IPRA 4 Door LX
#1251
_full_noise_
Posted 08 August 2015 - 01:50 AM
#1252
_jakeslxss_
Posted 09 August 2015 - 01:55 PM
may be a stupid question but what purpose does the foam serve? i cant seem to figure it out haha
nice progress by the way
#1253
Posted 09 August 2015 - 02:19 PM
The foam is put into fuel tanks to reduce fuel surge. It is a similar to putting in baffles in a fuel tank to control fuel surge.
Edited by ls2lxhatch, 09 August 2015 - 02:19 PM.
#1254
Posted 12 August 2015 - 11:06 PM
#1255
Posted 14 August 2015 - 10:01 PM
I am going to wrap them with that heat shield stuff.
Got to get 3 scavenge pipes from the sump connections in the background to the pump. Good luck Craig. Head scratching to follow.
Whilst the engine is out I plan to check and tighten all nuts and bolts before putting the engine back in. Don't want to take it out again if I have to.
#1256
Posted 14 August 2015 - 10:35 PM
Does the pump need to move to adjust the belt tension?
If not it'd be heaps easier to run three hard lines through there than braided line.
#1257
Posted 14 August 2015 - 11:17 PM
Nice work mate. Keep it rolling. Before you know it you'll be in the track!
Cheers Marcus, that's all I can do is keep pushing forward.
Found a pretty stupid fcuk up today. The mount for the 3rd link under the diff is 12mm to low. Will have to fix that.
I have considered that and still looking at that option. It's tight as a nuns proverbial.
#1258
Posted 20 August 2015 - 09:43 PM
#1259
Posted 20 August 2015 - 11:19 PM
#1260
Posted 21 August 2015 - 10:28 AM
So the injectors are Holley as well?
#1261
Posted 21 August 2015 - 07:50 PM
Standard for the moment Shiney,
Mocking up the templates for a dry sump oil tank.
#1262
Posted 21 August 2015 - 08:57 PM
#1263
Posted 21 August 2015 - 09:42 PM
I have no idea how many litres it holds yet.
Who's going to have a guess, LOL..........
#1264
_APL_
Posted 21 August 2015 - 09:52 PM
#1265
Posted 21 August 2015 - 10:13 PM
Just a smidge over 14 litres but I can be more accurate if you give me more dimensions...
EDIT:
BTW, that's a little over 11 kgs of oil (not counting the tank), are you sure you want that much weight that far forward over the front end?
Edited by Bigfella237, 21 August 2015 - 10:21 PM.
#1266
_LS1 Hatch_
Posted 22 August 2015 - 05:24 AM
Will it get any sort of baffles in it, or is that not needed ?
#1267
Posted 22 August 2015 - 06:16 AM
#1268
_LS1 Hatch_
Posted 22 August 2015 - 08:36 AM
#1269
Posted 22 August 2015 - 09:17 AM
#1270
Posted 22 August 2015 - 11:32 AM
#1271
Posted 22 August 2015 - 11:39 AM
Cool looking tank! And I will guess at 9.8 or 11.3 quarts. (I don't believe in metric guesses, lol)
Hey Jeff, yep will fix in baffles in. Is 9.8 quarts close to 12 litres??
EDIT:
Only 6-7 litres will be in the tank. I think it would go bloody close yo 14 litres if I filled it to the top. Good guess with the calculator, LOL.
I wonder if engines like Red Wine???4.3 flagons.
#1272
Posted 22 August 2015 - 11:46 AM
Any reason you arent boot mounting it?
It comes down to cost at the minute. To run 2 lines to the back is more expensive than up front. Weight distribution is not as good but the plan is to have it down back in time. I have a shoe string budget to finish this thing, better to be on track than waiting for more money in parts building the thing.
#1273
_LS1 Hatch_
Posted 22 August 2015 - 12:06 PM
Hmmmmm...so how much do they budget per string ?I have a shoe string budget
(We call them laces in America...but you guys on the metric system and all, who knows...
_LS1 Hatch_
Posted 22 August 2015 - 12:08 PM
Bit over 12, so I was kinda sorta close in a way, lol.Hey Jeff, yep will fix in baffles in. Is 9.8 quarts close to 12 litres??
And good deal on the baffles, figured you might to help minimize potential slosh a bit. Like trap doors and other baffles on some oil pans. (even though you don't worry about it sloshing up towards the crank and creating windage or anything..)
#1275
Posted 22 August 2015 - 12:20 PM
LOL, shoe lace budget just doesn't sound the same Haha.Hmmmmm...so how much do they budget per string ?
(We call them laces in America...but you guys on the metric system and all, who knows...)
