original clear was out of stock but was assured this new one would be good. Three coats went down letting them flash off in-between. I was pretty happy with the result, there were a few runs and about 8 nib dust bits and few areas of orange peel.
Then the next drama happened when I was de-masking and that tricky foam tape between front door and guard got stuck. I panicked and just kept pulling it as it came out it pulled some paint off as well. About 5mm x 30mm. Then the next day I decided to try my new de-nib tool on a 'run' which hadn't fully dried, bugger me I pulled the hole run off, 3mm x 3mm. If I just left it alone to dry i wouldn't of had these issues but the paint looks so beautiful I just had to keep touching it.
I think I can save the paint job! It's been a couple of days drying and I've starting blocking it back. That part to come later.
Anyway, enjoy the Amethyst Metallic.
Attached File  Screen Shot 2022-03-27 at 3.38.52 pm.jpeg   136.39K   9 downloads
Attached File  IMG_7645.jpeg   151.12K   6 downloads
Attached File  IMG_7647.jpeg   157.92K   7 downloads
Attached File  IMG_7649.jpeg   112.25K   8 downloads
Happy with my base now and getting ready for round 2 'applying the clear'
Attached File  IMG_7660.jpeg   181.64K   11 downloads
Attached File  IMG_7664.jpeg   195.82K   6 downloads
The frock-up and orange peel
Attached File  IMG_7665.jpeg   102.04K   11 downloads
Attached File  IMG_7666.jpeg   111.4K   10 downloads
Attached File  IMG_7673.jpeg   92.65K   8 downloads
Thanks for your tips S Pack, I used the YouTube 'Paint Society' Advice and I'm happy with coverage and I got no dry areas so I think that system worked. A couple of people said I should of finish the base with some diagonal spray patterns to avoid lines, I didn't do this but think its a great idea.
Gene, It's not my first Rodeo but the first time riding this bull. The LJ was like riding a pony.
#663 claysummers
Posted 27 March 2022 - 08:46 PM
Feeling your pain Marty. My son and I are about to closed door his impreza in metallic acrylic. Never done metallic before. I was told if the first two coats are too peely stop and block back.
#664 71xu1
71xu1
    Dave
  • 1,278 posts
  • Car:LC GTR XU1
Posted 27 March 2022 - 08:52 PM
Steep learning curve with 2k, acrylic is so much more forgiving but pretty much stops there. Tip with runs, use fine body filler over the run and slightly past with a nice feather edge on the body filler then work from 240 to 1500 grit wet n dry, a razor blade also works a treat. But yes make sure it is fully cured.
#665 Ice
Posted 28 March 2022 - 01:22 AM
Looking good Marty I’m sure by the time you’re finished it will be 100 % perfect  :)
#666 gad05
gad05
  • 422 posts
  • Name:Graham
Posted 28 March 2022 - 10:50 AM
Love your work Marty.
Sally chose a great colour.
Cheers Graham.
#667 LJ RB30
LJ RB30
  • 1,058 posts
  • Name:Trevor
Posted 28 March 2022 - 02:17 PM
Even with the minor hickup's Marty its looking bloody good!
I certainly take my hat off to you for your amazing effort!
Nice colour too.
#668 lj72bathurst
lj72bathurst
  • 228 posts
Posted 28 March 2022 - 07:17 PM
Very nice colour mate
The chrome and stainless will really stand out
Jason
#669 rodomo
Posted 28 March 2022 - 09:09 PM
What brand of paint are you using Clay?
#670 claysummers
Posted 29 March 2022 - 06:41 AM
Good question Rob
#671 sibhs
Posted 31 March 2022 - 11:12 PM
Thanks for your votes of confidence guys. I think this will turn out ok.
I waited a few days before starting to block the paint down.
I rubbed back the runs with a small piece of wooden mixing stick and some 800 wet and dry wrapped tightly around it. Managed to keep it flat and not damage anything else.
Below is a run and to the left of it the run I tried to remove too early with the de-nib tool leaving missing paint down to sealer.
Attached File  IMG_7684.jpeg   135.21K   13 downloads
De-nib in action
Attached File  IMG_7685.jpeg   175.38K   14 downloads
After sanding
Attached File  IMG_7686.jpeg   192.11K   9 downloads
Making myself comfortable for the long hours of blocking back. Starting with 1200 and worked my way up to 3000.
Attached File  IMG_7691.jpeg   186.78K   8 downloads
Keeping away from edges as not to cut through to base coat.
Attached File  IMG_7699.jpeg   114.24K   8 downloads
Paint job starts to look worse.
Attached File  IMG_7708.jpeg   172.14K   8 downloads
Attached File  IMG_7709.jpeg   204.65K   8 downloads
Here you might notice the tiny nib removed in second pic.
Attached File  IMG_7710.jpeg   120.76K   8 downloads
Attached File  IMG_7711.jpeg   116.48K   8 downloads
How the beading stops when you rub it back.
Attached File  IMG_7718.jpeg   183.93K   8 downloads
#672 claysummers
Posted 01 April 2022 - 07:24 AM
Bye bye finger prints…….
#673 sibhs
Posted 01 April 2022 - 08:43 PM
After the whole car was rubbed in 1200 then I decided to do the repairs on damaged bits.
Unothodox but I have nothing to lose in trying these bodgy repairs.
Soft edge masking around the run repair.
Attached File  IMG_7735.jpeg   82.68K   10 downloads
Same around door edge repair.
Attached File  IMG_7736.jpeg   132.86K   8 downloads
Boot had a few issues so decided to re-spray.
Attached File  IMG_7737.jpeg   213.49K   9 downloads
Spot patch a de-nib that was a grain of sand and went down to sealer.
Attached File  IMG_7738.jpeg   137.81K   11 downloads
Attached File  IMG_7739.jpeg   83.41K   8 downloads
Attached File  IMG_7740.jpeg   110.21K   9 downloads
Attached File  IMG_7741.jpeg   256.57K   7 downloads
Much better, no more dry areas or runs.
Attached File  IMG_7742.jpeg   169.02K   9 downloads
Cleared the whole door after getting some expert advice.
Attached File  IMG_7743.jpeg   126.99K   8 downloads
Blobbing extra clear on to build up thickness
Attached File  IMG_7745.jpeg   103.04K   9 downloads
Once this is polished I think it'll be hard to see. It is perfectly flat.
Attached File  IMG_7779.jpeg   103.92K   9 downloads
Attached File  IMG_7780.jpeg   104.36K   10 downloads
#674 claysummers
Posted 02 April 2022 - 08:04 AM
Well done. You can do a lot with a brush. Getting it flat after is the tricky bit.
#675 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 02 April 2022 - 08:29 AM
I think 1 of the main points Marty was trying to hint to here, is for other people to be patient during the excitement of de masking, learn from his mistakes. We all make them from time to time, & it's good to say, this was my mistake, please make sure that you don't do this. But Marty has also shown that working together you can come up with solutions. Pretty much what our forum is about really.
