186 rebuild, Oracle advice
#226
Posted 14 July 2021 - 09:27 PM
#227
Posted 14 July 2021 - 11:04 PM
#228
Posted 15 July 2021 - 07:02 AM
#229
Posted 26 July 2021 - 04:05 PM
Anyone seen this adjustable relief valve spring preload device before?
early Holden nut
#230
Posted 26 July 2021 - 05:45 PM
A previous owner (#3 probs) had it fitted when racing..i guess??
Ive never mucked with its adjustment.
#231
Posted 26 July 2021 - 06:37 PM
#232
Posted 26 July 2021 - 10:30 PM
Edited by rodomo, 26 July 2021 - 10:38 PM.
#233
Posted 26 July 2021 - 11:25 PM
early Holden nut
#234
Posted 21 November 2021 - 05:01 PM
early Holden nut
#235
Posted 21 November 2021 - 05:04 PM
early Holden nut
#236
Posted 21 November 2021 - 05:17 PM
early Holden nut
#237
Posted 21 November 2021 - 06:58 PM
https://www.ebay.com...afffbe240|iid:1Not cheap.
Edited by Indy Orange, 21 November 2021 - 06:58 PM.
#238
Posted 21 November 2021 - 08:27 PM
#239
Posted 21 November 2021 - 09:06 PM
Yep someone will have an old HR lying around.
#240
Posted 21 November 2021 - 09:26 PM
#241
Posted 21 November 2021 - 09:58 PM
#242
Posted 22 November 2021 - 09:33 PM
#243
Posted 22 November 2021 - 10:20 PM
#244
Posted 23 November 2021 - 05:55 AM
#245
Posted 23 November 2021 - 07:13 AM
#246
Posted 23 November 2021 - 11:10 AM
early Holden nut
#247
Posted 27 November 2021 - 02:19 PM
Share whatever oily vapuor there is more evenly between cylinders
Seems a shame to drill into your x2 manifold though.
Could little spacers under each carb be made with a tube in each?
No news in this page for 4 months... engine must have been going well.
Job done
#248
Posted 27 November 2021 - 04:00 PM
Anyway the motor is going well. Putting out of my mind the issue of a couple of lifters still not rotating as they should last I had the cover off. I have to adjust the rockers yet. They are a but rattley when cold but quiet down when warmed up. I initially set them with about 0.005” lash warmed up. I don’t know where I got that idea from. Probably from doing the grey in mrs summers FC.
Set the carbs up with a very simple modification to the original accelerator linkage. I was planning to use an HZ throttle cable and adapt to original pedal, but got too hard, and the original linkage works fine for now. Nice to have some original mechanicals on the car. Started up minus exhaust a couple of times. Tempting to go for a short run but I’ve got a tilt tray booked for a trip to Aldinga Radiators and Exhausts on Tuesday. Due for inspection at Lonsdale In two weeks.
#249
Posted 27 November 2021 - 05:17 PM
Sorry to make suggestions that I know would be a pain in the erse,
easier said than done, especially if it's someone else doing it.
Hope you can swing it though.
The .005"lash was on the cm205 cam? Isn't that a hydraulic number?
If I understood that right, I'd love to know if you've been running this long
set up that way without problems
Does your ute car need an inspection?
#250
Posted 27 November 2021 - 11:39 PM
Increased displacement from 138 to 186 and fitted HR balljoint disc front. Requires inspection, brake fade and Db test. No engineer.
early Holden nut
