186 rebuild, Oracle advice
#551
Posted 01 December 2023 - 08:52 AM
FB ute fixer upper, EK van on rotisserie
#552
Posted 01 December 2023 - 09:00 AM
#553
Posted 01 December 2023 - 01:11 PM
That rear main crank journal might be a bit out of round
Maybe worth plastigaugeing it in a couple of other spots to find out.
If you found a low spot it might be tighter everywhere else and
you may get away with it. Worth at least looking into further then, anyway
1.5 thou seems pretty tight? But those ones looked good
Did you have good oil pressure before it all came apart?
#554
Posted 01 December 2023 - 03:01 PM
I an thinking of fitting thus chrome sump, but a mate thinks it will be prone to leak. It was on an old speedway car if I recall. Came from a guy on here a couple of years ago. I suppose he thinks it may be brittle from the chroming, and crack.
#555
Posted 01 December 2023 - 03:26 PM
If you check around the mounting flange and panelbeat
it back to flat before it goes on I would think it’d be ok
And lovely and shiny
Could check you look ok next time you are under the car grumbling and swearing
Looking for oil leaks
#556
Posted 01 December 2023 - 06:01 PM
#557
Posted 01 December 2023 - 06:32 PM
#558
Posted 01 December 2023 - 07:58 PM
#559
Posted 01 December 2023 - 11:20 PM
#560
Posted 04 December 2023 - 05:57 PM
#561
Posted 05 December 2023 - 06:29 AM
Assuming 1.1mm head gasket and factory chamber volumes quoted by Byron, gives me 8.6:1 large chamber, and 9.6:1 small chamber head.
#562
Posted 05 December 2023 - 07:23 AM
Can you get a thinner gasket? Others here will know a lot more than me about these, but when I was reading up about what to deck the 350 block for my HK I remember reading the following (and remember this is on a SBC but I guess it translates):
Target quench area is 0.038-0.041" (piston clearance to head surface). Most factory pistons sat 0.020-0.025" down the hole so the original steel shim head gaskets (part number 10105117) were around 0.015-0.020" to maintain that approx 0.040" quench distance. Aftermarket generic gaskets are typically about 0.040" as they assume you are cleaning up both the head and deck surfaces about 0.010", or you are near zero decking the pistons and have new heads. The revised version of 10105117 to make it more suitable for used engines is now 0.028" thick.
So, if the above applies to a red 6, with your pistons down the hole 0.035" you want a thinner gasket but finding one is going to be the challenge! Ideally you should have decked the block so the pistons sat maybe 0.005-0.010" down the bore and used a 0.030" thick head gasket? But it looks like the thinnest around is a 0.040" Cometic. For SBC's they are available from about 0.025 up to over 0.100".
#563
Posted 05 December 2023 - 10:13 AM
#564
Posted 05 December 2023 - 03:27 PM
Everything else I found was a variant of the ag390 part number, and no decent info on
any of the differences between them all. Gsag390d, ag390r etc.
permaseal, durapro same part numbers
They all also have bh110 as a part number, and the same “gs” pre and “d” after version.
Don’t know what they’re playing at
Seem to remember finding only one place stating they were .047”which is 1.194mm
Almost as if it was some kind of secret
#565
Posted 05 December 2023 - 05:28 PM
#566
Posted 05 December 2023 - 06:39 PM
Slugs 35 thou down the bore is a long way.
With a 40 thou gasket your quench are will be 75 thou and right in the so called danger area (more prone to detonate) or so i have read. Probably not an issue because your not running big comp, just wont be as efficient i guess.
Bruce is right, 40thou cometic is the thinnest we can get.
I believe the thinnest stock gaskets install to 47thou. Get a graphite one if you dont want to pay for a cometic.
#567
Posted 05 December 2023 - 07:31 PM
Would be the same for either head
Small chamber one would have a bigger quench area to quench with
What was the ideal comp ratio Marshalls gave you for the cam, Clay?
Just mathed it out, 35 thou at a 186 bore of 3.625 is 5.9cc
If it’s any use to you, I vaguely remember my motor’s maths telling me
that 4cc was worth around half a point of compression ( from 10:1 up)
Maybe could help choosing which head to use , if you deck the block.
You’ve got me wondering since you measured a used gasket at .028
wether they squeeze down to that or not??
Would give you .063”
Maybe too much for folks chasing bulk power, but might be ok for your sensible motor
Have seen discussions saying .040 is game, and .030 is risky.
We’re the old pistons closer to the top?
I wonder what factory engines pistons measured up to
Actually, looking at Adam’s point about .075 being no good,
.063 isn’t too far off that, really
#568
Posted 05 December 2023 - 07:33 PM
#569
Posted 05 December 2023 - 09:07 PM
#570
Posted 06 December 2023 - 06:28 AM
The advice the machiners gave me was to try and sit the pistons 10 thou down the bore and use 28 thou gaskets to get that magical 40 thou-ish quench height. The 10 rather than zero or 5 thou was to allow for a future deck clean up if needed, at which time I'd jump to 35 or 40 thou gaskets. But I have that luxury with SBC head gaskets. This is actually where I'm up to with this 377ci engine at the moment, I just have to get the time so dummy fit the crank and a piston in each corner to check the deck height and piston clearance in each corner so they deck the block to make it 10 thou across the decks.
#571
Posted 06 December 2023 - 07:23 AM
Advertised duration cam families vs static compression ratio's here.
248/250/252 = 8 to 1;
258/260/262 = 9 to 1; (The 266 can go either way).
268/270/272 = 10 to 1; (Same with the 274 can go either way).
278/280/282 = 10.5 to 1; (Same with the 284).
288/290/292 = 11 to 1; (Same with the 294/296).
and
300 = 12 to 1.
Seemed to work pretty good, but these are for the older cams.
There are a whole bunch of things that affect this such as; aluminum head vs iron, camber shape and type; quench distance and headgasket thickness; of course fuel octane; timing; etc., etc...
Degrees at the seat, obviously
Just a bit more food for thought
#572
Posted 10 December 2023 - 09:29 AM
I didn't fill the lifters with oil prior to installing, just drizzled some in the tops, and when I adjusted the rockers, I set them so the lifter started compressing very slightly.
I packed Vaseline around the pump gears, but I think I will fill the pump with oil before I install the pick-up. So I've packed the tube with more Vaseline to prevent gravitating back into the sump. I will fill the filter as well.
Considering this I plan to install plugs and fire straight up to 2000rpm, rather than try and prime with the starter motor. Cam and lifters are well covered in molybdenum and will get oil quickly.
#573
Posted 10 December 2023 - 10:42 AM
Only thing to be careful of Clay. I've used Vaseline in the past and it formed a plug that blocked oil flow and stopped it building pressure. So since then I've always used thin grease. This was on a red V8 that I had the issues.
#574
Posted 10 December 2023 - 10:48 AM
#575
Posted 10 December 2023 - 11:20 AM
