hawks uc sunbird
#226
Posted 07 November 2011 - 10:09 PM
#227
Posted 08 November 2011 - 06:45 PM
#228
Posted 08 November 2011 - 08:04 PM
#229
Posted 08 November 2011 - 09:06 PM
also seemed like oil coming out the exhaust but turned car off and then ran again and it wasnt there so may have been condensation
#230
Posted 09 November 2011 - 07:08 AM
#231
Posted 09 November 2011 - 09:09 AM
also how will i tell if a lobe.is wiped
#232
Posted 09 November 2011 - 10:27 AM
#233
Posted 09 November 2011 - 11:34 AM
#234
Posted 09 November 2011 - 02:02 PM
#235
Posted 09 November 2011 - 02:10 PM
#236
Posted 09 November 2011 - 04:34 PM
ok so after checking.the timing plugs leads coil dizzy cap and.comp and setting.anything.that was.wrong.right its running better nit when i spoke to.a.local.mechanic he told.me it was.overheating alot. so i changed the thermostat and put.coolant in... still no improvement. it also has a larger radiator with twin thermo fans . so i give up and its.off to the mechanics tomorrow
#237
Posted 09 November 2011 - 08:13 PM
#238
Posted 09 November 2011 - 09:32 PM
#239
Posted 09 November 2011 - 09:55 PM
1 cold and dry
2 hot and wet up to temp and with throttle wide ope open
180 psi is about 9-1 comp ratio
#240
Posted 09 November 2011 - 10:20 PM
#241
Posted 10 November 2011 - 10:28 AM
well the temp gauge.was.disconnected.when the last owner fitted the thermo.fans.but.its.the.fact that the heat.through the firewall is crazy and it.always feels like the heater is.on non stop... shouldnt get that.hot.inside the.car and the radiator.is still too hot.to touch even when the car hasnt been driven for over 2 hours
Check to see the cables are actually moving the flaps in the heater box. If you're still having problems, I'll have a bit of a look when I'm over getting the bits next week.
#242
Posted 10 November 2011 - 02:10 PM
does.anyone have some lower front control arms with ok rubber bushes for.cheap or free as im desperate here?
#243
Posted 10 November 2011 - 07:29 PM
#244
Posted 11 November 2011 - 10:01 AM
#245
Posted 15 November 2011 - 05:14 PM
#246
Posted 15 November 2011 - 06:49 PM
I've used this method many times with success and no danger. I have used a spring compressor and I found it more difficult and more dangerous than the above method. If the springs are quite stiff (like mine) the spring will be able to be installed without compressing the spring with the jack (and my car isn't low), this also means there is less spring energy released when the ball joint pops.
hth
#247
Posted 15 November 2011 - 07:07 PM
#248
Posted 15 November 2011 - 09:54 PM
#249
Posted 04 December 2011 - 07:17 PM
so now i need a new front guard, stub axle and disc guard. so pissed off
#250
_Leakey_
Posted 04 December 2011 - 07:47 PM
You know the day I picked up my hatch the rear wheel came off going around a corner? The fella was follwing me to LX5008's house and on the last corner
BAM! off she came, along with the drum. It shook the bog out of the car!!!! LOL.
I have some red UC guards, but they are a bit rusty mate, and in Sydney.
