there is a very simple fix,that i didnt think would work,but the dyno guy did it and its been great ever since.thats experiance for ya
Catch Can
#26
_moot_
Posted 15 October 2008 - 08:25 AM
#27
_The Baron_
Posted 15 October 2008 - 08:37 AM
I measured first and found I needed a clearance of about 17-18mm, so I set the baffle height at a max of 15mm.
I also figured that I could dent the baffle slightly if I need more clearance.
I paid what I consider is a hefty price for the work ($250) but the result is worth it.
Take note of the weld bead you can se through the hole. I had this done so the fitting could never be pushed through the grommet to the point it would seal off the hole in the PVC or hose fitting.
#28
Posted 15 October 2008 - 07:29 PM
the problem isnt oil drains.its crank case pressure.it doesnt matter how many breathers you have,a big hp (and stroke) engine will still pump oil out of the breathers.
gonna share?
#29
Posted 15 October 2008 - 07:35 PM
_82911_
Posted 16 October 2008 - 07:02 AM
#31
_moot_
Posted 16 October 2008 - 11:16 AM
#32
_The Baron_
Posted 16 October 2008 - 04:21 PM
Care to share?----Dry sump?..........Slick 50 and no oil?.................Thin grease?........Never seize?
#33
_waz355_
Posted 16 October 2008 - 06:30 PM
You have our attention MOOT.
6 litres of Jonsons baby oil.
#34
_moot_
Posted 16 October 2008 - 08:12 PM
#35
Posted 16 October 2008 - 10:56 PM
#36
_82911_
Posted 17 October 2008 - 06:18 AM
An engine is an air pump, both top and bottom, any blow by from the induction and compression process has to be vented to atmosphere provided the holes are large enough to relieve the pressure adequately. The only other proviso is that the vent is above a level that oil reaches, otherwise oil will be pumped too.
Putting a vacuum in the sump by either a sealed motor and a dry sump scavenge pump or one of the comercially avalable vacuum pumps doesnt stop blow by or crankcase pressure, all it does is pull air at a rate greater than that which is added by the leakage from the combustion process.
ALL engines leak to the crankcase....ALL OF THEM. In NASCAR which is arguably the most highly developed V8 class in the world, the % of blowby is in the order of 2-3%. Everyone else leaks more...
MOOT.. if you have found a way to gain perfect ring seal.... QUICK, patent it because you are going to be rich!
Otherwise I'd like to hear this "magical" theory....
ALL EARS MATE.....
#37
_moot_
Posted 17 October 2008 - 07:52 AM
our problem was mulitplied by ultra thin rings and gas ported cp's,with some decent comp.
infact the car in question got used to get to half track at wsid and have smoke bellowing out of it,it was towed back twice cause of how much oil was in the engine bay,and that was with a catch can.
now,the car doesnt have a catch can at all,doesnt have any problems with smoke or fumes.
and it doesnt have any of the commonly tried things like,oil returns in the back of the heads,pipe cleaners in every second pushrod,tricky lifters etc
#38
_82911_
Posted 17 October 2008 - 08:58 AM
If that is the one, I would be interested to know how you resolved the problem.As it was "quite a breather"
PM if you like.
#39
_moot_
Posted 17 October 2008 - 10:35 AM
top guy,and he really knows what he's doing.
#40
Posted 29 October 2008 - 04:35 PM
Point..Local distributor is the Holden dealer...Having seen the car in the paper...the boys got all excited and decided I get the oil at wholesale...$27.50 for 5L..Thats cheaper than Magnatec on special...also..oil filters..genuine AC Delco are $5.20....Bonus day for me!!
Posted 29 October 2008 - 06:07 PM
#42
Posted 30 October 2008 - 10:50 PM
I've built a few catch cans(a can with a hose in it is a waste of time). Basically three chambers with the middle chamber filled with stainless scrubbing pads. I also have a drain in the bottom with a line running to the sump so it requires no maintenance. These are on 6cylinders. I have also put extra baffles in the rocker cover.
The more you make the crankcase air turn the more oil you can pull out of it.
If the rockers are filling with oil then you gotta improve drain back within engine and/or reduce oil to the top as no catch can will do the job
#43
Posted 31 October 2008 - 07:52 AM
has anyone here done this ?
Evan.
#44
_moot_
as for not posting anything,well i'm sure that the people i've helped through pm's would still be in trouble.
#45
Posted 31 October 2008 - 09:15 AM
#46
Posted 31 October 2008 - 09:41 AM
#47
Posted 31 October 2008 - 10:05 AM
Posted 31 October 2008 - 10:31 PM
#49
Posted 03 November 2008 - 01:26 AM
An incorrectly designed one not using PCV, there could be an issue with gunk.
You can also have a catchcan on the PCV side that operates under normal driving. Can be an issue if draining that back into engine as it has alot of water condensate on this side.
I think alot of guys dont really know what is happening in this department and putting (hi rpm blowby) catchcans in the wrong places
Re capacity: if draining back you dont need much capacity, just need to make sure that the catchcan design can blow the required amount of air so that it does not pressurise the insides of the engine
Edited by turbotrana, 03 November 2008 - 01:28 AM.
#50
Posted 04 November 2008 - 10:01 AM
I need to make something up soon for my turbo 202, I would like to keep it sealed if possible to keep things legal. Is yours fully sealed?
