Hawks Torana dream lives on
448 replies to this topic
#176 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 07 March 2021 - 05:38 PM
Finished off the floor today and got a few photos of the welds. They show the sill welds and what looks to be at the rear wheel arches in the door jams and at the front of the front floorpan.
anyway, will be slowly getting reassembled now.
Attached File  FB_IMG_1615101498952.jpg   38.16K   6 downloads
Attached File  FB_IMG_1615101496156.jpg   128.26K   4 downloads
Attached File  FB_IMG_1615102464540.jpg   21.07K   4 downloads
Attached File  FB_IMG_1615101506747.jpg   79.63K   4 downloads
Attached File  FB_IMG_1615101509450.jpg   70.84K   5 downloads
#177 toryman76
toryman76
  • 1,082 posts
Posted 08 March 2021 - 07:32 AM
All that effort and they still put a UC arse on it! 😂😂😂 jokes aside cars coming along brilliant mate. KBS floors look mint. Keep it up.
#178 yel327
Posted 08 March 2021 - 07:42 AM
You'll find joins on the windscreen pillars too. Hopefully they staggered those properly.
#179 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 10 March 2021 - 04:50 PM
One pillar is welded closer to the mirror and the other closer to the roof. Centre section of the car was maroon. Rear im not sure about but the welds in the rear door jams deffinitly arnt factory.
So Radiator support is off one car, rails, front floor and engine bay off another and potentially had the rear off a different car. As there are welds on both sides in the door jams.
Anyway bit more progress as the interior is going back in. decided to re use my old pillar vinyl due to colour matching. New floor plugs, steering column back in.
Attached File  FB_IMG_1615358576708.jpg   69.75K   5 downloads
Attached File  FB_IMG_1615358571799.jpg   49.09K   7 downloads
#180 toryman76
toryman76
  • 1,082 posts
Posted 10 March 2021 - 05:04 PM
Almost a roller ready for paint?? Is that the plan Steve?
#181 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 10 March 2021 - 06:36 PM
I wish that was the case but the outside is staying ratty for now.
Plan is to finish the interior off in the next week, then its going back together slowly to be prepared for rego.
Interior:
Carpet
T Bar handle replacement
Kick panels
Rear seat belt bolts
Column key barrel area is out of whack so need to sus that out.
Exterior:
New speed nuts for front panels.
weld in a new battery tray
Windscreen replaced only if required for rego.
new wheel nuts.
new washer bottles.
245 50 14 rear tyres
Not sure on front tyre size yet.
Mechanical:
Steering rack rebuild, may replace it yet as per previous post.
New uni joints for tail shaft.
Front brake calliper rebuild.
Driveline will be a 253 and auto at this stage although if funds and time run out I'll throw a 202 auto back in it for the time being.
Then it will just be the minor things to finish it off.
#182 toryman76
toryman76
  • 1,082 posts
Posted 11 March 2021 - 08:56 AM
Nice! Solid list to keep you busy but also remain focused. Paint can come after all this as the rest of the car will be micky mouse.
#183 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 15 March 2021 - 05:05 PM
Paint will be down the track after I eventually buy a house.
Got the carpet, kick panels, underlay and a hatch style auto knob.
Ran out of underlay so I'll pick some more up after work tomorrow.
Attached File  FB_IMG_1615791715673.jpg   69.53K   4 downloads
Attached File  FB_IMG_1615791736264.jpg   52.82K   4 downloads
#184 yel327
Posted 15 March 2021 - 06:03 PM
I always grabbed UC shifters when I could as they shift on the correct side for a TH400 and bolt straight into a HQ-WB tunnel hole. Harness plugs straight into the dash. Used to get a little vinyl boot made up and tuck the ends under the carpet. Allowed you to run a bench or buckets with a floor shift auto ie not console shift. Was especially good when the original TH400 column shift got all sloppy. Was good for a van with buckets as it allowed you to get into the back easier.
#185 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 15 March 2021 - 06:48 PM
I remember when I had my old HQ statesman I had to get the shifter link swapper to the other side when fitting an early commodore trimatic.
#186 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 16 March 2021 - 07:51 PM
Interior is finally back together, got a few tweaks to make and carpet isn't perfect but pretty stoked its together.
Still need upper rear seatbelt bolts and The centre console mid section screws.
The auto shifter is a little off centre but its sikaflexed in to seal it so it can stay like that for now.
The seatbelts will probably need to be replaced at some point too.
Attached File  FB_IMG_1615887844256.jpg   71.04K   5 downloads
Attached File  FB_IMG_1615887840804.jpg   43.69K   5 downloads
Attached File  FB_IMG_1615887837849.jpg   60.18K   8 downloads
#187 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 25 March 2021 - 03:21 PM
Small update, started on the front of the car tonight and got the battery tray out.
Attached File  FB_IMG_1616649143797.jpg   155.22K   7 downloads
#188 toryman76
toryman76
  • 1,082 posts
Posted 25 March 2021 - 06:16 PM
Nicely done. Should clean up alright.
#189 Rockoz
Posted 26 March 2021 - 09:40 AM
As far as your tyres go, I would make a suggestion to you based on experience.
The car will handle a hell of a lot better if you have the exact same tyres front and rear.
From the introduction of RTS that has been the best option right through to the end of the Commodores.
Even my LC did best with common tyres.
I did try 10mm wider on the rear, but the understeer became really bad.
But I do tend to like tight winding roads more than most.
#190 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 31 March 2021 - 04:23 PM
Thanks, I've narrowed down tyre size to 245/60/14 Hankooks or 245/50/14 Eagers for the rear. The front will be a 195/60/14 hopefully.
The red car in the photo is my old one with 195 65 14 front and 215 65 or 60 14 rear. Rears were 8's and a different offset.
Anyway spent this afternoon working on the fit of the battery tray. The rares item really is a poor fit and needed a fait bit of hammering. The fit looks relatively good now.
Attached File  FB_IMG_1617171131216.jpg   81.49K   7 downloads
Attached File  FB_IMG_1617171140130.jpg   65.57K   8 downloads
Attached File  FB_IMG_1617171133980.jpg   49.23K   6 downloads
Attached File  post-7807-0-97394000-1347700354.jpg   103.7K   9 downloads
#191 yel327
Posted 31 March 2021 - 05:23 PM
245/60/14 are a lot bigger than 245/50/14. If you were near me I could loan you one of each to compare.
Edited by yel327, 31 March 2021 - 05:23 PM.
#192 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 07 April 2021 - 04:40 PM
Cheers, although I think I'm set on the 245,60,14's. Based on the photos below.
Finished off the battery tray. Dropped the motor and box in so I could tighten up the front suspension.
So below is 245/60 on the passengers side and 215/65 on the drivers side.
Attached File  FB_IMG_1617770862915.jpg   75.09K   10 downloads
Attached File  FB_IMG_1617770866087.jpg   69.82K   10 downloads
Attached File  FB_IMG_1617770869402.jpg   129.27K   8 downloads
Attached File  FB_IMG_1617770872467.jpg   114.8K   8 downloads
Attached File  FB_IMG_1617770878827.jpg   98.88K   7 downloads
#193 mitchg
mitchg
    The guy with the Torailer
  • 3,111 posts
  • Name:Mitch
Posted 07 April 2021 - 09:25 PM
Looking good Steve! Way more progress than mine, that's for sure! Looks great all back together!
Any plans to smooth or tidy the bay? Working that battery tray is the perfect time lol
#194 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 08 April 2021 - 11:03 AM
Thanks, working away at it. Hopefully I can pick up a new rack next week. I have a tight deadline haha so need to push to get it done.
Funds have run dry now so it's going to slow down a fair bit.
At this stage the bay won't be getting done as that will open a can of worms. It will stay looking standard even in the future. Due to the amount of damage to the rails I feel like cutting the lips off them would significantly weaken them.
When the bay is done the bonnet hinge area will weed attention. there will be a few small holes hiding there. and the radiator support panel will need to be removed and welded on properly. Its currently brazed on and not sitting 100%.
#195 toryman76
toryman76
  • 1,082 posts
Posted 09 April 2021 - 12:55 PM
Smart play to leave the bay for now. I feel like I spent way more time on mine than the rest of the car and I didn't smooth anything. I'm happy with the result though.
#196 mitchg
mitchg
  • 3,111 posts
  • Name:Mitch
Posted 09 April 2021 - 08:52 PM
Thats how mine started, I ripped the battery tray due to rust and added flat sheet, then starting filling holes and smoothing wheel arches and welded that gap between arches and rails. I didnt trim the rails, didn't see it overly necessary and looks wonky if the holes aren't centre in them so I left them alone.
Looking forward to the rest of the build!
#197 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 18 April 2021 - 10:35 PM
Well a little more progress.
Picked up another steering rack for parts and will drop them both off to have a good one made out of the two. Hopefully that will be done this week.
Bolted the front guards back on with all new speed nuts and chrome bolts from resto spares. Made fitment a lot nicer.
I need new headlight screws if anyone knows where to get them? Resto spares don't have them, will have to check rares.
Got new rear tyres ended up with 225 60 14 Nankangs mainly due to them being available and at a good price. decided on 215 60 14 for the front also available in nankangs.
Attached File  FB_IMG_1618725908593.jpg   79.84K   5 downloads
Attached File  FB_IMG_1618725905649.jpg   109.59K   6 downloads
#198 Heath
Posted 19 April 2021 - 09:56 AM
When you say headlight screws... send me a message on FB with a photo of the screw with a ruler next to it. I may have spares.
#199 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 21 April 2021 - 07:51 PM
Thanks heaps Heath.
If I can't find new ones I'll let you know.
Had the rack rebuilt with new everything. Did the double knuckle mod and fitted it all up to find it doesn't fit.
Had some advice through Facebook that even though the rack ends are listed as UC they aren't actually UC rack ends. Apparently I need to cut the thread further along the rack end then cut them down about 15mm per side. does this sound right?
Anyway, a few pics. The one of the passengers wheel shows where it sits with the drivers side straight and the tie rod ends at max adjustment.
Attached File  FB_IMG_1618998026964.jpg   130.78K   5 downloads
Attached File  FB_IMG_1618998029831.jpg   34.39K   4 downloads
Attached File  FB_IMG_1618998036924.jpg   61.84K   7 downloads
Attached File  FB_IMG_1618998612571.jpg   88.13K   5 downloads
#200 S pack
Posted 21 April 2021 - 09:21 PM
What was wrong with the original tie rod ends?
Also excuse me for saying this but......bloody cable ties, everyone uses bloody cable ties to hold the rack boots on. Give them a couple of years and they will break and fall off.
Whatever happened to the good ol metal clips?
Edited by S pack, 21 April 2021 - 09:24 PM.
1 members, 1 guests, 0 anonymous users
