186 rebuild, Oracle advice
#601
Posted 29 January 2024 - 08:54 PM
I want to do another tank of cruising on the old head to test the fuel consumption before I swap the new one on. So far seem to be using more fuel with the SUs, which I wasn’t expecting.
#602
Posted 29 January 2024 - 09:43 PM
Been a lot of years since I've seen a Holden head with such small valves & not ported.
#603
Posted 29 January 2024 - 09:53 PM
#604
Posted 30 January 2024 - 06:22 PM
He uses someone in Sydney to supply needles etc. so now I am wondering if I may need to richen things up at all. At the moment it is running pretty well, although I’m not sure it picks up as well as with the old cam and tune. It doesn’t crackle and pop on over run like it used to either. May just be difference in the timing.
According to the builder the new head is around 10:1 static. It should flow a bit more and have a bit less back pressure. Cam is very mild spec either 0.435” lift, 109 separation and 205 duration at 0.050”. Factory cast headers, straight through muffler and 2” full exhaust with fairly short secondaries. Currently running TW needles and red springs.
#605
Posted 31 January 2024 - 10:21 AM
#606
Posted 31 January 2024 - 01:55 PM
Forgot to say that the TW needles are sitting in 0.010" jets, HS6 carbs.
I'm hoping for recommendations on needles to suit from the wise ones.
#607
Posted 31 January 2024 - 09:25 PM
#608
Posted 01 February 2024 - 04:44 AM
#609
Posted 01 February 2024 - 06:01 AM
Having a cam that is close to std, needle selection is harder. Have a look at an Austin Healy 3000 needles, that might give you something to look at.
I built a 173 last year, the new pistons were .040" down the hole, before machining.
#610
Posted 01 February 2024 - 07:09 AM
I'm no expert but if you have larger exhaust valves and better exhaust (as in X2/S headers and larger pipes) it will probably lean off a bit. From memory that is what happens to a standard red 6 when you put extractors and bigger exhaust on it. I'm not sure larger exhaust valves are going to have any performance increase, but the exhaust should.
Stick a magnetic dial gauge on the pistons at TDC and measure the deck height, if its 40 thou down then you might be looking at 9:1-ish compression static. Which should be OK with a small camshaft.
#611
Posted 01 February 2024 - 08:58 AM
Made it pretty….
#612
Posted 01 February 2024 - 10:45 AM
You probably did, even posted it but I forgot. Same as I forgot you'd put larger exhaust valves in! You'll be fine with static compression ratio with pistons 35 thou down the bore, but IIRC it will also mean more risk of pinging with them that far down regardless of the static compression ratio.
To show the difference it makes I entered info into a compression ratio calculator for a HT-HG GTS350 manual engine:
4" bore
3.48" stroke
64cc chambers
8cc valve reliefs in the pistons (effective dish).
10 thou deck clearance.
25 thou compressed gasket thickness
8 cylinders.
Comes out at 10.04:1. GM almost always rounded up to the nearest 0.25:1 so this was advertised as 10.25:1.
If I change the gaskets to 38 thou compressed (which is typical of these gaskets) and drop the pistons to 35 thou down the hole it drops to 9.22:1. Using 38 thou gaskets with something like 5 thou deck height it is 9.85:1.
Have a play with 6cyl numbers:
https://www.summitra...sion-calculator
#613
Posted 01 February 2024 - 12:24 PM
What I am asking for though is advice on needles. Helped before (Bruiser)……………
#614
Posted 01 February 2024 - 02:24 PM
I’ve been having a think and checking out that TW against the OA7 on the comparison graph from
https://www.classicm...chnical/needles
also because salamiman has bought it up too.
I am sorry those ones didn’t end up working out for you
I tried them on the advice of someone here with an engine very similar spec to how mine
was at the time, he was using the weaker blue piston spring as well!
Your motor is even more sensible than mine was then, so you should need a leaner needle than I did, logically.
I never got that quite right, I don’t think.
I had a chat a while back on the pm with a fella here who had used 0A7 needles in his su’s
With 3 cams he described as 25/65, 30/70 and with a big crow 35467 as well
He raced a 600hp speedway car, so I guess he knows a bit. I did quiz him on the needles,
and he said they worked fine with each setup.
Maybe the hotter his motor became, the lower he would drop his jet to riches things up for mid to top end,
which brings the idle richness up too. Maybe acceptably (within reason) ?
The OA7 and OA6 come up all the time in discussions, and the comment about “old timers swearing by them” does too.
They both have a fairly even progressive taper on the graphs, maybe that is well suited to the Holden 6 generally(?)
If you are looking to buy (hopefully) the ideal set before your dyno tune, maybe someone else has the knowledge to
give the right advice, but I think the best we could get is a rough guess. And they’re really not a cheap guess, either
Those TWs could be reshaped to be close to an OA7, if you are game and patient enough..
I’ll help you out if you want to have a go
Maybe the dyno feller has an idea, if he’s done a few of these?
Head looks nice, there’s nothing like a brand new one all nice and fresh
I can’t see any deshrouding in the chambers, just a bit of grinding on the exh port floors
Did he need to even them up a bit out something?
I bet having your dizzy regraphed will make a huge difference
#615
Posted 01 February 2024 - 06:28 PM
#616
Posted 01 February 2024 - 06:34 PM
#617
Posted 16 February 2024 - 03:27 PM
I may have damaged some of the valve stem seals when I put the soft springs on, possibly accounting for numbers 2 and 4 being oily. 3, 5 and 6 have pretty unform whitish grey cathodes. Electrodes are pretty uniform, with a small amount of soot. Apart from no 2 the insulators are pretty uniform I think, though 3 has some soot.
#618
Posted 18 February 2024 - 02:22 PM
And running lean.Sent from my SM-G781B using Tapatalk
#619
Posted 18 February 2024 - 02:54 PM
They do look a bit crudded up with oil, too.
They don’t look as lean as the exhaust valves do, anyway
at least the valves aren’t completely white.
New head with nice guides and seals should make a nice improvement
#620
Posted 18 February 2024 - 08:30 PM
Edited by claysummers, 18 February 2024 - 08:34 PM.
#621
Posted 18 February 2024 - 09:35 PM
The plug straps look a bit hot? Too much advance?
#622
Posted 18 February 2024 - 11:09 PM
#623
Posted 19 February 2024 - 04:14 AM
#624
Posted 19 February 2024 - 07:24 AM
Speaking of valve stem seals , the rubber square section ones that are supplied with gasket kit tend to harden after a while with heat and oil and then let a bit of oil past . If they were possibly damaged on installation then that is another story. I recently had to "tidy up" some valve seats etc. on a 186 and found every valve stem seal was hard and just broke apart and this thing had done hardly any miles.
Use viton o rings instead of the rubber seals , they handle the heat better than the rubber apparently . i forget what size i used but they are available in a size that does the job.
#625
Posted 19 February 2024 - 11:25 AM
Thanks for the tip though I’m sure I damaged them putting the retainers back on after changing to soft springs. I left the shrouds off also and if I recall correctly none were fitted when I got the head. It was only ever going to be a temporary thing.Speaking of valve stem seals , the rubber square section ones that are supplied with gasket kit tend to harden after a while with heat and oil and then let a bit of oil past . If they were possibly damaged on installation then that is another story. I recently had to "tidy up" some valve seats etc. on a 186 and found every valve stem seal was hard and just broke apart and this thing had done hardly any miles.
Running nice now, though I will need to re-set the tappets hot I think. It certainly pulls well. No pinging evident under load.
