Hawks Torana dream lives on
448 replies to this topic
#151 Rockoz
Posted 16 February 2021 - 10:15 AM
Ive used both.
If left outside in the weather, the zinc one seems to absorb moisture and starts to rust a bit sooner than the copper.
Not a scientific test by any means, just my observations.
Even cold gal doesnt seem to last as well as I would expect in the weather.
#152 Heath
Posted 16 February 2021 - 02:48 PM
My method with these primers on overlapping joints is wherever there's going to be a MIG weld (eg. plug weld like we're talking about here), is clamp it into position, then scrape all the paint off the surface through the holes you're going to plug up. You're not trying to weld onto the painted surface, lol.
Start the weld in the middle of the hole to get a bit of temperature into the weld and then quickly move to the edge where it connects with the bit with the hole in it.
Lots of amps, will keep the weld flat and the penetration sound.
Argoshield only, 10L/min flow rate should be adequate. A small (proper, not the disposable type) bottle should last you AGES (like my Argoshield probably lasts me 3 years, although I would empty a TIG bottle which is used in a slower welding process might only last me 4 months).
Edited by Heath, 16 February 2021 - 02:49 PM.
#153 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 16 February 2021 - 11:38 PM
Thanks for the advice guys, I took weld through too literally I think haha.
I have the smallest of the proper bottles. The mixed gas was set to 10L min and the argon only had to be set to 30L min for a decent weld. Dad set it up so I guess I trusted his judgement.
Will only be buying the mixed from now on as it welded a lot nicer than the argon on its own.
I'll get a bottle of the mixed gas this week and reset the welder to suit. Hopefully them I can get the last bit of the drivers side rail done.
Then I'll give the floor inside a lick of KBS black after a clean up.
#154 Rockoz
Posted 17 February 2021 - 01:07 PM
Ive never needed anything like 30 litres per minute for ANY welding.
10 is generally okay, up to 12 as a max.
If that isnt working for you, then something is wrong.
#155 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 17 February 2021 - 04:33 PM
Anything below that was spattery shit. Ah well back to the mixed gas tomorrow hopefully.
Started the drivers side rail repair where the gearbox crossmember is.It looks better than it was, note the bend in the Reinforcement plate for reference to how squashed it was.
before:
Attached File  FB_IMG_1613543168214.jpg   81.3K   5 downloads
Attached File  FB_IMG_1613543173124.jpg   90.98K   5 downloads
Floor cut:
Attached File  FB_IMG_1613543178748.jpg   37.59K   5 downloads
Reinforcement plate out, note the bend before and after.
qAttached File  FB_IMG_1613543181204.jpg   95.25K   5 downloads
Attached File  FB_IMG_1613543184133.jpg   100.03K   6 downloads
Rail bashed relatively straight again.
Attached File  FB_IMG_1613543189917.jpg   58.98K   5 downloads
#156 rodomo
Posted 17 February 2021 - 09:08 PM
:spoton:
#157 Rockoz
Posted 18 February 2021 - 12:46 PM
As far as the gas goes, I have a bottle of both.
I havent set up my welding trolley yet, so I move my steel MIG between the truck in the yard I am working on, and the shed where I do the most welding.
One bottle is in the shed, the other beside the truck.
I dont care which gas I use, and the welds are okay with either.
The only real difference I can see is the colour of the smoke marks around the welds.
Although its not ideal, the gas shouldnt make a huge difference in the weld quality.
Im looking more at the person.
When you weld, get up close and personal with it. The only thing you should be watching is the weld puddle, and to a lesser extent, where your weld is going. If you watch the puddle you can see exactly what is happening with what you are doing.
Ive welded tube together and gone off track many a time, but it was still a good weld.
Just meant a bit more grinding to tidy things up.
Didnt look the greatest, but it did the job it was meant to do.
I dont care too much about the look of the weld.
I dont profess to being a welder.
I am actually more of a grinder.
Years ago I watched in awe as a mate of mine built a tow truck back for another mate.
It was made entirely of chequer plate steel.
He took the time to line up the chequers so they matched up in line with each other.
He welded the entire job with a stick welder.
There was not a single grind mark anywhere.
He had a 9 inch grinder, but it was only used with a cutting disc, and rarely at that.
He cut most of it with an oxy.
He was a top class boilermaker, and it showed. But that was his job.
He could even cut a round hole in a plate that was good enough to run a tap through later. Freehand.
Dont be too hard on yourself.
Its a learning process.
But maybe do some more practice welds.
0.9mm electro gal sheet is only about 50 bucks for a 2.4 x 1.2 sheet.
Cut one up and practice practice practice.
#158 claysummers
Posted 18 February 2021 - 01:11 PM
What Rob said
early Holden nut
#159 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 18 February 2021 - 05:13 PM
Got the mixed gas today and changed the settings and the welds were a lot nicer.
Welded the plate back to the rail. Might get the floor section in tomorrow arfer work.
Attached File  FB_IMG_1613631447337.jpg   97.48K   6 downloads
#160 rodomo
Posted 18 February 2021 - 09:10 PM
You're doin orite Steve for a bloke that was worried about tackling this stuff  :D
#161 toryman76
toryman76
  • 1,082 posts
Posted 19 February 2021 - 06:45 AM
Super job Steve nothing wrong with those repairs. One thing I thought of with my welder that's worth noting. When I use the gasless wire I have to swap over the neg and pos on the earth lead. No idea why. I did it a couple of times when I was desperate but I hated the gasless wire so I never use it now.
#162 Rockoz
Posted 19 February 2021 - 07:53 AM
I tried gasless with the first budget MIG I bought.
It was kind of okay on anything about 2mm and thicker.
Was reasonable full belt on 6mm.
Got the shits with it really quickly and bought a little gas bottle from Bunnings, and some new wire.
Got about 10 inches of weld done and it went crappy again.
Bottle had run out. Bought 2 more before I bit the bullet and bought a regulator and opened a Gasweld account.
Eventually bought a decent MIG and went to Coregas. Gasweld rental costs were getting way up there.
Only time I have really had success with gasless wire was when I was helping a mate hardface some buckets.
Think it was 1.5mm gasless wire.
Was using a 400 amp machine to do it.
Loved doing that job for a day. Not sure I would want to do it full time though.
#163 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 19 February 2021 - 06:03 PM
Thanks for the advice guys, I think I've got the settings sorted now.
Rodomo, I over think everything and always doubt my capabilities haha.
Anyway floor welded back in. Welds came up awesome with minimal grinding. only 2 pin holes I had to touch up. it was difficult lining the piece up to go back in as the whole floor was warped and dented upwards. I had to knock it back down in a few spots.
Maybe someone used it for some rallying at some point? Either that or it was without a doubt paddock bashed.
Attached File  FB_IMG_1613721061127.jpg   93.66K   9 downloads
Attached File  FB_IMG_1613721064122.jpg   56.75K   7 downloads
#164 yel327
Posted 19 February 2021 - 06:22 PM
Just a Torana, they dint and bend pretty easily. Plus side is they also straighten out pretty well when pulled back. If you’d seen how they performed in demo derbies in the 90’s you’d get it. I remember totalling one with one hit, it crumbled almost as fast as a Volvo 200 Series in the same derby. I was in a HG wagon, but nothing was a match for those Aussie designed Holdens, tough as old boots but they weren’t really designed to crumple either.
#165 claysummers
Posted 19 February 2021 - 07:02 PM
Keep at it Hawk
#166 Rockoz
Posted 20 February 2021 - 11:51 AM
I will be honest with you.
What you are managing to do with your repairs is a lot better than a lot of panel beaters would do.
One panel beater I know well does welds that are about 10% of the quality you are getting.
And thats in the actual weld.
His eyes arent the best and a stitch weld will start on one piece, cross over the join a little than continue on the other side of the weld.
So he would be lucky to get 10% of the weld actually done.
A bit of body deadener covers a multitude of sins.
His painting wasnt much better.
Cant understand how he remained in business to be truthful.
He is retired now, and doing projects in his shed.
#167 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 20 February 2021 - 07:11 PM
Thanks thats good to hear haha. I always worry about getting others to do work on my cars.
Anyway cleaned up the passengers side front floorpan, etch primed then KBS rust sealed it.
Hopefully I'll get the rear passengers side pan done tomorrow.
Attached File  FB_IMG_1613806860559.jpg   83.45K   9 downloads
#168 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 21 February 2021 - 06:26 PM
Attached File  FB_IMG_1613895158688.jpg   97.16K   9 downloads
Attached File  FB_IMG_1613895162009.jpg   75.85K   11 downloads
#169 Holdenbn74
Holdenbn74
  • 152 posts
  • Name:Brendan Nichol
  • Car:LH
Posted 21 February 2021 - 10:49 PM
Good work mate, keep at it. Great feeling completing it yaself 👍
#170 Heath
Posted 27 February 2021 - 04:25 PM
Excellent repairs, Steve. Nice one.
#171 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 03 March 2021 - 07:31 PM
Thanks, still plugging away slowly.
Got some more of the floor painted, should finish it this weekend.
Ordered new B and C pillar vinyl. Went with black as nothing else was close. It will do for now.
To finish off the interior for now I still need:
Seat bolts
seat belt bolts and potentially new belts.
Carpet and underlay
replacement auto T-bar handle (may go with a hatch style one)
Kick panels (can wait for now)
pinch weld (may reuse for now)
If the screen has to be replaced I will replace the headlining too as its pretty rooted where it meets the B pillars and door jams.
Attached File  FB_IMG_1614759623104.jpg   88.18K   6 downloads
Attached File  FB_IMG_1614759625883.jpg   88.1K   5 downloads
#172 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 06 March 2021 - 05:10 PM
First coat on the passengers side rear pan.
As I've been doing the floor the mystery as to this cars past deepens. All signs point to a previous cut and shut through the centre of the car.
behind the centre floorpan brace all the spotwelds across the floor have been re done same with the rear of both chassis rails. Also some in front of the floor brace as seen below.
I can't imagine a UC ever have been worth a cut and shut like that in the past.
Attached File  FB_IMG_1615014275528.jpg   95.82K   4 downloads
Attached File  FB_IMG_1615014278098.jpg   67.29K   5 downloads
Attached File  FB_IMG_1615014280900.jpg   73.91K   4 downloads
Attached File  FB_IMG_1615014284524.jpg   47.19K   4 downloads
Attached File  FB_IMG_1615014290355.jpg   81.74K   5 downloads
#173 yel327
Posted 06 March 2021 - 06:33 PM
Has it been cut across the inner sill or did they unpick those off the outer sill? How it’s done is how we used to repair tonners and utes, use the whole front from that floor joint right around to the windscreen pillars, doors, dash and all. You’d cut a GTS, Statesman or Premier and transfer the whole lot onto the commercial cabin and rails. Engine, box etc too.
#174 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 07 March 2021 - 01:16 PM
I've seen worse - I bought a Gemini once that was later found to be made of three different cars, roof & b pillars from one, front end and rear end from two others...
#175 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 07 March 2021 - 02:16 PM
I'll hopefully get some better photos later today, its deffinitly welded through the inner sill.
Also explains the bog in the roof.Rear half looks to have been maroon
