LX Hatch Complete Restoration
484 replies to this topic
#276 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 13 November 2021 - 03:00 PM
Finally got the air con unit mounted.
The guy who supplied the unit, and who is going to do all the plumbing and wiring,
made this plenum chamber that takes the air from the front around to the right hand side with four ports to connect hoses to.
Two at the top, one at the back and one at the bottom.
Attached File  IMG_0868.jpg   249.72K   8 downloads
Attached File  IMG_0869.jpg   298.52K   7 downloads
Attached File  IMG_0870.jpg   271.5K   7 downloads
Attached File  IMG_0872.jpg   381.6K   6 downloads
Attached File  IMG_0873.jpg   305.47K   6 downloads
Regards Mando.
#277 SmacT
  • 1,026 posts
Posted 14 November 2021 - 11:46 AM
Looks neat!
#278 Shiney005
Posted 14 November 2021 - 12:55 PM
Will it be plumbed into the defrost vents as well? Probably get away without the legalities of needing a heater that way.
#279 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 14 November 2021 - 06:47 PM
Not sure at the moment.
I'm at the stage where the quickest and easiest is the best.
I didn't rebuild the heater motor, and I didn't install the small radiator into the heater box.
The heater box flaps all work from the original slide controls, so it could be used to distribute the air to all the ducts.
I'll leave it up to the air con guy, as long as every thing works.
Regards Mando.
#280 Heath
Posted 15 November 2021 - 08:19 AM
Is this being installed as a totally additional unit?
It's the same unit as mine, but the installation has nothing in common at all, haha.
#281 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 15 November 2021 - 09:57 AM
Heath,
nothing and no-one could be compared to any of your installations.
Regards Mando.
#282 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 26 November 2021 - 05:57 PM
Hi Guy's,
can anyone let me know where the two hoses left and right of the centre hose get connected to please.
Attached File  IMG_0881.jpg   250.57K   7 downloads
Attached File  IMG_0882.jpg   348.94K   8 downloads
Attached File  IMG_0883.jpg   247.84K   11 downloads
Door windows in, really happy with the green tinge.
Attached File  IMG_0884.jpg   222.45K   7 downloads
Regards Mando.
#283 Bigfella237
Posted 26 November 2021 - 06:19 PM
The fitting you've got the hose connected to (not "TANK", the other one) just goes to a vacuum supply. It's supposed to draw any fumes out of the canister and burn them in the engine.
The other one ("CARB") is connected to the fuel bowl vent on anything except 5 litre cars, on Quadrajet equipped cars (ie 308's) it's blocked off.
As you don't have a carby you can safely and legally block it off as well.
Evaporative-Emission-Controls-LX-4-2-L.j
Evaporative-Emission-Controls-LX-5-0-L.j
#284 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 26 November 2021 - 06:27 PM
Thanks Andrew.
Regards Mando.
#285 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 12 January 2022 - 10:15 AM
Hi Guy's,
can anyone let me know where I can get some wiper assemblies from in black [not the arms].
Rares and the other suppliers can only supply them in stainless.
Regards Mando.
#286 rexy
  • 3,834 posts
Posted 12 January 2022 - 12:05 PM
Just paint them?
#287 claysummers
Posted 12 January 2022 - 01:34 PM
Seems to be hard to get good adhesion to stainless. Maybe powder coat or light sand blast prior to etch prime.
#288 Bigfella237
Posted 12 January 2022 - 04:13 PM
Can you anodise stainless?
I think they used to call it black chrome, if that's the same thing?
#289 rexy
  • 3,834 posts
Posted 12 January 2022 - 05:14 PM
Just scuff it and rattle can it. It’s surprising how well things come up. Seems to last well and is easy enough to redo if needed at some stage.
#290 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 12 January 2022 - 07:33 PM
Thank's guy's,
I think I'll try and lightly glass bead them and the paint.
Regards Mando.
#291 Ice
Posted 12 January 2022 - 08:08 PM
With the right prep it will stick like frOck
#292 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 14 January 2022 - 10:15 AM
Got mine powdercoated in satin black
Came up a treat
#293 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 15 January 2022 - 05:44 PM
Andrew,
I haven't had much luck with black chrome.
Rexy,
I know I'm over thinking this.
Sometimes the easiest solution is often the best.
Dave,
I didn't think about powder coating.
I'll pull them apart then decide.
Thanks for the idea's.
Regards Mando.
#294 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 19 February 2022 - 04:40 PM
Hi Guy's,
does anyone have a pair of LX Hatch quarter window latches they're happy to sell?
Average condition would be great, but I'll look at anything that may be available.
Regards Mando.
#295 Shiney005
Posted 20 February 2022 - 09:54 AM
This guy is in Perth if you are on Facebook.
https://www.facebook...hare_attachment
#296 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 19 March 2022 - 04:11 PM
Nearly finished the underside, mainly the electrical to be done
Attached File  IMG_0952.jpg   309.39K   9 downloads
Attached File  IMG_0953.jpg   213.95K   7 downloads
Attached File  IMG_0954.jpg   240.59K   12 downloads
Attached File  IMG_0955.jpg   342.94K   9 downloads
Attached File  IMG_0957.jpg   264.69K   8 downloads
Attached File  IMG_0959.jpg   224.03K   7 downloads
Regards Mando.
Edited by jeffblanco, 19 March 2022 - 04:12 PM.
#297 Bigfella237
Posted 19 March 2022 - 04:23 PM
That is a thing of beauty, well done!
With the (almost) solid mounts on the tailpipes, I assume there's a flex-pipe in the exhaust somewhere between the cats and the mufflers?
#298 Shiney005
Posted 19 March 2022 - 06:36 PM
Ready for Summernats 2023
#299 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 20 March 2022 - 08:22 PM
Hello Andrew,
I always get scared when I see one of your posts.
Your assumption would be wrong.
I have more rubber mounts through the centre of the car, but I don't have any of those flex pipes I now notice on other LS resto mods.
Again, I foolishly assumed the guy who did the exhaust system knew everything I should need on my LS3
and would have installed it accordingly.
WRONG AGAIN.
What will happen if I don't have them installed?
The exhaust is stainless from the extractors to the diff, so it wouldn't be that difficult to cut and install two flex pipes.
Regards Mando.
Edited by jeffblanco, 20 March 2022 - 08:23 PM.
#300 Heath
Posted 21 March 2022 - 08:58 AM
They certainly are not mandatory, but of course if you have a motor that moves around a lot and an exhaust that is very tightly retained, there might be some fighting going on there.
I believe that the only "no brainer" application for flex pipes would be in an application where the motor is east-west as its torque-reaction is on a totally different plane to the direction of the exhaust.
Do the exhaust mounts closer towards the front of the car have more freedom of movement than the rear ones? (I think at least that would be recommended!)
