186 rebuild, Oracle advice
#276
Posted 18 December 2021 - 07:58 AM
#277
Posted 18 December 2021 - 09:19 AM
#278
Posted 18 December 2021 - 09:25 AM
1.6 ratio rockers will pull a bit harder against the studs
Agree, stick with the std 1.5:1 ratio.
#279
Posted 18 December 2021 - 09:46 AM
Three piece rocker arm. I hope I got all the bits. I suppose the roller rockers will fit under original cover? I was going to put one on with 179X2 decal.
#280
Posted 18 December 2021 - 12:55 PM
Posted 18 December 2021 - 01:20 PM
#282
Posted 18 December 2021 - 01:26 PM
#283
Posted 18 December 2021 - 01:54 PM
I think in the absence of evidence that your rockers are binding on anything that you are seeing the results of fatigue from not running them with the correct preload. Every time they are activated they get a whack from the valve train and this cumulative fatigue is showing.
Millions of holdens have survived for ever with those stamped steel factory rockers set up correctly.
#284
Posted 18 December 2021 - 02:51 PM
Yep.
#285
Posted 18 December 2021 - 04:35 PM
#286
Posted 14 February 2022 - 02:55 PM
#287
Posted 24 February 2022 - 09:45 AM
Some of the old arms look pretty dodgy now I look at them. Pre existing damage I should have noticed initially rather than just throwing them on. They were from a mixture of old heads so who knows?
The opposing surfaces are all fine.
#288
Posted 24 February 2022 - 02:23 PM
#289
Posted 12 April 2022 - 12:51 PM
Front three have a fair carbon build up. The rest are a nice brown. I'm wondering if front carb is a bit rich. Champion NI 2 Y on 98 unleaded. Though they look fine, I will get some new ones. Any suggestions?Might try leaning out the idle on front carb.
#290
Posted 12 April 2022 - 02:13 PM
Spent an afternoon at Oran Park many years ago watchin unofficial practice.
A couple of crews in particular as they were working together.
Sports Sedans from memory.
When they checked the plugs for colour it was after a run at full noise down the straight, then the engine shut off pretty much at top revs.
They towed the car back to the pit area then checked the plugs.
They had banks of plugs of different temp ranges as well as an aluminium plate loaded up with multiples of every jet size and power valve size.
Does the colour really matter if the engine has been idling?
I know it is different applications, race vs street.
#291
Posted 12 April 2022 - 03:26 PM
#292
Posted 12 April 2022 - 03:42 PM
#293
Posted 12 April 2022 - 03:53 PM
#294
Posted 12 April 2022 - 03:58 PM
New rotor and cap for sure
#295
Posted 12 April 2022 - 04:23 PM
Any elaboration on that Adam?I would pull 2 degrees timing out also.
#296
Posted 12 April 2022 - 06:35 PM
Yep, that kinglead to rotor contact is tiptop,
surprised it isn't running worse than a bit fluffy
How old are those plugs? Even the bit outside of the head looks cruddy
Rotor, cap and plugs might get rid of the fluffies
Those crow rockers look like a good buy, too
#297
Posted 12 April 2022 - 09:20 PM
Yes the Crow rockers a bit under $300 peace of mind.
I was surprised how well it was running. I got 12.5 litres/100km on a recent tank full. The plugs were from the previous motor and in it when I painted it a dark grey hence they look grotty. But they had only done nominal km in that motor.
I'm looking forward to running it after this ignition freshen up. The leads appear to be good. I suppose I could test resistance and clean them.
#298
Posted 12 April 2022 - 10:28 PM
At least if you still need to you can start on the carbs
knowing the ignition is as good can be
#299
Posted 12 April 2022 - 10:41 PM
#300
Posted 13 April 2022 - 06:57 AM
Looking at those though you can still see the colour change on the ground strap is too close to the thread. It should be in the middle of the apex.
Closer to the thread indicates more timing than needed for the efficiency of the head.
