IPRA 4 Door LX
1678 replies to this topic
#1276 eyepeeler
eyepeeler
  • 1,963 posts
Posted 22 August 2015 - 12:24 PM
Just bent this but of 6mm over a pipe with the help of a bit of oxy.
Just the right shape for the tails haft hoop.
#1277 _LS1 Taxi_
_LS1 Taxi_
Posted 22 August 2015 - 12:36 PM
Awesome work as usual
#1278 Shiney005
  • 10,029 posts
Posted 22 August 2015 - 12:38 PM
Now THAT is a fashion faux pas. Those shoe strings don't go with those sneakers at all!!!!
#1279 eyepeeler
eyepeeler
  • 1,963 posts
Posted 22 August 2015 - 02:53 PM
Perf sheet for the baffels. First bit looks like this. Have to make a channel to fit it.
#1280 eyepeeler
eyepeeler
  • 1,963 posts
Posted 22 August 2015 - 03:50 PM
Channel tacked in. Worked well.
Both panel are cut with safety edge fold for stiffness.
Nice fit.
Will make 2 layer perf plate to fit on top for the returning oil. Similar to this, with the other layer about 50mm above.
#1281 eyepeeler
eyepeeler
  • 1,963 posts
Posted 27 August 2015 - 08:00 PM
My hoop is offset just the same a Heaths
Setting up the clutch lines.
Time to get all things engine in an tightened up.
#1282 eyepeeler
eyepeeler
  • 1,963 posts
Posted 27 August 2015 - 08:04 PM
#1283 eyepeeler
eyepeeler
  • 1,963 posts
Posted 27 August 2015 - 08:09 PM
Good engagement of the starter. I've had that in since machining the mount and never known if it was good or not. Great to see it worked out ok.
#1284 _Bomber Watson_
Posted 27 August 2015 - 08:16 PM
Nice.
That flywheel/clutch is pure sex.
#1285 Potta
Posted 27 August 2015 - 10:25 PM
Nice.
Fr0ck yeah, getting exciting now!!
#1286 myss427
myss427
  • 1,636 posts
Posted 28 August 2015 - 10:29 AM
Good to see Quicktime has made a larger window in the side of the bellhousing for clutch lines, mine is a 2cm gap and impossible to get a spanner through! You need to feed the lines out before bolting up.
#1287 eyepeeler
eyepeeler
  • 1,963 posts
Posted 28 August 2015 - 05:04 PM
Exhaust wrap
#1288 eyepeeler
eyepeeler
  • 1,963 posts
Posted 28 August 2015 - 08:31 PM
#1289 orangeLJ
Posted 31 August 2015 - 03:53 PM
I feel the need to do a Tim the tool man Taylor gruff chuckle.
Thats how awesome this is.
#1290 eyepeeler
eyepeeler
  • 1,963 posts
Posted 31 August 2015 - 08:06 PM
Cheers mate, appreciate that.
#1291 eyepeeler
eyepeeler
  • 1,963 posts
Posted 03 September 2015 - 07:08 PM
Scavenge line in oil lines are done
Working on pressure line to the block. I am going to use a remote oil filter arrangement
This is where the oil comes into the block from the oil filter.
#1292 Racehatch
Racehatch
  • 1,028 posts
Posted 03 September 2015 - 11:32 PM
What size line are you running to the supply side of the pump?
#1293 eyepeeler
eyepeeler
  • 1,963 posts
Posted 03 September 2015 - 11:45 PM
Hey Sam, -12 from the tank to the pump
-10 from the pressure out on the pump to the remote oil fitting and onto the block which its -8 to M16 X1.5
2 @ -10 & 1 @ -12 from the pan to scavenge in on the pump
And lastly -12 from scavenge out to the tank
All fuel lines are -8
Love the video you posted from Malalla. That was really good. Off the line looked fun!!
#1294 Racehatch
Racehatch
  • 1,028 posts
Posted 04 September 2015 - 04:46 PM
Okay cool that sounds fine - are you not running an oil cooler?
RE video, cheers mate, loving just being able to drive the car without it breaking, going to make some changes to the rear end to help with steering mid corner and exit - also looking to change my gearbox ratios as they are a bit tall 1-3 which makes it hard to get off the line.
Wont be long now and you'll be out there yourself!
#1295 eyepeeler
eyepeeler
  • 1,963 posts
Posted 10 September 2015 - 11:08 PM
Had some help tonight putting the diff and engine back in, Dave Mc A9X868 dropped by to say g'day. Great chat and great help along the way. 1 bolt just didn't want to play the game and Dave and I had a bastard of a time getting the holes lined up to get it done. Got it in the end.
Will take a few pics later on.
Great to catch up Dave, as always.
#1296 eyepeeler
eyepeeler
  • 1,963 posts
Posted 12 September 2015 - 06:03 PM
#1297 _greg2240_
_greg2240_
Posted 15 September 2015 - 09:10 PM
looks tough, great build
#1298 _LS1 Hatch_
_LS1 Hatch_
Posted 15 September 2015 - 11:54 PM
:spoton:
#1299 _The Baron_
_The Baron_
Posted 16 September 2015 - 12:26 PM
WOW, this project is epic!
#1300 eyepeeler
eyepeeler
  • 1,963 posts
Posted 16 September 2015 - 08:54 PM
:spoton:
Cheers fellas. With pretty much all the fab work done, it's down to assembly, plumbing and wiring.
