hawks uc sunbird
#201
Posted 06 October 2011 - 09:27 AM
#202
Posted 06 October 2011 - 03:54 PM
what would a rough price be to have the block, pistons, rods and crank cleaned and fitted at an engine builder?
where would i buy new rings and bearings? and how much?
#203
_Woodsy_
Posted 06 October 2011 - 04:14 PM
#204
Posted 06 October 2011 - 04:20 PM
Performance Modifications.
Engine Reconditioning - Lilydale, VIC
5/ 2 Melba Ave, Lilydale VIC 3140, Australia
(03) 9739 4086 the guys name is ian he is very good and cheap plus he likes making stuff go fast
take all your gear down there to ian he can give you a price best get everything machined before you start buying rings and bearings ect do you no what cam your putting in it yet
what are you building the motor for a hotty or just a daily drive
#205
Posted 06 October 2011 - 06:35 PM
i just cleaned the tops of the pistons and they have std .001 on them does this mean they are standard bore size
It would appear they are close to stock size pistons. As for the rest of your questions, just follow Ryans advice .
#206
Posted 17 October 2011 - 06:47 PM
could it be because the petrol tank has run dry twice recently? could it have damaged the fuel pump?
i checked the filter and it was clean and replaced the air filter.
it runs fine at higher speeds but near idle it just dies every few mins
#208
Posted 01 November 2011 - 04:43 PM
found that there was a vacuum leak off the carby and the coil and no.5 plug weren't working. shows how much they will put up with as it was still going on 5 cylinders with a coil that was leaking fluid and 2 vacuum leaks. the second one hasn't been found yet but ill have them all replaced soon. And hopefully a better gearbox will be going in this week because the current one slips a bit and has a loud clunk when changing thats getting worse. could the clunk be the diff by any chance?
also put a new exhaust bracket in as one snapped but its still hitting on the diff.
does anyone know where i could get a 350 holley and manifold or twin stromberg manifold for cheap? on ebay most of it is over $150
#209
Posted 01 November 2011 - 05:34 PM
#210
Posted 01 November 2011 - 06:43 PM
#211
Posted 01 November 2011 - 06:52 PM
#212
Posted 01 November 2011 - 07:20 PM
#213
Posted 01 November 2011 - 08:13 PM
#214
Posted 01 November 2011 - 08:51 PM
#215
Posted 01 November 2011 - 09:10 PM
#216
Posted 01 November 2011 - 09:14 PM
#217
Posted 01 November 2011 - 09:53 PM
#218
Posted 01 November 2011 - 11:50 PM
#219
Posted 02 November 2011 - 07:13 AM
#220
Posted 02 November 2011 - 09:27 AM
#221
Posted 07 November 2011 - 01:08 PM
what do u know massive bush failure on the passengers rear haha
#222
Posted 07 November 2011 - 02:03 PM
#223
Posted 07 November 2011 - 06:09 PM
#224
Posted 07 November 2011 - 06:12 PM
Couple of guys put them in, lowered their cars, and when they went to do something a month or so later, bushes in a little pile on the floor, and the cars hadn't even been driven.
#225
Posted 07 November 2011 - 06:18 PM
