Hawks Torana dream lives on
447 replies to this topic
#101 yel327
Posted 14 January 2021 - 05:23 AM
I just meant to repair it properly, as in ask how to do it. Being it is an important structural point.
#102 warrenm
Posted 14 January 2021 - 05:57 AM
Drill the ends of the cracks & weld them.
#103 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 14 January 2021 - 08:13 AM
I plan to do it properly, seeing the rust in the crack and how thin the metal is in spots id rather put a patch in the spot instead of just welding it.
What thickness sheet metal do I buy for the patch?
#104 claysummers
Posted 14 January 2021 - 09:21 AM
If you are going to buy fresh sheet then for the lighter panels I've used 0.9 mm zinc anneal which approximates the old 20#. Otherwise can use unwanted panels from cars of the era. Structural pressings are the next size up generally 18# or 1.2mm.
#105 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 14 January 2021 - 09:37 AM
I always use 1.2 Zinc anneal for any panel repairs on 1mm section.
Has massively improved the quality of my repairs.
#106 Rockoz
Posted 14 January 2021 - 02:50 PM
Yep same crack I had in my VB many moons ago.
Mate panel beater said it was very common.
He double skinned the area to get strength.
#107 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 14 January 2021 - 08:09 PM
Awesome thanks I'll get some when I'm ready to start welding (need to buy a welder).
Got my front end back from the blasters along with a few other bits and started painting it all.
Painting the front suspension in KBS gloss black. Just brushing it on and being outdoors, I'm getting a few bugs in it. Might have to buy the KBS kit that sprays inside cavities to get inside the K frame.
Can I leave the timing cover like this? or does it need to be painted?
Attached File  FB_IMG_1610617976825.jpg   81.21K   10 downloads
Attached File  FB_IMG_1610617980467.jpg   54.93K   9 downloads
Attached File  FB_IMG_1610617989022.jpg   70.47K   9 downloads
Attached File  FB_IMG_1610617986207.jpg   75.77K   9 downloads
Attached File  FB_IMG_1610617991815.jpg   76.12K   10 downloads
Attached File  FB_IMG_1610617982922.jpg   136.86K   10 downloads
Attached File  FB_IMG_1610617998674.jpg   141.49K   7 downloads
#108 toryman76
toryman76
  • 1,082 posts
Posted 14 January 2021 - 09:03 PM
Looks awesome! What did you coat the inside of the rocker covers with?
I reckon the timing cover would look nicer with a coat of paint. Maybe some KBS in silver? The motor coater stuff is good for heat and bonds really well and I think it comes in silver or grey whichever you prefer. The inside would probably be ok to leave it but the rough surface might promote further errosion.
#109 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 16 January 2021 - 07:53 AM
They are how I picked them up from the blasters, so I have no idea.
I'll paint the timing cover with some engine enamel then. I plan to use proper coolant in it so that should help minimise further erosion.
#110 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 16 January 2021 - 06:16 PM
Well no turning back now, started cutting up the floor and knocking the rail straight.
Before
Attached File  FB_IMG_1609295649161.jpg   61.11K   10 downloads
floor cut for access
Attached File  FB_IMG_1610778404042.jpg   104.27K   9 downloads
plate removed
Attached File  FB_IMG_1610778375355.jpg   108.91K   8 downloads
the cracks will need a lot more trimming to remove the damaged metal.
Attached File  FB_IMG_1610779380655.jpg   63.79K   6 downloads
Attached File  FB_IMG_1610779377266.jpg   45.06K   6 downloads
Knocking it straight.
Attached File  FB_IMG_1610778379318.jpg   61.33K   8 downloads
Obviously it still needs a lot of work but is coming along now.
Painting also continued. All done with rattle cans as thats all I have on hand. Mixture of different paints depending on the part. Probably got some of it wrong.
Attached File  FB_IMG_1610778388350.jpg   123K   7 downloads
Attached File  FB_IMG_1610778384299.jpg   62.06K   7 downloads
#111 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 17 January 2021 - 04:17 PM
Front end is done and ready for bushes.
Attached File  FB_IMG_1610856906844.jpg   111.93K   12 downloads
Attached File  FB_IMG_1610856898604.jpg   76.12K   12 downloads
#112 toryman76
toryman76
  • 1,082 posts
Posted 17 January 2021 - 05:54 PM
Very nice! You're making decent headway
#113 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 19 January 2021 - 09:24 PM
The upper and lower control arm bushes are pressed in and balljoints fitted.
the outrigger bushes for the Kframe as shown below, does the flange go on the rail side or the inside of the KFrame?
Attached File  FB_IMG_1611054749622.jpg   73.62K   6 downloads
#114 toryman76
toryman76
  • 1,082 posts
Posted 20 January 2021 - 06:53 AM
That's a long debated argument.... The manual says one thing but most cars were fitted the other way. I put mine back in the way they came out pretty certain it was flange against the rail.
#115 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 20 January 2021 - 09:07 PM
I bought two lots, thought the hamburger kit came with rubber K frame bushes but they were actually whiteline ones with the two piece lowers so used them instead.
Its starting to come together now but will have to come back out for the rail repairs.
Was going to leave the outrigger area alone other than the crack but unsure now I see it all lined up. should I leave it as is or try to straighten it a bit?
Attached File  FB_IMG_1611127191701.jpg   55.86K   9 downloads
Attached File  FB_IMG_1611127188296.jpg   101.38K   8 downloads
Attached File  FB_IMG_1611127185086.jpg   101.78K   7 downloads
#116 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 21 January 2021 - 05:39 PM
well its a roller again.
Hopefully picking up a welder soon, a unimig 120 viper. Will that be good enough for what I'm doing?
Will be ready to rebuild the rack soon. got all the parts except for the inner bushes. nowhere seems to have a clue what they are. Does anyone have a part number or know who supplies them?
Attached File  FB_IMG_1611214432988.jpg   116.62K   8 downloads
Attached File  FB_IMG_1611214435807.jpg   112.43K   7 downloads
Attached File  FB_IMG_1611214438800.jpg   97.9K   7 downloads
Attached File  FB_IMG_1611214442128.jpg   119.8K   7 downloads
#117 toryman76
toryman76
  • 1,082 posts
Posted 22 January 2021 - 08:06 PM
Looks like your front end lines up great. I don't see the issue? I wrestled mine for a day to get it in and even then I'm still not happy how one of the top bushes sits. Not sure about steering rack. I know a few years ago I was told there were certain parts you couldn't get for them. I am sure this has changed now though as so many parts are available now compared to when I built mine. Maybe have a chat to one of the old skool steering companies they might know?
New front end looks great BTW! Nice fresh everything. Doing this first up will make the car feel much nicer on the road.
#118 Rockoz
Posted 24 January 2021 - 11:35 AM
I would have gone the next sized up MIG.
Well I actually did.
I had a 2?? mig, and I just bought a 285 as well.
I decided to buy another one because it was becoming a bugger changing between mild steel and aluminium.
The other day I changed back and forth at least 4 times.
Now I dont have to bother.
It cost me a touch over 800.
It gives me MIG TIG and stick capabilities in the one machine.
I now have a MIG/Stick, an AC/DC TIG/Stick a MIG/DC only TIG/Stick and a Plasma Cutter.
All of them UNIMIG.
Chee
#119 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 30 January 2021 - 07:51 PM
Cheers guys, as for the Mig. Being on a budget meant its my only option. I'll upgrade at a later stage. Been playing around with the gassless stuff today and as usual its a shocker haha. Need to wait for more funds to buy gas and wire.
Been a slow week on the car as I've had a lot on. hopefully do a bit more tomorrow.
Anyway, reassembled the bonnet catch and fitted to get the relocated washer and overflow bottles in the right spot. Turn the Horn around for clearance and it frees the bay up a lot. Never noticed any air flow issues with this mod on my old UC
Attached File  FB_IMG_1611999625474.jpg   128.49K   5 downloads
#120 UCSLE
UCSLE
  • 740 posts
  • Name:troy
  • Car:Goggomobil
Posted 30 January 2021 - 08:22 PM
have you tried 0.6 gasless wire ?  https://www.ebay.com...CABEgJ9GvD_BwE  gas is so much better but it maybe worth a look at since your on a budget .
Edited by UCSLE, 30 January 2021 - 08:23 PM.
#121 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 01 February 2021 - 07:49 PM
I'll be buying gas and wire as I want the welds on the rails to be solid.
been scrubbing and wire wheeling the motor. Really temped to do a full rebuild on it.
Pulled the sump off for a look. Are these standard pistons?
Attached File  FB_IMG_1612167843691.jpg   108.23K   10 downloads
Attached File  FB_IMG_1612167846616.jpg   55.48K   10 downloads
#122 Rockoz
Posted 02 February 2021 - 11:44 AM
0.6mm wire for panels.
I would likely go up to 0.8 or 0.9 for the rails as they are heavier gauge steel.
I get lots better welds with 0.8 on thicker steel than the welds I get using 0.6 on thinner stuff.
For me I think it might be because Im not moving fast enough.
If you are tight for funds, the more expensive rental of bottles might work for you.
Get a BOC account. They were doing deals on one free refill at one stage.
#123 toryman76
toryman76
  • 1,082 posts
Posted 02 February 2021 - 04:54 PM
Any nasty stuff in the bottom of the sump? I doubt they are std factory pistons with those markings in the casting. Check the top of the piston to id if it's std bore or oversize. I would err on the side of if it ain't broke don't fix it. 0.6mm wire plus gas and you should be on the money. Just play around with your settings and technique for the rails so you get a process nailed before doing the job. Remember to practise in the position you will be welding in ie overhead, etc as this makes a big difference to settings and technique.
#124 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 03 February 2021 - 06:12 PM
Bought some gas today and 0.6 and 0.9 wire. Had a few test goes then had a crack at the rails.
Not great but filled in a lot of where I needed too. the rest will be done when the plate is welded back in. Hopefully I'll buy some weld through primer tomorrow after work.
Before
Attached File  FB_IMG_1610779380655.jpg   63.79K   4 downloads
Attached File  FB_IMG_1610779377266.jpg   45.06K   4 downloads
After
Attached File  FB_IMG_1612339321246.jpg   86.22K   4 downloads
Attached File  FB_IMG_1612339333563.jpg   57.74K   5 downloads
Attached File  FB_IMG_1612339330622.jpg   42.61K   5 downloads
Attached File  FB_IMG_1612339327494.jpg   64.4K   5 downloads
Attached File  FB_IMG_1612339324238.jpg   61.21K   6 downloads
#125 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 04 February 2021 - 04:41 PM
Repair is finished on the rail. Next step is to weld in the floor section.
Before
Attached File  FB_IMG_1612420627905.jpg   60.63K   5 downloads
Setting up
Attached File  FB_IMG_1612420643247.jpg   50.16K   6 downloads
After
Attached File  FB_IMG_1612420650341.jpg   66.61K   7 downloads
Attached File  FB_IMG_1612420656196.jpg   26.92K   5 downloads
Attached File  FB_IMG_1612420653032.jpg   37.97K   5 downloads
