The Sally Report
1003 replies to this topic
#101 sibhs
Posted 23 October 2019 - 10:21 PM
G'day lads!
Time to tear off the drivers side pillar skin and make a new one. This one didn't go as smoothly as the first, maybe because I re-used the passenger side template flipped over. Anyway had to ad a few bits along the way but still very happy with the result.
I did a couple of big days on the car and ended up losing my mojo and gave it a break for almost a week. Just sick of welding and grinding I suppose.
Attached File  IMG_9133.jpg   111.81K   21 downloads
Attached File  IMG_9144.jpg   222.94K   16 downloads
Attached File  IMG_9164.jpg   99.84K   13 downloads
Attached File  IMG_9167.jpg   144.76K   13 downloads
Attached File  IMG_9168.jpg   118.42K   14 downloads
Attached File  IMG_9171.jpg   150.51K   14 downloads
Attached File  IMG_9173.jpg   108.42K   12 downloads
Attached File  IMG_9179.jpg   106.77K   14 downloads
Attached File  IMG_9176.jpg   100.34K   11 downloads
Attached File  IMG_9213.jpg   139.62K   14 downloads
Attached File  IMG_9221.jpg   143.54K   14 downloads
Attached File  IMG_9223.jpg   126.37K   14 downloads
#102 sibhs
Posted 23 October 2019 - 10:44 PM
I've also been cutting the rust out of the front valance, some of these shapes have been very hard to make but finally got them sorted.
Attached File  IMG_9174.jpg   149.51K   13 downloads
Attached File  IMG_9175.jpg   196.62K   13 downloads
Attached File  IMG_9214.jpg   205.93K   11 downloads
Attached File  IMG_9215.jpg   157.59K   11 downloads
Attached File  IMG_9216.jpg   96.71K   11 downloads
Getting some nice little tac welds with the .6mm wire.
Attached File  IMG_9217.jpg   172.19K   12 downloads
Attached File  IMG_9218.jpg   144.21K   12 downloads
Attached File  IMG_9219.jpg   128.81K   13 downloads
Attached File  IMG_9220.jpg   182.11K   11 downloads
#103 308 Sunbird
308 Sunbird
  • 976 posts
  • Name:Stuart
Posted 24 October 2019 - 06:07 AM
Great job Marty
#104 gad05
gad05
  • 422 posts
  • Name:Graham
Posted 24 October 2019 - 10:39 AM
Very nice Marty.
#105 claysummers
Posted 24 October 2019 - 10:55 AM
You make it look easy. Avoiding shrinkage on those flat valance patches requires patience I`m still looking for.
#106 lctriples
lctriples
  • 414 posts
  • Name:paul
Posted 24 October 2019 - 04:48 PM
Top work Marty!  Ain't grinding welds back fun! Looks like the .6 wire is doing the trick, handy to know in the future, Paul
#107 sibhs
Posted 24 October 2019 - 10:38 PM
Evening all,
Sometimes you feel like you're going nowhere with your resto so I've given myself a target/goal of getting the windscreen cowl on. To do that I need the door pillars fitted and the plenum chamber prepped and maybe spray some colour in there first.
I've got the passenger pillar fitted with my made up top bit and hopefully get the drivers side done soon.
Attached File  IMG_9206.jpg   139.08K   15 downloads
Attached File  IMG_9207.jpg   124.06K   12 downloads
Attached File  IMG_9208.jpg   139.17K   15 downloads
Attached File  IMG_9209.jpg   177.46K   11 downloads
Attached File  IMG_9210.jpg   182.08K   12 downloads
Great job Marty
Thanks Sunbird, appreciate the support.
Very nice Marty.
Cheers Graham
Hi Clay, It sure aint easy but is challenging and very time consuming. I could never do this for money. Have you tried welding 5 spots then hitting it with compressed air?  I've found it a much better way of reducing warping/shrinkage.  I think I've still got a bit of movement but will sort that out later I hope.
Grinding sucks!  I'm also finding grinding discs(hard disc about 4mm thick) go blunt or clog up even though they still look new.  They start off great and then reduce their grinding power.
Thanks guys
#108 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 25 October 2019 - 09:20 AM
Nice work bud
#109 Rockoz
Posted 25 October 2019 - 10:52 AM
Marty gave a good tip about keeping it cool.
I found that if you can keep the whole area down to a temp that you can keep your hand on, reduces lots of dramas.
Another trick I found is dont cut out square corners. You get a lot more pull with so much weld in a close area.
Make your patches circular or oval wherever possible. That sort of keeps any pull even over the whole patch.
My advice is only through what I have found works for me. Im still very much more a grinder than a welder.
But with car panels there is no real way of avoiding that as an amateur. TIG will help, but is more difficult to do in odd places, and uses way more gas.
Also when grinding down your welds, go easy then too to keep the heat down.
#110 sibhs
Posted 29 October 2019 - 10:08 PM
Hey all,
I've got both pillars done, pulled a few repairs then sanded the plenum and re-rust blasted the front end.
Then the next day when dry all the welded bits were rust sealed and then got my first batch of etch on the car.
So now I'll focus on getting the windscreen cowl on but will paint and seal inside first.
Attached File  IMG_9242.jpg   148.13K   12 downloads
Attached File  IMG_9259.jpg   118.96K   12 downloads
Attached File  IMG_9261.jpg   191.7K   12 downloads
Attached File  IMG_9274.jpg   149.24K   13 downloads
Attached File  IMG_9275.jpg   137.3K   13 downloads
Attached File  IMG_9276.jpg   109.52K   13 downloads
Attached File  IMG_9277.jpg   106.17K   15 downloads
#111 sibhs
Posted 29 October 2019 - 10:18 PM
I'm missing the heater control knobs but managed to borrow a pair from a friend.
Made a mould and poured a few sets up, takes a bit of time but I reckon once they're in the car no one will know the difference.
Attached File  IMG_9234.jpg   142.27K   14 downloads
Attached File  IMG_9239.jpg   141.47K   13 downloads
Attached File  IMG_E9241.jpg   146.15K   14 downloads
#112 _2ELCS_
_2ELCS_
Posted 30 October 2019 - 07:08 AM
You're a talented man Marty  :D
#113 _Housecat1977_
_Housecat1977_
Posted 30 October 2019 - 09:07 AM
Nice work Marty, always enjoy seeing your updates.
My tip for welding the cowl panel on is to fit the wiper mechs. This is to make sure the panel that sits against the heater is in the correct position and the wiper mech fits afterwards.
I used a HB cowl panel on mine, not realising the differences, and neglected to fit the wiper mechs when I welded it on.
Fast forward to me fitting the wipers and wondering why -
1) The passenger side wiper mech wouldnt fit without some massaging and grinding of the hole it sticks through.
2) The drivers side wiper mech hole was actually about 60mm too far to the center of the car so I had to redreill the mounting holes.
3) When I fitted the heater box, I needed two gaskets to make it seal against that panel. (I still havent tested to see if it's water proof.)
Luckily it looks good and isn't easy to pick without a keen eye.
What may seem obvious to some is not so for others!
Paul
#114 sibhs
Posted 01 November 2019 - 08:43 AM
On Wednesday I got to see a NOS inner door pillar and due to me just working on these I took a bit of interest in it.
Here are some pictures for reference, I was mainly interested in the welding points of the hinges.
Attached File  IMG_9284.jpg   250.27K   14 downloads
Attached File  IMG_9285.jpg   304.06K   13 downloads
Attached File  IMG_9286.jpg   290.42K   13 downloads
Attached File  IMG_9287.jpg   377.85K   12 downloads
Attached File  IMG_9288.jpg   199.97K   11 downloads
Attached File  IMG_9289.jpg   154.6K   11 downloads
Attached File  IMG_9290.jpg   160.19K   11 downloads
Attached File  IMG_9291.jpg   89.53K   10 downloads
Attached File  IMG_9292.jpg   82.69K   10 downloads
#115 warrenm
Posted 02 November 2019 - 05:12 AM
I can see why they rusted, a sort of a wipe of sealer across the horizontal surface.
#116 Shiney005
Posted 03 November 2019 - 11:00 AM
Nice reference there Martin. Looks like it came from that big warehouse in Thailand.
#117 S pack
Posted 03 November 2019 - 11:21 AM
Japan actually.
#118 Shiney005
Posted 03 November 2019 - 01:10 PM
Ha ha. I only got taught Straylian at my school.  I didn't even know they went to Japan Dave. Got any pics? There is an export thread in here somewhere. And I don't think it even has beer in it.
#119 S pack
Posted 03 November 2019 - 03:21 PM
Unfortunately no pics Laurie but my daughter translated it for me. The Asian writing is Japanese kanji and it literally translates to 'left hand front door pillar'.
GMH did export RH drive vehicles to Japan, albeit in small numbers. The RPO was XU4 - Japanese special vehicle equipment.
#120 sibhs
Posted 03 November 2019 - 07:17 PM
The story with the pillar is it's been sent to asian country to see if it can be copied and manufactured but after 4 years of flying around the world it's come back with a "can't do."
Paul
Thanks Paul, Always good to learn from other peoples mistakes.  I'm pretty sure I would of put the wiper mech's in before lining up the cowl.
I've sanded back the etch to remove the runs caused by Rust Seal.  Then re-applied another coat of etch.  Made up a big brew and etched some parts I had sand blasted and rust blasted.
Attached File  IMG_9279.jpg   139.55K   8 downloads
Attached File  IMG_9294.jpg   172.69K   9 downloads
Attached File  IMG_9267.jpg   369.92K   10 downloads
Attached File  IMG_9297.jpg   164.89K   9 downloads
Attached File  IMG_9298.jpg   116.81K   11 downloads
#121 S pack
Posted 03 November 2019 - 07:28 PM
haha, nothing is impossible, miracles just take a little longer. If Vauxhall & GMH could make them then they could be copied, it's probably just the cost is prohibitive.
#122 Ice
Posted 03 November 2019 - 08:02 PM
You never do things in half measures do you Marty
Im just blown away what your capable of
#123 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 03 November 2019 - 08:16 PM
Hi Marty, any chance of some photo's of the car dolly design & can you please comment on anything you would change with it mate. Looks like a good idea to me. Thanks, Gary.
#124 sibhs
Posted 03 November 2019 - 09:19 PM
Correct! It was a price issue.
Thanks Gene, just a normal guy having a crack at everything. I'll put up some pictures of all my failures(learning experiences) soon.
Attached File  IMG_8297.jpg   423.72K   11 downloads
Attached File  IMG_8357.jpg   192.45K   13 downloads
Hi Gary, I've attached the dolly's to the mounting points of the chassis where they're designed to take the weight. Rear spring tower and trailing arm brackets, then the front k frame mounting to chassis.
At first I thought I'd made it too high but now realise its perfect. I would prefer a little higher but then bonnet would hit garage ceiling and painting the roof would be difficult. I think i'll remove dolly wheels when painting car to bring it down a bit. I also used eBay dolly wheels which don't change direction too well.  I use the front dolly to stand or sit on (handy) and can walk in and out of the engine bay by just bending over (very handy).
#125 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 03 November 2019 - 09:49 PM
Thanks mate, any photo's of the rear set up, would be fantastic. I might design something like that for when my body gets restored. What diameter are your wheels ? Solid or rubber tyres ? All handy to know for when that time comes. Gary.
