cheers sting
hawks uc sunbird
#176
_sting_
Posted 05 September 2011 - 08:47 PM
cheers sting
#177
Posted 07 September 2011 - 08:31 PM
#178
Posted 08 September 2011 - 11:03 PM
#179
Posted 08 September 2011 - 11:46 PM
#180
Posted 08 September 2011 - 11:54 PM
#181
Posted 09 September 2011 - 10:45 AM
#182
Posted 09 September 2011 - 09:02 PM
#183
_UCV80_
Posted 09 September 2011 - 09:27 PM
#184
Posted 10 September 2011 - 11:10 AM
#185
Posted 10 September 2011 - 12:33 PM
#186
Posted 10 September 2011 - 03:53 PM
#187
Posted 10 September 2011 - 05:42 PM
#188
_L32M20_
Posted 10 September 2011 - 08:12 PM
Matey, this is an LX, and is the plenum chamber, but with the top section unpicked.
Gives you an idea of what is going on down there. Stupid bloody design not being able
to get to it eh!?
This is LX5008's SS, and he is using a UC donor panel in there.
I've just discovered a lot of rust on my driver's side, and will do the unpicking job,
even though it wasnt really in my initial plans. But its the ONLY way to ensure no water leakage.
The 'coconut hair' hides all......
If you dont want to do all that, may I suggest you remove the lot. The whole dash. Its an easy job.
You wont lose much blood, just a bit when unclipping the speedo. Oh and its great when you're all contorted
and trying not to cut yourself on razor sharp rust, and a huntsman runs out at you up your arm. Aaaaaaahhhhh!!!!!
mate thats pissfunny ........................thanks for the laugh.........love agood huntsman gag
#189
Posted 10 September 2011 - 09:41 PM
New diff is up and running brakes bled and new oil... the speedo is out by 10+ kph how do i fix that
You need a yellow 24 tooth gear.
#190
Posted 10 September 2011 - 09:48 PM
#192
Posted 15 September 2011 - 09:02 PM
bought drivers front guard and front door, scuttle panel, front apron and boot lid. ill be picking up the other 3 doors this weekend. id also like to thank
chopper for all the panels and the diff
Posted 04 October 2011 - 10:48 PM
are these good pistons ?
over the next few months im hoping to build a new motor for the car plans are
red 202 block
blue 202 crank or blue 173 crank if this is possible
starfire rods
the acl pistons
light port work on the head
and im unsure on which cam, manifold and carby to use. im hoping to build this as cheaply as possible as
i dont have the most money and i should save alot of money as the block doesnt have a lip and shouldnt
need machining
#194
Posted 05 October 2011 - 07:02 AM
#195
Posted 05 October 2011 - 12:29 PM
the red 202 had some fairly deep scores in the 3rd cyl does that mean its needs to be boted out and i cant use the acl pistons?
how do i find out what oversize the pistons are ?
If i was to use a blue 202 block i have (bores are good) how do i tell if the bores are stock, would i be able to use a blue 173 crank i have in the 202 and would i be able to use a 9 port head i know 12 ports cant be used on red motors so im guessing same the other way around?
#196
Posted 05 October 2011 - 07:02 PM
#197
Posted 05 October 2011 - 08:49 PM
#198
Posted 05 October 2011 - 08:51 PM
the heads can be swapped, just a few holes in the deck to drill. lay a head gasket over the deck and you will see what i mean
Edited by greens nice, 05 October 2011 - 08:53 PM.
#199
Posted 06 October 2011 - 09:07 AM
#200
Posted 06 October 2011 - 09:22 AM
