LX Hatch Complete Restoration
484 replies to this topic
#301 Bigfella237
Posted 21 March 2022 - 01:31 PM
~ the only "no brainer" application for flex pipes would be in an application where the motor is east-west as its torque-reaction is on a totally different plane to the direction of the exhaust.
Do the exhaust mounts closer towards the front of the car have more freedom of movement than the rear ones? (I think at least that would be recommended!)
^ What he said! I hate flex-pipes myself, but they are sometimes a necessary evil.
However, if the front half of your system is as Heath says and has 'proper' exhaust hangers, then it would be far easier to mod the tailpipe mounts to allow some more movement rather than fit some kind of flexible joint. I mean, if you did add flex-pipes then you'd need to solid-mount the mufflers too, otherwise you have the same problem!
The problem occurs over time, if you take a piece of steel and clamp one end in a vice, then constantly move/vibrate the other end, it will eventually (and prematurely) crack.
The only time I'd use flex-pipes in this situation is if you're REALLY tight on space going over the diff and/or past the tank, then you could solid-mount the rear half of the system and, with your heat wrap and maybe some extra shielding, you could almost have it hard up against the floor.
Edited by Bigfella237, 21 March 2022 - 01:33 PM.
#302 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 29 April 2022 - 04:26 PM
Hi Guy,s
could anyone let me know what these brackets are for please?
.Attached File  IMG_0956.jpg   453.53K   7 downloads
Attached File  IMG_0957.jpg   423.31K   6 downloads
Attached File  IMG_0958.jpg   415.42K   6 downloads
Regards Mando.
#303 Heath
Posted 29 April 2022 - 04:36 PM
The part on the left? I do not recognise that as a Torana part. I've never seen it before.
The part on the right? That's been broken off a front door hinge... it is the detent cam for opening the door, and a strong tension spring stretches around it (kind of like a check strap, but Toranas don't have check straps). You can kind of see it in this photo of my front door hinges:
#304 Bigfella237
Posted 29 April 2022 - 05:04 PM
I was gonna guess the part on the left may be part of a column-shift linkage? IE. It bolts to the bottom of a steering column?
But that's just a guess (I don't think I've ever seen a column-shift Torana in the flesh).
#305 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 29 April 2022 - 06:16 PM
Thank's guy's,
that's what happens when you by a car in pieces.
Regards Mando.
#306 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 15 July 2022 - 11:12 PM
Hi guy's,
could anyone help me please.
I'm after 4 of the small spacers I have highlighted in blue pen.
I know it's a long shot, but if anybody has some lying around
and could take some measurements I could make them from aluminium.
Attached File  IMG_1008.jpg   148.45K   6 downloads
Attached File  IMG_1009.jpg   126.22K   8 downloads
Regards Mando.
#307 308 Sunbird
308 Sunbird
  • 976 posts
  • Name:Stuart
Posted 16 July 2022 - 02:04 PM
I think they are moulded to the facia Mando
#308 76lxhatch
Posted 16 July 2022 - 04:28 PM
Yes they are the recess for the screw head
#309 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 16 July 2022 - 07:05 PM
I'm fairly sure they are small tubes that are bigger one end than the other.
I remember unscrewing the gauge cluster from the dash panel, and throwing the spacers in the bin
thinking I'll be able to get a hold of these from somewhere.
How stupid do you want to be?
Regards Mando.
#310 Shiney005
Posted 17 July 2022 - 10:46 AM
I cringe when I think about what I used to throw away in the 1980's. Two whole SLR/5000's went on the tip. They weren't much more than bush bombs at the time, but man I could have used some parts off them since.
#311 Cook
Cook
  • 1,535 posts
Posted 17 July 2022 - 12:14 PM
Hi Jeff.  Here is a pic of the back of my fascia and I think they are the "lugs" incorporated into it.  One is threaded, which would correspond with the top one in the above pic, which would screw the cluster to the fascia, and one is just a spacer/locator, as per the bottom one, which would screw the whole lot to the body, via the speed nut.  Hope I am right as I don't have any separate spacers.  Cheers Ron
Edited by Cook, 17 July 2022 - 12:15 PM.
#312 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 17 July 2022 - 06:19 PM
Thanks Ron,
my dash is the same as yours.
The tubes I'm thinking about must have come from somewhere else.
Everything seems to lock in together, so I must be dreaming.
Thats for all your help guy's.
Regards Mando.
#313 hanra
Posted 18 July 2022 - 07:00 AM
No seperate spacers. The image is deceiving. Use the workshop manual.
#314 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 02 September 2022 - 11:48 PM
Hello Punters,
could anyone please let me know, if the handbrake release knob on the dash of a A9X
has the symbol on it or is it the one that say's twist and pull.
The pictures I've seen have the symbol, but rare spares shows the ones with the symbol
being for earlier models.
Regards Mando.
#315 Shiney005
Posted 03 September 2022 - 09:30 AM
It isn't something you see in photos because the steering wheel is usually at "straight ahead" and hides it.  I do have pics of about a dozen cars where you can see it, and it seems to be split about 50:50 between them. So the short answer is I don't know.  L34's were definitely the symbol.
Attached File  cd5122904310460031279.jpg   166.51K   4 downloads
#316 AbsynthHatch
AbsynthHatch
  • 765 posts
  • Name:Mark
Posted 10 September 2022 - 03:14 PM
My hatch is a 9/77 build and has the 'twist pull' type knob from the factory.
Probably was to much confusion with the meaning of the symbol on the other offering.
#317 AbsynthHatch
AbsynthHatch
  • 765 posts
  • Name:Mark
Posted 10 September 2022 - 03:20 PM
I thought symbol was LH & writing was LX but I don't think it was that clear cut.
#318 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 10 September 2022 - 03:37 PM
Thanks Guys,
no one has them in stock at the moment, so I think I'll order the twist and pull and wait.
Regards Mando.
#319 Bigfella237
Posted 10 September 2022 - 03:51 PM
I'm almost certain the symbols came later when GMH started exporting to non-English-speaking countries.
The same thing would've happened with instrument clusters... a pic of a jerry can instead of "FUEL"... a pic of an oil can instead of "OIL"... etc..
There is some "International Standard" (ISO) that determines which symbol is used for what purpose.
#320 claysummers
Posted 10 September 2022 - 06:16 PM
Part of the same fashion trip bringing in euro world car ethos with the VB Commodore no doubt
#321 AbsynthHatch
AbsynthHatch
  • 765 posts
  • Name:Mark
Posted 12 September 2022 - 05:57 PM
That's an interesting point Andrew.
#322 Shiney005
Posted 15 September 2022 - 08:41 AM
Except it may be the other way around?  I have seen plenty of LH Toranas in Indo, but I don't know if I have ever seen an LX. Like I said above, all L34's have the symbol, so maybe LH's had it for export reasons, and then sometime during the LX lifecycle exports to non english countries were stopped and the "Twist and Pull" came about?  I'm only guessing here.
#323 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 15 September 2022 - 12:44 PM
Rare Spares describe the handle with the symbol as being "early LX".
I'm still not any clearer.
The thing that really pisses me off, is that I bought the handle with twist and pull
about two years ago, and had it in the box on my kitchen table for about the last four months.
Now I can't find it any where.
Regards Mando.
#324 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 15 September 2022 - 01:09 PM
Don't despair Jeff, you're not the only one. I have lots of parts like that, if I ever move house will probably find them.
#325 Cook
Cook
  • 1,535 posts
Posted 15 September 2022 - 01:13 PM
Hi Jeff. My hatch is 11/76 and has the symbol.  I got a new one from Restocountry and according to EBay they have them in stock. Cheers Ron
