Hawks Torana dream lives on
#201
Posted 21 April 2021 - 09:37 PM
The cable ties are what came with the new boots and the metal clips were rusty.
#202
Posted 21 April 2021 - 10:07 PM
Brad Merrick does repros if they are the same as LC/J.
JPXU1
#203
Posted 15 May 2021 - 04:31 PM
After the issues with the rack, I pulled the rack ends out of my spare rack. They were pretty rough but after a clean up, did the trick.
So finally have steering.
Picked up the front tyres, new wheel nuts and more cotter pins today.
Pretty happy with how its looking.
FB_IMG_1621060060420.jpg 123.42K
6 downloads
FB_IMG_1621060065343.jpg 126.39K
6 downloads
FB_IMG_1621060062807.jpg 132.22K
7 downloads
#204
Posted 15 May 2021 - 08:59 PM
#205
Posted 31 May 2021 - 12:22 PM
progress has slowed a lot lately although still going. A lot of little things not worth posting about.
I'm about to start building the motor and have stripped it down to a bare block. It has a .040 over bore with flat tops. The bores arnt horrible so they will get a hone and the pistons will be reused.
the bottom end bearings were far from the worst I've seen although need doing.
To start off I plan on having the block tanked and possibly decked with new cam bearings and a hone.
The crank will need to be polished and refitted with new bearings. then re use the pistons as before.
I plan on reusing the heads with a minor rebuild and standard rocker gear.
The cam, lifters, timing chain, push rods and harmonic balancer all need to be replaced.
I've been told that the biggest cam I should run is 200 @ 050 while in the little league article they ran 237.
Realistically what is the biggest cam I can run in it?
Plan is to run an edelbrock dual plane manifold with 4 barrel. the holley pictured is supposed to be a 600. Should I downsize to 400ish?
Anyway a few pics below.
FB_IMG_1622426638672.jpg 109.77K
4 downloads
FB_IMG_1622426642113.jpg 87.27K
4 downloads
FB_IMG_1622426664638.jpg 95.48K
4 downloads
FB_IMG_1622426669082.jpg 83.12K
4 downloads
FB_IMG_1622426680668.jpg 99.23K
4 downloads
FB_IMG_1622426658966.jpg 99.58K
4 downloads
FB_IMG_1622426650205.jpg 75.75K
4 downloads
FB_IMG_1622426653002.jpg 76.09K
5 downloads
Edited by hawk, 31 May 2021 - 12:23 PM.
#206
Posted 31 May 2021 - 07:48 PM
#207
Posted 31 May 2021 - 11:21 PM
It's a 253 isn't it?
#208
Posted 01 June 2021 - 10:32 AM
Rodomo, its a 253.
#209
Posted 01 June 2021 - 05:27 PM
#210
Posted 02 June 2021 - 11:05 PM
It will feel like a different engine.
Shave heads and deck block to get the comp up on it
#211
Posted 03 June 2021 - 07:59 AM
#212
Posted 03 June 2021 - 10:39 AM
Hi Steve. Any progress is good progress. I notice those engine mounts are, I'm pretty sure, from H series holdens. If you intend on using them check your clearances, particularly steering knuckle against extractors, as I had issues with the same mounts. I used them in the hope of getting the motor a fraction lower but had to ditch them for Torana mounts. Cheers Ron
#213
Posted 03 June 2021 - 12:02 PM
I'll see what they come back with. if it's going to be 5k or more I'll have to throw the 6 back in for now and build the 8 over the next year or so.
Anyway build pans are similar to the image below.
As for clearance, I have done the double knuckle mod to help although haven't checked extractor clearance yet.
FB_IMG_1618998029831.jpg 34.39K
5 downloads
Screenshot_20210601-171616_Samsung Internet.jpg 102.4K
8 downloads
#214
Posted 03 June 2021 - 12:48 PM
You don't really need VN V8 rods, any from mid VK onwards will do if you want stronger rods, IIRC the VK rods are the same as L34. Otherwise use the ones you have with new bolts.
You won't be able to run a HQ/HJ intake with those heads, need to change to HT-HJ heads to run the early intake.
Not sure I'd bother putting 305 SBC intake valves in it, the standard size should be fine for a 253. The bore is really too small for that size valve, although at 60 thou over might be close to OK.
Keep compression below 10:1 if you can so you can happily run on 98 and even 95 if you have to.
And I still stand by the XT5 4.2 Quadrajet, just get it setup right.
#215
Posted 04 June 2021 - 06:20 PM
Don’t spend too much on it.
if you are up for a fair bit to do it then you might as well find a 308. The extra capacity will be the cheapest HP you can get.
Im betting that at 38 degrees timing that guy got to replace a lot of head gaskets.
Stick with a hydraulic cam and standard style rocker gear if you can.
#216
Posted 12 June 2021 - 06:46 PM
couple of questions though.
Are aussie 3 and aussie 4 speed bellhousings the same?
is the clutch for the same for floor shift and column shift?
Probably going to get a dellow hydraulic clutch kit to avoid having to source a cable clutch setup.
This motor will get a degrease, and maybe a couple of gaskets and then just drive it.
Saw it running before purchase, it came out of a low mile Hq.
The plan is to get it running in the car and set up this weekend if I find time then pull it out for a clean and to attach a 4 speed.
Pretty sure I'll need to change the thermostat housing and drill the water pump for the heater lines.
FB_IMG_1623487115419.jpg 87.39K
5 downloads
FB_IMG_1623487118397.jpg 66.39K
4 downloads
#217
Posted 12 June 2021 - 07:03 PM
#218
Posted 12 June 2021 - 07:51 PM
I'll get it on the road then worry about modifying it. Really cutting it close time wise now.
#219
Posted 12 June 2021 - 08:22 PM
What's your deadline, Yr12 formal?
#220
Posted 12 June 2021 - 08:24 PM
#221
Posted 12 June 2021 - 08:40 PM
Hmm, tough predicament. Just move to where he goes. Easy peasy.
#222
Posted 12 June 2021 - 10:29 PM
Anyway chipped away at it tonight and got it to start.
It won't idle, seems to be a fuel issue. It starts if I give the carb a few shirts, pump is working.
I blanked all the vacuum ports but it still sounds like a vacuum issue. There is 2 ports on the manifold. One for the brake booster and one that goes to the rocker cover. and one on the carb for the dizzy.
Carb is leaking a bit so could be the issue? although it idled when bought.
Only have choke hooked up as accelerator cable bracket is different.
Excuse the tape and temporary wiring haha.
FB_IMG_1623500570023.jpg 94.92K
6 downloads
FB_IMG_1623500566361.jpg 87.7K
4 downloads
FB_IMG_1623500563473.jpg 101.41K
4 downloads
FB_IMG_1623500557588.jpg 94.85K
4 downloads
#223
Posted 12 June 2021 - 10:53 PM
Try it again in the morning. The needle and seat might have gummed up due to sitting. (this would explain the fuel leak due to flooding and also why you have to give it a big gulp of air to keep it running) Now that it has fresh fuel flowing it might dissolve the gum.
#224
Posted 12 June 2021 - 11:11 PM
It wasn't sitting as it was running in the car it came out of a few days ago.
#225
Posted 12 June 2021 - 11:23 PM
I told you not to sell the old one but good to see you are back in the game.
I think sometimes not having one reignites the flame...
That's what did it for me too.
