The Sally Report
1003 replies to this topic
#126 sibhs
Posted 10 November 2019 - 09:27 PM
Update time boys,
A bit more work on the parts that need re-chroming. Plenty of time spent working my way through the grades of wet'n'dry to remove pitting and scratches.
Attached File  IMG_9300.jpg   93.69K   13 downloads
Attached File  IMG_9301.jpg   140.99K   9 downloads
Attached File  IMG_9299.jpg   210.05K   9 downloads
After a polish it's checked with the badge in place. This still needs more work after noticing scratches still visible.
Attached File  IMG_9303.jpg   154.51K   11 downloads
Attached File  IMG_9337.jpg   236.05K   9 downloads
Attached File  IMG_9338.jpg   164.61K   9 downloads
Attached File  IMG_9340.jpg   168.17K   9 downloads
I had a worry moment whilst sanding one of the taillights and noticing the edging was bent. Thought I had wasted an hour of sanding and the cost of stripping the chrome but luckily the metal is soft and plyable so I could bend it back into shape.
Attached File  IMG_9332.jpg   104.89K   11 downloads
Attached File  IMG_9333.jpg   145.6K   9 downloads
Attached File  IMG_9327.jpg   144.57K   11 downloads
Seam sealed the plenum and a few other areas, wanted to use up the sealer tube rather than leave some to go hard.
Attached File  IMG_9309.jpg   105.26K   15 downloads
Attached File  IMG_9308.jpg   100.68K   13 downloads
Thanks mate, any photo's of the rear set up, would be fantastic. I might design something like that for when my body gets restored. What diameter are your wheels ? Solid or rubber tyres ? All handy to know for when that time comes. Gary.
100mm solid rubber. Two with brakes all swivel.
#127 sibhs
Posted 10 November 2019 - 09:42 PM
Bought some paint products while I was in the deep south where the mouth breathers live. Found a good paint store in Welshpool and decided to get most of my gear while out that way.
After reading all the tech sheets I marked up the cans to help when mixing the products. I got a litre of the final colour so I can paint the plenum and a few other bits.
Attached File  IMG_9434.jpg   236.23K   15 downloads
Now the etch is on I can see some more dents so knocked them out where possible.
Attached File  IMG_9311.jpg   89.9K   9 downloads
Attached File  IMG_9312.jpg   73.11K   9 downloads
Attached File  IMG_9313.jpg   44.18K   11 downloads
Some of the tools used.
Attached File  IMG_9317.jpg   137.26K   9 downloads
When I had the panic attack over the tail light being bent, I rushed out and bought a shop press hoping it would be the answer. It wasn't and I was able to fix with levers and blocks of wood hit with a hammer. I'm sure the press will still come in handy and am in the process of making jigs to remove trailing arm bush's.
Attached File  IMG_9331.jpg   129.13K   9 downloads
#128 Indy Orange
Indy Orange
  • 2,987 posts
Posted 10 November 2019 - 09:50 PM
Nice work Marty! Very time consuming rubbing handles and tail light surrounds trying to remove pitting.
#129 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 15 November 2019 - 05:16 PM
The press, will be good, but you will get frustrated aswell, with the single action pump. Get yourself some bush & seal dies from hare & forbes ect, great for removal and installation. Thanks for the tip on the wheels to mate.
#130 sibhs
Posted 16 November 2019 - 10:01 PM
Evening, it's Saturday night, theres nothing on TV, lets write an update.
No work on the body this week due to work being busy and the heat in the arvo.
The only update is regarding the heater cables.
I picked up some cable and wire last week and also got my LJ cable making tool back after lending it out.  I decided to turn it over and mark out the LC cables.  I have a borrowed pair to copy and hopefully the pictures below tell the story.
I had enough material to make 3 of each but have realised I can't finish off the small thick cable until I get some brackets.
I need three brackets to finish off these cables so if anyone has some lying around they want to donate it'll be appreciated.
Attached File  IMG_9479.jpg   169.36K   12 downloads
Attached File  IMG_9478.jpg   177.52K   9 downloads
Attached File  IMG_9480.jpg   207.49K   11 downloads
Attached File  IMG_9481.jpg   114.04K   10 downloads
Attached File  IMG_9482.jpg   184.67K   9 downloads
Attached File  IMG_9484.jpg   94.97K   9 downloads
Attached File  IMG_9485.jpg   145.67K   10 downloads
Attached File  IMG_9486.jpg   129.36K   10 downloads
Attached File  IMG_9487.jpg   143.47K   10 downloads
Attached File  IMG_9488.jpg   218.88K   10 downloads
Attached File  IMG_9490.jpg   225.71K   10 downloads
This is the bracket I'm after three of if anyone can help out.
Attached File  IMG_9489.jpg   97.94K   10 downloads
#131 rodomo
Posted 16 November 2019 - 10:11 PM
:spoton:
#132 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 16 November 2019 - 10:52 PM
Marty, does that cable just unwind back out of the bracket easily ? I haven't pulled 1 apart yet, be interested to see if there is any trick with them. & do you mind showing how you start the curl in the wire. They look good & if i have to make any cables, I'd like to be able to get them like yours.
#133 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 16 November 2019 - 11:12 PM
I'm also keen to see what you used, if you stripped your own chrome off & what grit paper that you're using to repair the die cast. If you prefer to pm me that's fine mate.
#134 rodomo
Posted 22 November 2019 - 09:41 PM
You'll be needing on of these bent bits of steel?
https://www.ebay.com...ggAAOxymcdRhKCK
#135 sibhs
Posted 22 November 2019 - 09:47 PM
Hi Rob, just noticed you were bushed!  Was going to ask for tips. I've just got some tube cut to 35mm in length and was going to cut out a section so it fits like that tool.
#136 _The Handbrake_
_The Handbrake_
Posted 11 April 2020 - 05:07 PM
Hey all, sorry it's been a while - M has been waiting for me to post something before carrying on with the build thread. B)
So....any guesses on the colour I’ve chosen? (I'm wearing a few clues)...
Attached File  IMG_0605.jpg   144.01K   22 downloads
It's my birthstone, and hey I like a bit of Deep Purple. If you fellas don't like it tough titties - my car, my choice!   :D
Anyway, apparently I've put the hand break on this build too long. Ever since this virus has hit M has got a bee in his bonnet and is no longer waiting for me to do anything. :blink:  At least it's the ideal self isolation project for him, and if the pandemic hangs around much longer I may have a finished car soon!   :spoton:
Oh and she’s now got a name too…my Carona. (Hoping it’s not too insensitive for any forum members out there).
So stay safe all, and I'll leave you in M's capable hands...
Hoping my trim choice will work with the body colour.
Attached File  IMG_9565.jpg   150.18K   13 downloads
Colour tested on the bit under the wipers.
Attached File  IMG_9502 (1).jpg   122.41K   12 downloads
Happy chappy.
Attached File  IMG_9506 (1).jpg   169.24K   15 downloads
#137 Ice
Posted 11 April 2020 - 05:27 PM
Thats going to look real classy with that colour, trim combo Sally
#138 snuff1966
snuff1966
  • 194 posts
  • Car:LH G pack
Posted 11 April 2020 - 06:10 PM
Nice  :spoton:
#139 sibhs
Posted 11 April 2020 - 06:23 PM
Finally!
I've been waiting 5 months for The Handbrake to announce the colour combo so I can continue this thread.
For those that don't know, the colours are Amythist Metalic (an LC 71 colour) and interior is Sandalwood.
Lets go back to late last year and start catching up on where we're at.
The seat trims had arrived from Cools Auto Trim along with the hood lining, door trims and rear parcel shelf. Some bits I was very happy with and others not so.
Attached File  IMG_9560 (1).jpg   151.56K   11 downloads
Here I compare the repo's with originals and the decrepencies are minor, a great looking product.
Attached File  IMG_9562.jpg   140.8K   12 downloads
Unfortunately they were glued onto rusty steel tops and I am very dissapointed and will have to do something about that. Some will say "why didn't you clean them up first"? Reason is, they were with a courier on route to Dash Original who said they sand blast and powder coat tops before fitting, but then the plan changed and they were instead sent to Cools, and I presumed they would do the same. Arrrrggg- not so. I've had a word to Cools and let him know it's not cool to put rusty stuff back on new stuff.
Attached File  IMG_9567 (1).jpg   69.7K   11 downloads
Hood lining looks nice.
Attached File  IMG_9937 (1).jpg   154.34K   10 downloads
You should all remember how amazing the original seats looked out of this car. They were too good to destroy and re-cover so I swapped them with a friends shitty ones. Next I had to test they fitted.
Attached File  IMG_9942 (1).jpg   221.63K   12 downloads
I found some broken welds and bent sections which I fixed.
Attached File  IMG_9945 (1).jpg   171.05K   10 downloads
This bar across the parcel shelf was bent and needed straightening.
Attached File  IMG_9935 (1).jpg   145.84K   10 downloads
Attached File  IMG_9944 (1).jpg   168.13K   9 downloads
Then they went to the zinc platers.
Attached File  IMG_0028 (1).jpg   116.17K   9 downloads
and finally trimmers for all new foam and fitting.
Attached File  IMG_0346 (1).jpg   97.61K   10 downloads
Attached File  IMG_0345 (1).jpg   272K   10 downloads
Now they can stay in a bedroom and out of my shed.
#140 sibhs
Posted 11 April 2020 - 06:53 PM
Now time for the front seats. I didn't want the full set left at the trimmers factory incase something happened to them.
Attached File  IMG_9948.jpg   203.48K   11 downloads
Strip the old seats.
Attached File  IMG_9961.jpg   229.73K   9 downloads
Attached File  IMG_9960.jpg   185.08K   9 downloads
Remove all the broken springs and dodgy bed spring and replace.
Attached File  IMG_E0024 (1).jpg   321.26K   11 downloads
Zinc the front lowers
Attached File  IMG_0073 (1).jpg   203.66K   10 downloads
Etched and ready for black
Attached File  IMG_0334 (1).jpg   150.34K   10 downloads
Black and Sandalwood painted
Attached File  IMG_0182 (1).jpg   202.15K   10 downloads
Springs prepped and painted
Attached File  IMG_0326.jpg   118.18K   10 downloads
Bits re-plated
Attached File  IMG_0568.jpg   80.35K   10 downloads
Pack them away with the rears.
Attached File  IMG_0097.jpg   186.33K   13 downloads
Restore the seat runners
Edited by sibhs, 11 April 2020 - 06:54 PM.
#141 hanra
Posted 11 April 2020 - 08:12 PM
Remind me to only buy restored cars from you!!!
#142 sibhs
Posted 11 April 2020 - 08:57 PM
After a hiatus on the body due to hot weather I found my mojo again and stripped the roof and rear end.
Attached File  IMG_9997 (1).jpg   192.31K   12 downloads
First apply the paint stripper. This roof has a lot of rust pitting, i'll repair the worst and skim over the rest.
Attached File  IMG_0003 (1).jpg   219.27K   12 downloads
First round of scraping
Attached File  IMG_0022 (1).jpg   188.34K   12 downloads
Second round of scraping
Attached File  IMG_0023 (1).jpg   180.89K   10 downloads
Paint stripper disc work
Attached File  IMG_0020 (1).jpg   185.91K   10 downloads
Attached File  IMG_0030 (1).jpg   153.85K   11 downloads
Sand blasting started.
Attached File  IMG_0031 (1).jpg   147.89K   10 downloads
Attached File  IMG_0041 (1).jpg   172.18K   10 downloads
Moving all the stuff out side for clean-up.
Attached File  IMG_0042 (1).jpg   183.86K   10 downloads
Attached File  IMG_0044 (1).jpg   173.89K   9 downloads
Wash down
Attached File  IMG_0049 (1).jpg   201.07K   10 downloads
After rust blast
#143 Ice
Posted 11 April 2020 - 09:02 PM
Looking good Marty
#144 sibhs
Posted 11 April 2020 - 09:10 PM
Roof had a few holes which needed steel replacing.
Once the repairs were done I rust blasted, sanded, then two coats of Rust Seal then while still tacky it was epotec etched. I'm very confident the roof will not rust again.
Attached File  IMG_0053 (1).jpg   141.88K   11 downloads
Attached File  IMG_0054 (1).jpg   213.03K   12 downloads
Attached File  IMG_0060 (1).jpg   116.68K   10 downloads
Attached File  IMG_0061 (1).jpg   223.69K   11 downloads
Attached File  IMG_0063 (1).jpg   199.63K   9 downloads
Attached File  IMG_0065.jpg   198.09K   10 downloads
Attached File  IMG_0066 (1).jpg   82.03K   9 downloads
Attached File  IMG_0067 (1).jpg   110.64K   10 downloads
#145 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 11 April 2020 - 10:28 PM
Great work Marty and Sally, everything in this resto is excellent!
Very impressive,
Cheers, Tom
#146 lctriples
lctriples
  • 414 posts
  • Name:paul
Posted 12 April 2020 - 06:37 AM
Sal and Marty, looking great, was wondering how resto was going. Nice to see a different interior colour other than black, should look real nice with the purple. I remember another resto project on this forum that had a lovely aqua/turquoise exterior and sandalwood interior, and how cool it looked. The purple you chose should look the same. I notice no empty corona's in garage!, have a lovely easter, paul. :D
#147 S pack
Posted 12 April 2020 - 07:38 AM
Happy chappy.
Hi Sal, Amethyst and Sandalwood is going to look great. :clap:
An old favorite :spoton:
#148 claysummers
Posted 12 April 2020 - 09:44 AM
Didn’t know you could use Epotec over rust blast. Good thing if it works and would save a lot of work getting to clean steel.
The Purple paint and creme vinyl is a real classic seventies theme, will look stunning. My cousin had a Charger in that theme, with creme vinyl roof.
#149 sibhs
Posted 12 April 2020 - 12:10 PM
Hi Clay,
I was told the purple with cream colour interior is the favourite with the Ford GT boys too.
Yes epotec loves the zinc rich coating left by rust blast.
When ever you KBS Rust seal you must etch it before it fully cures or sand it if cured before etching. Even the KBS fusion you have to apply before Seal cures.  I spoke with the KBS tech's about all this years ago.
#150 DMLC71
DMLC71
  • 424 posts
  • Name:Daz M
  • Car:1971 LC 4 door
Posted 12 April 2020 - 06:51 PM
Hey Marty,
If Sally ever gives you the boot there is a spare room and an empty garage at my place
Rent free mate
cheers Dazm
